Question about Car Audio & Video
I have relocated and need to enter in my present address. Unable to delete old address so that I may enter new destination points starting from my new address
    Top Expert:
  • Car Audio & ... Master
  • 79,865 Answers
What are we working with here? whatever it is need make and model number
Posted on Nov 18, 2009
How to put in address to pick up someone?
Would like to know what model you have, but have you tried typing the address in as a new destination? or try adding it as a POI(points of interest)? You may need to remove some old address's and or POI's to make more room if you can not enter it. Thanks for using FixYa
May 28, 2011 | Magellan GPS
Hi I recently purchased a garmin nuvi 1410 and tried programming several sites in. however when i left one site and wanted to navigate onto the next, it kept trying to bring me back to the previous site...
Hi, there are 2 possible solutions to your problem.
1. Press WHERE TO and enter your first address. Instead of pressing GO press SAVE, at the bottom of the screen. This will save the site in your FAVOURITES folder. Repeat for each destination. Then when you want to go to one of these addresses just press WHERE TO then press FAVOURITES and select the address from it. If you're going to use these addresses fairly often then this is probably the best solution. When you reach your destination sometimes the satnav doesn't realise you have as, for example, you could be on the wrong side of the street to where it expects you to be or the satnav could be out by a few yards. When this happens it tries to get you to go back. To stop this press MENU at the bottom of the screen and then press STOP. (The STOP icon only appears while the satnav is trying to take you to a location) Having done this you can then select your next destination.
2. The second option for solving your problem is to enter your last destination first and press GO. Then enter your second last and when you press GO again it will ask you if you want to set this as a VIA point. Select YES. Add each destination in turn making them all VIA points. When you do this the satnav will take you to the last via point first and then each of the others on the way to your destination. The advantage of this method is that you don't have to set destinations when you're traveling. As soon as you reach one it adjusts to take you to the next. The disadvantages are that if you want to go to the same destinations again you need to re-enter all the information again. Also if the satnav thinks you have not reached your via point, when you have, pressing STOP cancels the whole route.
Entering the places into FAVOURITES is probably the best option. Note once they're in FAVOURITES you can rename them if you wish or you can delete them. You'll find details of how to do so on page 12 and 13 of the manual available in Adobe Reader format from http://static.garmincdn.com/pumac/nuvi_1100_1200_1300_1400_OM.pdf
May 09, 2011 | Garmin Nuvi 1410 Car GPS Receiver
HOW DO I DELETE ADRESSES FROM BINATONE G350 SAT NAV
You can only delete the Recent Destinations and destinations in the Address Book, the Sat Nav will still store destinations you have entered and as new ones are entered the older ones will fall off the system when maximum is reached.
Apr 03, 2011 | Toymax Binatone Carrera X350 Car GPS...
AVIC-F700BT Destination Menu-Address isn't lit up. Can't input.
It turned out that one of the harnesses wasn't connected...:-) I only noticed when I took the unit out and checked the connections.
Jan 10, 2010 | Pioneer AVIC-F700BT Car GPS Receiver
How do I delete stored faxed numbers (speed keys)of the fax machine? How do you change a speed key title?(let say I fax documents to this fax number everyday: I stored the fax number under the name "Team...
From Ricoh Aficio MP2550 manual:
Delete destinations registered in the LAN-Fax Address Book:
numb01.gifOn the [Start] menu, point to [All Programs], [LAN-Fax Utilities], and then click [Address Book].
The [Address Book] dialog box appears.
If LAN-Fax Driver has already started up, click [Edit Address Book...].
numb02.gifClick [New/Browse...], and then select the CSV file containing the address list to be edited.
numb03.gifSelect the destination you want to delete so it is highlighted in the list.
numb04.gifClick [Delete].
numb05.gifClick [Yes].
numb06.gifClick [Close].
numb07.gifIf you made changes to a destination, a confirmation message appears. To save the changes, click [Yes].
If you do not want to save the changes and want to quit editing, click [No].
To return to the editing display, click [Cancel].
The confirmation dialog box does not appear when you have not made any changes after starting Address Book.
You can download the manual (HTML or PDF/ZIP versions) from here:
http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/mp33/mp33en.htm
Jul 29, 2009 | Ricoh Aficio GX5050 GelSprinter InkJet
Delphi Nav300 - Delete home
Just enter in your new home address for a new destination and when saving to favorites you are given the option of "Home: Yes/No" change this to yes and save!
caz
Mar 12, 2009 | Delphi NAV300 Car GPS Receiver
HP Deskjet F2200 All-in-One SCAN green light flashes but does not scan
Error: “HP Cue Scanning Flow component has encountered a problem and needs to be closed”.
The problem is caused by HP software not installing the file path to the scanner correctly in XP, so if you run a registry cleaner such as RegCure it will delete the file path.
OS: Windows XP.
If you encounter this error message please follow the steps below:
1. Go to registry by clicking on Start/Run then typing in regedit and hitting enter.
2. Go to HKEY_ Local_ Machine\Software\Hewlett-Packard\DigitalImaging\
3. Click on the Digital Imaging Folder and in the Right Hand Side Pane and check if the String Value “ProfileWritePath” is present and Value is set to %APPDATA%\HP\Digital Imaging\Data\Destination
4. If the Sting Value is not present right click and then click on new and then click on String Value Name it as “ProfileWritePath” and then right click on that and click on Modify and make sure that the value is set to “%APPDATA%\HP\Digital Imaging\Data\Destination” and close the registry editor.
5. Then go to My computer C:\Documents and Settings\All Users\Application Data\HP\Digital Imaging\Data and check if the Destination folder is present. If not create a new folder and name it as “Destination”.
6. If you are unable to locate the Application Data folder under All users, click on Tools and then click on Folder Option. In the Folder Options Window click on the View tab and under Hidden Files and Folders make sure that “Show Hidden Files and Folders” is checked and then click on Apply and then click on OK..
7. Then Make sure that the same that the HP\Digital Imaging\Data\Destination folder is present under all user profiles Application Data folder.
8. Run Regcure and after the scan check the file/path errors and tell it to ignore the HKEY_LOCAL_MACHINE\SOFTWARE\Hewlett-Packard\digitalImaging ProfileWritePath= C:\Documents and Settings\ (whatever your file path to the destination folder is)
Now it should run flwalessly even after you run regcure.
For other registry cleaners I'm sorry but you will have to find out how to tell your cleaner not to delete the erroneous file/path error.
Graham Sept 13th 2009.
Oct 14, 2008 | Office Equipment & Supplies
UNABLE TO RESET MY HOME LOCATION.
I had this problem and solved it by reseting the unit - Power+Find
May 03, 2008 | GPS
Deleting wrong home address
Tap on the screen, go to "Change Preferences",then browse to "Change Home Location" and set the correct location.
Feb 29, 2008 | Tomtom ONE GPS Receiver
Magellan Roadmate 360 reset
Called Magellan tech support, According to them you can't delete previous addresses, the unit will just override old destinations as you put in new ones.
Dec 01, 2007 | Magellan RoadMate 360 GPS Receiver
Car Audio & Video Logo
22 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
