Question about Maytag Neptune FAV6800AW Top Load Washer
No hot water for a Maytag topload washer
I can not get any hot water when I use a hot water wash on my Maytag toploader washer, model LAT6914AAE. The cold water does fine.
  • Anonymous Mar 15, 2014
    With the temperature set to cold, only hot water will come out. Top load Maytag washing machine.
    Scholar:
  • 196 Answers
Turn the water off and disconnect the hot wat hose from the spigot and the machine. There should be a screen filter in one end. Check to see if the screen is clogged. If it is then replace it. If not then replace the water valve
Posted on Jan 13, 2008
My maytag topload washer overfilled,
It isn't a sensor problem, it sounds more like your water level tube has pulled loose. This is attached to the outer drum itself. You can see it when you remove your front cover to the right of the outer tub. This tube uses the pressure generated from your tub water level to push air up to your water level selector, which has a rubber membrane that flexes and closes 2 contacts as the water level makes the rubber expand. If that tube is off, the water will just keep running.
Mar 18, 2010 | Maytag MAV3905EWW 13 Cycle Washer
How can we troubleshhot a Maytag toploader that
You probably have something stuck in the drain pump. You will have to remove the hoses from the pump to extract it.
I can not be more help without a model number. Maytag builds several styles of top load washers. They all access differently.
Aug 30, 2009 | Maytag Washing Machines
Washer will not spin
Sounds like it could either be an electrical problem, with the signal from the timer control board getting to the gear box,,, or it could be the gearbox itself.
Mar 12, 2009 | Maytag 22 Cycles Topload washer, SAV365Z
Model mav6000awu has a sound of water rushing when machine finished filling and running.started doing this recently.
most maytag toploader mav did have that sound if it drain & spin your ok i have the same washer and it has the same sound & work fine that washer will only last about 10 years (i work for maytag )
Feb 18, 2009 | Maytag Washing Machines
Washer won't fill
First take off the fill hoses from the washer, make sure the screens on the washer valve are not clogged. Next heck nd make sure you have water coming from the hoses. Finally if still no water. you may ned a new fill valve. Hope this helps , Dave www.washermd.com
Dec 22, 2008 | Maytag HAV3460AWW Top Load Washer
Not able to do hot washing
My LG Toploader (wft753a) has a cold and a hot inlet, and the mechanism inside the machine simply turns the flow from each tap on and off. There is no internal heating element in it.
Nov 22, 2007 | LG WFT1071TP Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
230 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
