Question about Kenmore 54501 Dehumidifier
Have a manual for Models MDF 30AE - 5OAE - 40AE & 65AE EVERY ONCE IN AWHILE THE "P1" LIGHT COMES ON....THERE IS NOTHING IN MY MANUAL IN REGARDS TO THIS. WE UNPLUG IT PLUG IT BACK IN AND IT RESUMES AT WHATEVER HUMIDITY IT IS SET FOR. WHAT IS THE "P1"??? THANK YOU CAROLINE
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: The dehumidifier is a MDF-65AE. The top area above
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Posted on Aug 13, 2011
Power button is blinking on polar wind model MDF1-30AE dehumidifier?
The tank closes an interlock when it is reinstalled and operation is restored. The tank may not have been reinstalled in such a way as to close the interlock.
Sep 08, 2014 | Dehumidifiers
WHy does P2 code come on display for my Westpointe DeHumidifier
I could not find the user manual for your particular model but the manual for the MDF1-30AE model indicates that the P2 code is when the bucket is full or not in the right position.
If you have already emptied the bucket and the error remains I would recommend checking around where the bucket goes as there should be a switch that gets pressed by the bucket when it is in the proper position.
My guess would be that when you are putting the bucket in it is not properly hitting this switch.
Source: User manual for MDF1-30AE
Oct 25, 2012 | Midea MDF1-40AEN3-BA5 Westpointe, 40 PT,...
The dehumidifier is a MDF-65AE. The top area above the storage water bucket is freezing and the water leak's all over the floor?
heatman101
Jul 02, 2011 | Kenmore Dehumidifiers
I purchased danby dehumidifier less that 1 year ago and p1 is on most of the time. What can I do?
According to your Owners Manual:
P1 is part of a normal function of your dehumidifier. When your compressor is working it will build frost on the evaporator coils. When there is enough frost on the coils the unit will go into a P1 deicing program. This deicing cycle will last anywhere from 15-45 minutes. Once complete it will automatically resume normal function. The cooler the room the more often this function will turn on.
If you think it's still staying ON to long, contact Danby Consumer Help 800-263-2629
Hope this helped you.
Apr 28, 2011 | Danby DDR607EE Dehumidifier
P1 buuton comes on
P1 is code for defrosting. Once it's done defrosting it should start operating
Dec 17, 2009 | Danby Dehumidifiers
Code on Top
I have another of their dehumidifiers, the MDF1-30AE. The first time the P1 came on, the unit stopped, because the filter needed cleaning. Recently P1 came on but the unit didn't turn off, and I had already cleaned the filter, so I phoned Midea customer service at 1-866-646-4332. The man told me P1 means it's in defrost mode and said to just leave it on and the P1 will eventually go away. It's been a while though....
Dec 01, 2009 | Midea MDC-45AE Dehumidifier
My model is DDR4009EE, after it run for a while, the display changed from RH to "P1",what does "P1" mean?
My Danby DDR657EE shows P1 periodically also. So, I called Danby.
Danby's Consumer Help Line (1-800-263-2629) is always busy. So, I called their General number: 419-425-8627. The receptionist transferred my call to their Service dept. My call was answered in 2 minutes.
The Service Rep. described the following code for my dehumidifier model (DDR657EE):
P1 = Defrosting: the unit will go into Defrost mode periodically to ensure that the parts are working at the right operating temperature. It should be in Defrost (P1) mode for only a brief period of time. If the unit is in Defrost (P1) mode continuously for a couple of hours (or more), then you should call Danby Service for further assistance.
He had no documentation of a P2 code for my model.
He also described other General Codes (applicable to most Danby Dehumidifier/Humidifier models):
E1 = Not enough water
E2 = Not draining
E3 = Water temperature too cool
E4 = Overflow Switch activated
E6 / E7 = Problem with Temperature Sensor
So, if you see P1 periodically (for brief periods), then it would be normal.
Also, here is a link to Danby's FAQ page for Dehumidifiers (which answers some common questions):
https://www.danby.com/faqs.php?cat=12
I hope that helps.
May 11, 2009 | Dehumidifiers
P1 error
Your question needs to be answered in 3 parts:
1) As per the manual for my Danby Dehumidifier (Model DDR657EE), the unit may not turn on immediately when powered On (it may take a several minutes). So, generally, it would be normal in your case.
2) Danby's Consumer Help Line (1-800-263-2629) is always busy. So, I called their General number: 419-425-8627. The receptionist transferred my call to their Service dept. My call was answered in 2 minutes.
He also described other General Codes (applicable to most Dehumidifier/Humidifier models):
E2 = Not draining
So, generally, if you see P1 periodically (for brief periods), then it would be normal.
3) Since your unit keeps running (continuously) and there is no water in the bucket, then you should call Danby ServiceI for additional assistance - it seems defective for this reason.
I hope that helps.
Oct 31, 2008 | Danby DDR2506 Dehumidifier
P1 and P2 error codes
E2 = Not draining
I hope that helps.
May 25, 2008 | Danby DDR2506 Dehumidifier
Kenmore 54501 Dehumidifier Logo
589 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
