Question about Kenmore Ovens
Kenmore Model #911 4298814, Serial #OA63016. Oven is taking forever to get hot and when it does, it burns the food.
SOURCE: kenmore oven
I noticed your question and I just experienced the same problem. Curious if you found the solution or not, since no one has posted one?
Posted on Aug 09, 2007
SOURCE: Oven bakes unevenly and burns food
I was ready to replace my heating element in my oven for these reasons. I stumbled across a solution totally by accident. I found an adjustment on the BACK of the knob for the overn temperature. Made the adjustment there and have had no more problems. I have a Kenmore stove and had no idea there were adjustments on the knobs themselves.
Posted on Jan 05, 2008
You wrote- "Recalibrate the controls". How?
Posted on Apr 21, 2008
  • 147 Answers
SOURCE: large yellow flame, not cooking food thoroughly
I think ill give it a try for you. The gas lines come in thru you cutoff valve then thru you gas valve and on to the burner. right before the burner you will see a bell shape fitting. The gas line is in the center of the fitting and there will be some opening around this fitting That fitting has dust clogging it up. This is where the gas mixes with the air Turn your oven off and blow this fitting out.
Posted on Oct 25, 2008
SOURCE: Oven not working properly
I just solved this problem with my GE gas range. I waited forever for the oven to warm up. The igniter would glow, light the burner and burn for a minute or so and go out. It would repeat this process till oven reached operating temp, which took forever. Problem is in the igniter. It may be glowing, but it is not letting the gas valve stay open, because it is not hot enough to create resistance in it to keep gas valve open. I had replaced the thermostat thinking it was the problem. The good part about it was I could take it back because my buddy works at supply house. Once the igniter was replaced, the oven fired up and stayed lit till operating temp was reached. It will also hold the oven temp much better. Oh yea, the igniter will stay glowing while the burner is on. Hope this helps.
Posted on Nov 29, 2008
My Maytag MGR5750ADW oven will take forever to preheat. It does get hot, but the preheat light takes a very long time to go out. Food takes much longer to cook as the oven does not seem to get up to temp.
Hello there and welcome to fixya
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out. You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. To determine if the heating element is burned out, watch the part testing video at the bottom of this page. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Aug 10, 2011 | Maytag Ovens
Large oven burning food on top shelf when in fan assisted mode
Always cook food in the middle of the oven. Assuming this is an electric oven, there is a heating element up there that will cause burning of food, much like a broiler works.
If you must cook that high up in the oven, then cover the food your cooking with foil.
Dec 16, 2009 | Kenmore Ovens
Oven is burning food and seems too hot
HI. the oven temp sensor is malfunctioning. have it inspected for damage. check the wires leading from the control to the sensor for cuts and damage as well. replace the sensor if these issues with heating persist.
Sep 20, 2009 | Ovens
Wont heat past 200 degres
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 | Ovens
Kenmore oven lower element sporadically heating.
Kenmore 30425 Oven will not reach target temp
the ignitor is moast likley bad, look for a hot spot on the ignitor showing a open on the filament.
Dec 25, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Nov 29, 2008 | GE JGRP20 Gas Single Oven
Oven gets too hot
Thermostat needs to be replaced.
Apr 10, 2008 | Ovens
When foods are burned, soggy, or baked unevenly, it generally means heat isn't being distributed evenly throughout the oven, its escaping out the door or the controls are out of adjustment. 1) Remove any aluminum foil from racks or the bottom of the oven. 2) Check the door gasket and, if necessary, have it replaced. 3) Be sure nothing is obstructing the vent. 4) Reposition the oven racks so baking pans aren't too close to the heat sources. 5) Check your baking pans. If they're dark, they may be burning your food. Reduce temperature by 25 degrees F when baking in dark metal or glass pans. 6) Recalibrate the controls.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
185 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
