Question about RCA 257003 Remote Control
My remote control for my Spanish TV Technimagen has broken. Can you fix it please and what will it cost
Remote is set on spanish I need English
Language selection is made during initial setup of the TV. The remote has nothing to do with language selection.
Nov 20, 2013 | Coby TV Remote Control
Zenega cd 1004is remote control with Zee dish tv connection my remote broken it was 4 year old i buy new one for same model from the dish tv dealer but it's not working please help me
please follow this instruction manual, they have 3 system for TURN on the device. Please select another different from the CODE and fix it.
God bless you
Oct 26, 2013 | Televison & Video
Spanish closed caption, can't get to menu mode w/o original remote.
probably there is not menu button on the front panel i gess1.
  • get the original remote control at www.andrewselectronics.com if available
  • or try to get phillips universal remote control available in any retail store.
  • finally turn off those lines
Apr 15, 2009 | Philips 25PT533S 25" TV
LG DVD Remote for controlling TV
I found the DVD LG DVS-8575N manual in spanish on http://safemanuals.com/user-guide-instructions-owner-manual/LG/DVS-8575N-_S
Procedure:
Press at the same time POWER TV and a code number.
TV - Code number
LG / Goldstar: 1 or 2
Zenith: 1, 3 or 4
Samsung: 6 or 7
Sony: 8 or 9
Hitachi: 4
Mar 20, 2009 | Televison & Video
My remote fell off my bed and fell apart and now doesnt work. its an rca tv 244889 remote control. can someone please help fix it. Thanx
You should be able to fix the remote yourself with a screwdriver. if the plastic has broken of the circuit board has broken all you can do is replace it im afraid.
Mar 10, 2009 | RCA 244889 Remote Control
TV in SAP mode and cannot remove. Lost original remote.
I had the same problem. You have to order a replacement remote with the MTS button (Multi Channel Sound)
Call RCA Support @ 1.800.338.0376 I believe the remote part number is RCR130TB1
Dec 22, 2008 | RCA 257003 Remote Control
My tv is on spanish how do i take it off
Spanish on the screen or Spanish through the speakers on some channels? If its the on-screen display that's in Spanish, you pick the language using the setup menu with the remote control. If you're getting Spanish through the speakers, you probably have turned on the SAP (second audio program) function. In some areas with a large enough population, SAP is often used to broadcast program audio in a different language. On channels with no SAP broadcast you don't hear any problems. The SAP function is usually controlled by a button on the remote and probably got pressed by accident.
Dec 01, 2008 | Hitachi 51F500 51" Rear Projection...
BROKEN IN TROBLE
If it is a direct tv remote they will replace it for a minimal charge. If it is a remote from the tv, the manafacturer will replace it within a year and if you bought an extended warrantyfrom a store most will replace it free of charge. Except circuit city. They wont help you not one bit
Apr 08, 2008 | Samsung TV Remote Control
Remote control sensor broken
it is best to take it to a shop should cost no more than 15 quid you can do it yourself but it is a bit fiddly and you can damage something else doing this hope this is some help the part should cost about a fiver
Oct 31, 2007 | Samsung TXN2730F 27" TV
Remote will not control TV (but will control other devices)
Your remote control could still be the problem. Try another Toshiba remote on your TV or try your remote on another Toshiba and see what happens. Don't ever look past the easy repairs.
Mar 16, 2007 | Toshiba 36AF53 36" TV
RCA 257003 Remote Control Logo
43 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
