Question about Motorola Mobility W375 Cellular Phone
I have a 375 motorolla cellphone. we have a fax machine. the fax machine is plugged in but not turned on. i heard noises in the fax machine & the light on the motorolla cellphone lit up the same time. what does that mean?
How do you enter the time on the fax machine
look for a menu or setup button go to fax settings and find time and date.
Feb 28, 2012 | Philips FaxJet 375 Plain Paper Inkjet
How to put new cartrige in faxjet 375
1. turn on printer.
2. open the printer.
3. the printer will automatically move the cartridge tray into an easy to access location.
4. replace cartridges.
5. close printer.
Mar 28, 2011 | Philips FaxJet 375 Plain Paper Inkjet
No dial tone
plug out the fax... plug in a phone... if still no dialtone... replace phone cable... still no dial tone... call the phone company...
plug out the fax... plug in phone... dial tone heard... bad fax... try to reset fax machine... per instructions... still no dial tone... call repair guy...
Dec 18, 2009 | Office Equipment & Supplies
Unable to work phone no loop current what does this mean
Your fax machine cannot find a dial tone. make sure the ANALOG phone cord is plugged into the LINE port.
Aug 01, 2009 | Philips FaxJet 375 Plain Paper Inkjet
Error Log Result 232... The telephone connection was lost.
Error 232 Definition A communication failure occurred between the two machines. The user at the remote machine might have pressed the Stop key. The call waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line. Do not use call waiting on a line with a fax machine. The power at the remote machine was interrupted, or deliberately turned off causing the fax session to be interrupted. Check the following items: Make sure that you have plugged the phone cord directly and securely into the wall jack and into the back port of the fax product. The fax port on your product is marked "Line," "To Wall Jack," or with a wall jack symbol. Make sure the Line Interface Unit (box that the phone cord plugs into) is fully seated into the back of the fax product. Remove any other devices from the line such as splitters, credit card machines, or telephone answering machines. Try sending and receiving faxes on a different fax line. Try using a different telephone cord. Have the phone company test your line for static or noise problems. Turn Error Correction Mode (ECM) off, if you encounter the same error repeatedly Solutions If the error persists, and error correction is in use for the fax session, disable ECM. Fax quality might be degraded. Set the host machine to receive at a slower transmission speed. Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power brownouts and other power-related problems. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
Jun 09, 2009 | HP OfficeJet 6210 All-In-One InkJet...
I've got a Philips Faxjet 375 which displays NO LOOP CURRENT when I try to fax anything Any advice?
No dial-tone detected. Plug a regular phone into the wall jack and verify dial-tone.
Make sure you are plugged into the LINE port of the fax machine.
Nov 07, 2008 | Philips Office Equipment & Supplies
How do I get a fax number?
you are correct just use a splitter and if you hear a fax . beep beep then hit answer
or just set your fax to answer on the 6th ring.
or purchase a dedicated phone line for faxes.
who uses faxes any more.
May 12, 2008 | Philips FaxJet 375 Plain Paper Inkjet
Installation of jetfax 335/356
What is your question?
Hook the phone cord to the LINE port of the fax machine.
Feb 21, 2008 | Philips FaxJet 375 Plain Paper Inkjet
Motorola Mobility W375 Cellular Phone Logo
22 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
