Question about Konica Minolta bizhub 350 All-In-One Laser Printer
C-206 Our printer has just come up with this fault code. It is a C300IF Help what has gone wrong?
    President:
  • Konica Minolta Expert
  • 347 Answers
C-206 this code means third tray lift up abnormality. call technical service representative.
Posted on Jun 21, 2010
My Peogeot 206 HDI has a diagnostic error code P14660. The engine turns but it doesn't start
that fault code is too high for a Peugeot 206 with OBD2
i checked all the Peugeot car forum sites for answers
on that code
P14660 no mention
PO4660 no mention
PO1466 no mention
need to start back old school diagnosis
fuel pump ... spark at plugs
this is the world list of all PO obd2 fault codes
http://www.troublecodes.net/pcodes
Oct 26, 2016 | Cars & Trucks
Peugeot 206 error code p14660
on that code
P14660 no mention
PO4660 no mention
PO1466 no mention
Oct 26, 2016 | Peugeot Cars & Trucks
My Peugeot 206 is revving high and doesn't seem to be going through the gears. What cd be wrong?
run the fault codes and look for a problem torque converter clutch solenoid / servo
check for TCM fault
Apr 18, 2015 | Peugeot 206 Cars & Trucks
My peguoet 206 1.9 is stuck in economy mode how can i tix this
Have the fault codes read. Replace faulty items. Use only
genuine items as replacement as non-genuine are not always compatible with the OEM fitted CPU units. This results in the fault codes not cancelling out.
May 18, 2013 | Cars & Trucks
Unlock security code for nokia 206
The default Nokia security code is 12345 unless it was changed.
Mar 10, 2013 | Cell Phones
Peugeot 206 XS Can't accelerate above 1000 rpm at any gear
The very first thing you need to do here is have the engine control module scanned for fault codes with an OBD2 fault code reader or scan tool. Once you have the fault codes then you can diagnose the cause by the fault code or codes received.
Mar 30, 2017 | 2003 Peugeot 206
Hi my 2000 peugeot 206 windscreen wipers keep coming and going they will make a few full moves then only go a bit and may take up to an hour to go back down and wont work then for ages i tryed changing the...
When you can't find any fault code in ecu log then in my opinion its the wiper motor that has gone. May be motor has a broken pinion which doesn't engage the wiper arms properly and causes the problem. Buy a used wiper motor from ebay and give it a try. I hope that it'll work.
Jan 11, 2010 | 2005 Peugeot 405
U2 fault on Sharp AR-206
Error code U2 in Sharp copier AR 206 shows error or failure of toner crimp you can try to solve by replacing toner crimp
Or by reseting the error code by fallowing procedure
press c intrrupt 0 ( zero ) intrrupt contoneously after pressing all the light on control will go off then press 16 then press start switch
your prob will 100% solve.
if any more prob pl inform
May 20, 2009 | Sharp Office Equipment & Supplies
Dashboard fault
I too have a Peugeot 206 - and has given me nothing but grief - mostly electrical.
The fact you are suddenly losing systems, and draining battery points to a short in the wiring loom - which is a common fault on pugs.
I advise you trace the wire from the rear heater to the fusebox (it's labeled in there). Use a cheap multimeter - pull the fuse out and check the wiring both to the heater (resistance to good earth) and the supply( check for 12V )with the switch on. You may end up undoing the loom cover in the engine bay - but check your feet area first for any damaged wires. Try wiggling the loom with the ignition switch on and in neutral to find the problem. Often just taping it up properly solves it.
Feb 04, 2009 | 1991 Peugeot 405
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
176 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
