Question about Cameras
Date/time setting date/time
  • 685 Answers
All digital camera have the date and time setting, and they often have a daylight time setting so you can just switch that on and off at the appropriate time s of the year. Some will let you put the date and time on the fac of the picture too, by this is very dependent upon the make and model of the camera.
Posted on Nov 21, 2009
Where is OK button when setting date and time
Correct my date and time to update my phone ' Windows ...
www.windowsphone.com/.../correct-your-date-and-time...
Windows PhoneIf you're having trouble installing a Windows Phone update, correct your date and time settings manually.
How to Change the Date in Android ' Chron.com
smallbusiness.chron.com > ... > Setting Up a New Business Basics
Android phones normally pull the date and time from the Internet, but if there's a problem with the signal ... Click the "Settings" button to open the Settings menu.
2013 Models - How to Set the Date and Time on your ...
? 0:52
https://www.youtube.com/watch?v=jTSZwCLSiTk
Dec 4, 2012 - Uploaded by Panasonic Canada Help
In this video we will explain how to Set the Date and Time on your Panasonic Cordless telephone, models KX ...
How to Set the Date and Time on Your iPhone - For Dummies
Dec 26, 2015 | Lands Phones
How do i set the time on a pantech p5000?
Date and Time Settings Pantech Marauder
Date and Time Settings - Pantech Marauder™ [Device-Specific Instructions]
  1. From a home screen, select Apps (located in the lower-right).
  2. Select Settings.
  3. If applicable, select System (appears in Starter mode only).
  4. From the SYSTEM section, select Date & time.
  5. To use network-provided values, select the following:
    Enabled when a check mark is present.
    • Automatic date & time
    • Automatic time zone
  6. If not using network-provided values, perform the following to adjust date & time manually:
    1. Select Set date.
    2. Adjust the date then select Set.
    3. Select Set time.
    4. Adjust the time then select Set.
    5. Select Select time zone.
    6. Select the time zone.
  7. Select Use 24-hour format to enable of disable.
  8. To change the date format:
    1. Select Choose date format.
    2. Select one of the following:
      • Regional (6/7/2013)
      • 06/07/2013
      • 07/06/2013
      • 2013/06/07
Nov 01, 2015 | Pantech Cell Phones
Can't find how to change the date or time
System
Setting the date and time
To set the date and time, tap
APPS
Settings
Date & time
Tip
: If you travel frequently or live in
an area that uses daylight saving
time, and have mobile network access, activate
from this menu. Your tablet will set the date and time based on information
it receives from the network
Mar 11, 2014 | Acer Iconia A1-810
Setting time, date on power book g4
I'm taking it that you are running system 10 so go to system preferences under the apple menu, then go to date and time under System. Go to time zone and allow the time zone to be set automatically and then go to date and time and set the date and time automatically. If you want to set the date yourself you can uncheck the set date and time automatically and then select the date and then the time using the up and down arrows. Hope this helps.
Dec 06, 2012 | Computers & Internet
How do you clear memory, and set date and time 712c
To delete all the records :
  1. Press the MEMORY button
  2. And while holding the MEMORY and the START/STOP button simultaneously for more than 2 seconds all records will be deleted.
To set date/time :
  1. Press the Date/Time Setting button to adjust the date and time (the year flashes on the display)
  2. Press the MEMORY button to advance by increaments of one year and press the Date/Time Setting button,
  3. Press the MEMORY button to advance by increaments of one month and press the Date/Time Setting button,
  4. Press the MEMORY button to set the current day and press the Date/Time Setting button,
  5. Press the MEMORY button to set the current hour and press the Date/Time Setting button (the time is set using AM/PM)
  6. And finally, press the MEMORY button to set the current minute and press the Date/Time Setting button.
Jun 14, 2010 | Omron Healthcare Omron Hem-712c 712 Blood...
Setting the time and date
To set the date, make sure that you are in Rate Set. type in the date such as August 3, 2010 would be entered as 08.03.2010 then press the date time key. This will set the date. To set the time type in the time such as 4:20 PM would be entered as 16.20 then press the date time key and this will set the time.
Feb 02, 2010 | Sharp EL-1197PIII Calculator
Current time and date samsung tocco lite
On the main menu select Settings, then Time & Date.
Set Time zone updating to Manual.
Then SCROLL down i.e. drag the menu upwards (this is the bit that many don't realise.)
Then you will be able to set the time & date.
Sep 20, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
How do i set the time on my nokia 2630
Select Menu > Settings > Date and time. Select Date and time settings to set the date and time. Select Date and time format settings to set the formats for date and time. Select Auto-update of date & time (network service) to set the phone to update the time and date automatically according to the current time zone. Hope it helped...
Aug 05, 2009 | Nokia 2630 Cellular Phone
How do you set the date on an LG KS360
http://www.o2.co.uk/deviceinfo/device-pdfs/lgks360eng.pdf
Manual
Hope it helps.
Most cell phones get the info from the provider based on your triangulation.
It is in the Settings Menu.
Under DATE & TIME
More detailed Instructions....
Changing your date & time
You can set functions relating to the date
and time.
1 Press Menu or and select Settings.
2 Select Date & Time and choose from the
list below:
Set date - You can enter the current date.
Date format - You can set the date format.
(YYYY/MM/DD, DD/MM/YYYY, MM/DD/YYYY)
Set time - You can enter the current time.
Time format - You can set the time format to
either 24 hours or 12 hours.
Auto update - Select On, the phone will
automatically update the date and time.
Jan 03, 2009 | Cell Phones
Ho w to set the date and time
Go to the link below. You need adobe acrobat to read. THere is a section in the manual called "Adjust Date & Time"
For Date:
Put Calculator on RATE SET
Press Time/date key: enter the date using a decimal between the month, day and year (all 4 digits) please the date/time button. It should reset. (Exmple: 01.16.2009)
For time:
Leave Calculator on RATE SET
Press Time/Date key until time shows up. just like date, press the hour then the decimal then the minute. (Example if the time is 10:15 you enter 10 . 15) Press the Time/Date Key and the time is set.
This link is the manual:
http://www.sharpusa.com/files/cal_man_EL1750PIII.pdf
Jun 04, 2008 | Sharp EL-1750PIII Calculator
Cameras Logo
566 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
