Have tosbia p305d s8828 laptop, no video , blank screen , tried external monitor also has black screen, cannot enter setup , tried boot from cd rom and usb drive, no access, no beep codes,removed internal battery held down power button , tried f2,f8, f12 will not boot, con-alt-del no luck,removed and reinstalled hard drive and memory no change , was down loading PC Tools update wouldnot finish download or install, rebooted no video, any help would be appreicated,, deerwatcher007@msn.com
    Champion:
  • 206 Answers
Your MB is dead.
Do not try anymore
Posted on Nov 19, 2009
Samsung NP-RV510-A02ZA
The external monitor will run at boot up by default. Enter the bios and set boor sequence to boot from CD ROM first.
Jan 18, 2014 | Samsung NF310-A01 10.1-Inch Netbook (Titan...
My acer aspire one laptop 532h-2db blank screen . help me pls.
If there is still light on it there are two possible points of failure. But we need to isolate first if it is a hardware or a OS issue. To do this you need to try to boot to the BIOS.
> Restart the computer and tap on F2 continously until you see a setup screen or the screen saying loading system setup.
If is goes to the system setup, then the issue is with the OS. Try to boot to safe mode.
Restart the computer and then keep on tapping F8 until you get a black screen with white writings on it that says safe mode, safe mode with networking. Choose Safe Mode. If this works, you just need to reinstall the video driver.
If booting to the BIOS does not work, then the problem is hardware related.
Try to connect an external monitor and then press Fn + F5, if the screen shows up on the external monitor then you have a problem with the LCD screen of your portable. You need to have it replaced.
If It does not show up, you need to have the video card replaced on the laptop which is embedded on the motherboard which pretty much is the whole electronic component underneath your keyboard.
Unfortunately this means it will be more economical to buy a new laptop. 1.
Jun 28, 2011 | Computers & Internet
My laptop is running very hot and keeps turning off although the screen is not black but blank. I have a Toshiba Satellite L305d-s5881. Thanks!
The Toshiba Satellites were will known for heat problems, the bottom of the laptop needs to removed for access, the cpu fan, heat sink, must be removed for cleaning, when all dirt is removed including the fins. Clean thermal conductive grease off the heat sink and cpu ic, apply fresh and assemble, if not sure get a professional.
Jan 05, 2011 | Toshiba Satellite P305D-S8828 Notebook PC
Inspiron 1100,screen will not come on at all,is there a way to format the hard drive without seeing what you are doing?Also it will not boost from a XP disc to fix it.Last time i seen the screen it had 2...
You can hook the laptop up to an external VGA monitor and then power on, you should get video externally by default.
If you don't try pressing the FN + F5 key once.
If it wont' boot to the XP cd make sure the boot order is set to boot cd rom / dvd rom first in the bios setup page.
Let me know if you get stuck or have any other questions ;)
Sep 25, 2010 | Dell Inspiron 1100 Notebook
I can't use the wireless on mine satellite P305D-S8828
1. uninstall the wireless driver
2. restart ur system
3. now try to connect wireless
Dec 29, 2009 | Toshiba Satellite P305D-S8828 Notebook PC
My srceen goes Blank
first try booting the laptop and pressing the Fn key with the numerical ( numbered key ) that has a picture of 2 screens on it. This is for booting to an external monitor. you could also try adding an external ( pc monitor ) this will eliminate any motherboard Faults.
Secondly, the graphics chip driver may be corrupt or not installed correctly. if you have a restore cd, you could try booting the laptop, with the cd in the drive.
you can then try, to see if the settings in the bios are all correct, by booting/starting the laptop and pressing esc or F2 or delete immediately as the laptop starts. ** Be-Careful** what you adjust.
My suggestion is to look for. ** default settings tab** or load setup defaults.
these are the obvious things to try, before assuming that you have a faulty graphics chip or motherboard fault.
Mike @ compurepair.
Jun 12, 2009 | Acer Computers & Internet
How to install win xp in toshiba portage r200 laptop
This is resolved by installing Intel Storage Manager drivers through "F6" option on XP Setup. YOU MUST HAVE AN EXTERNAL FLOPPY DISK (A Drive)...as the Portege doesn't come with one...and XP does not support USB or CD ROM for this particular function.
Mar 18, 2009 | Toshiba Portege R200 Notebook
Repair installation
Sorry to cover the basics but you cant be too careful. have you set your bios to boot from cd? Also when the cd tries to load you should have to tap any key to go into it. If all these thing are covered you have two more likely faults. 1. Faulty Ram. 2.Faulty drive
Aug 14, 2007 | Acer Aspire 3680 Laptop
I need help fast.
Booting to an external USB drive depends on your BIOS but as far as your monitor goes have you tried plugging an external monitor into the vga port in back yet? It may be that your backlight is non-functional and an external monitor will give you the work-around you need.
Feb 25, 2007 | Toshiba Satellite M45-S2692 Notebook
Computers & Internet Logo
216 people viewed this question
David Payne
David Payne
