Question about Nokia 6500 Slide Cellular Phone
I cant work in my phone
I can switch on mY nokia 650slide, but i can't work in my mobile , when I switch on after 2 sekonds my phone dont work...please help me ...:D
I got a nokia 2220 from saudi arabia and now im in the u.s. and its not working with either of the sim cards, i dont know why, it cant find the operator, how can i fix this?
Hi you can unlock it by unlock codes..as you say you dont know your provider then you can unlock it without the sim card..here is the instructions about how to unlock your mobile
1 - Switch on your Nokia 2220 Slide without any sim card.
2 - Don't bother as to what is displayed on your Nokia 2220 Slide.
3 - Compose #pw+CODE+1#.
4 - The Nokia 2220 Slide would then display the message "SIM Restriction Off" and will be unlocked!
and to get codes you can try theunlockspot and get unlock codes and unlock your mobile..
Jul 31, 2011 | Nokia 2220 Cell Phone
How to format 5130
need the code to flash for Nokia 5130 c-2
Aug 22, 2010 | Nokia 5130 Cellular Phone
My nokia n72 asking me password
You need to format if you dont know it.
How to Format Nokia N72, N73, N81, N95, NSeries Mobile Phones. Method 1: Three Finger Reset for Nokia Phone1. Switch off your Nokia phone.
2. Hold down the following three keys, Green (call answer button) * Key, and Number ‘3? key.
3. While holding these buttons, press the power button and switch on the phone.
4. Wait for message ‘Formatting’ to appear on the screen and release all keys once you see that message.
Method 2: Hard Format of Nokia Mobile Phone1. Switch off your Nokia phone
2. Now Press following key sequence *#7370#
3. Enter Default lock code is 12345.
4. While holding these buttons, press the power button and switch on the phone.
5. Wait for message ‘Formatting’ to appear on the screen and release all keys once you see that message.
Method 3: Soft Reset of Nokia Mobile Phone1. Switch off your Nokia phone
2. Now Press following key sequence *#7780#
Please Note: The Above Nokia Phone Formatting method will erase all your Phone data. So do backup before proceeding for Formatting
May 15, 2010 | Nokia N72 Cellular Phone
I have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
It ll work . you dont need to go 4 the firmware v5.05
If ur phone restarted 3 or 4 times and switched off automatically. Try this
method
1] Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu
[default security code:12345]
{i know most of people have done this thing,but remember u have 2 go
with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]
between 470kb - 499kb.
Now surely ur 3110c working fine about 5
months.During these time u can
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime.
but remember below DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times
and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Nokia 3110 Cellular Phone
My phone cant finish restating/opening
REMOVE MMC BACK UP OF ALL UR DATA FROM PHONE MEMORY INSTALL NOKIA PC SUITE IN UR PC AND DOWNLOAD UPDATES FOR NOKIA MOBILE FROM NOKIA.COM INSTALL IT AND UPDATE UR MOBILE ONLINE.IT WILL FORMATE UR MOBILE AND RESET UR CODE TO 12345 AND ALSO fix ALL problem
do restore factor setting form setting menu it solve ur problems or backup ur data format ur phone use *#7370# code it remove all virus and corrupt file
i guarantee my solution is always right
plz dont forgetme to rate on fixya (blue line)
Nov 08, 2008 | Nokia 6270 Cellular Phone
Can't switch on my Nokia 6233
my nokia 6233 mobile cant swich on my friend tell me a mobiles flash software and mobile swich on automaticly. please help me
Jul 09, 2008 | Nokia 6233 Cellular Phone
Nokia n81 8G
*#7780# (*#rst0*) - This will soft reset your phone. It is different from *#7370# because all data, like contacts, calendar and notes, are not removed.
It will only reset the phone settings, such as profiles, themes and shortcuts.
The default lock code is 12345.
or try this(But it will fully format your phone)
Method 1:
1. Switch off your Phone.
2. Hold down the following three keys, Green (call answer button) * (Star) Key, and Number '3' key.
3. While holding The Three buttons, press the power button for switch on the phone.
4. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 2:
2. Now Press following key-*#7370#
4. While holding All of the buttons, press the power button for switch on the phone.
5. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 3:
Please Note:
The formatting method will erase all of your Phone data.
Please take a backup before you Format.
Jun 02, 2008 | Nokia N81 Smartphone
Nokia 6030 - Couldn't switch on the mobile
hi dude,
i think its a problem with ur power switch, or rubber inside it !
Check it out .. I think it dont cost to check it !!! It dont cost too much also to repair it !
send me a feedback and rate my solution.
SAJAN(sajwhat_2003@yahoo.com/sajwhat@hotmail.com)
May 13, 2008 | Nokia 6030 Cellular Phone
Nokia 6500 Slide Cellular Phone Logo
18 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
