Question about Southbend SLEB/20 Stainless Steel Electric Double Oven
Trying to find Thermostat on the for the top oven not heating up
  • 1,250 Answers
Call Rick at Restaurant Parts and More. 1-888-814-1110.
Be sure to have model and serial numbers to get the correct part.
Hope this helps.
Posted on Nov 21, 2009
2 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: zanussi electric double oven. Top oven not working.
It sounds like a faulty thermostat, because when you turn the thermostat on it should supply the oven element and the neon light, so even if the element is faulty, the neon light should still come on regardless of the element working or not.
Hope this helps.
Posted on Feb 10, 2010
I have a smooth top kenmore oven model #92172300 when you use the oven it gets to the temperature but then its shuts the heat off i had heating element tested and its good please help
The thermostat controls the heating element. If it comes to temp you know the element is OK. The thermostat can be tested. or just replace it.
Nov 18, 2016 | Kenmore Ovens
Bottom oven isn't heating to desired temp. Considering swapping the heating elements to see if one is faulty - thoughts?
try thermostat first. verify heating elements operational, if so check if tstats are same. swap if so, If not jump out tstat and see if higher temp achieved.
Sep 20, 2015 | Thermador PODC302 30" Double Electric Wall...
Early 1960's Frigidaire 24" Double wall oven not heating
Hello Chris Hammond, thanks for your post!
Based off the information you have provided it sounds like a potential problem with your connector for your element within your Frigidaire wall oven. I would recommend reaching out to a professional technician for proper diagnosis repair to help avoid any unnecessary part purchases. Best of luck! -Matt
Nov 07, 2014 | Ovens
Oven not heating up properly
Go to Lakeland and buy there oven thermometer - it is about £5. If that confirms the oven is not working as per the readings on the dial, i.e. 160 on the oven control dial is not shown on the thermometer, check the thermostat sensor. It is located at the rear top right hand side of the oven above the heating fan cover. It is about 6 inches long and thin, connected by an even thinner wire. It can be very brittle so treat it with care! It should be bright clean and shiny, if it is greasy and black, that may be your problem. Again from Lakeland buy there brush on oven cleaner and follow the instructions. I use it on all of the oven including the stay clean panels. Brush the liquid on and leave it for as long as necessary. The liquid gradually dissolves all the grease. You can keep reapplying and then when you are satisfied it is clean, wash it off and then dry it with kitchen towel as carefully as possible. try the oven again and see what happens. If you need a new thermostat, try espares and you will have to take the whole oven out of the kitchen carcass and then remove the top and rear panels to do the job.
(The thermostat may just be lazy, so if the Lakeland thermometer shows only 10 degrees out all through the range, I would live with that. Just make adjustements when you use it. My top oven is 15 degrees out).
Dec 17, 2010 | Stoves 720EF Electric Double Oven
Oven will not heat up but stove top works
Hello there
Please read the entire solution to see which best decribes your problem ok
first.
If neither the oven nor the broiler heats, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)," push the knob in and try heating the oven and broiler again. If they still don't work properly, you probably have a defect in the thermostat, selector switch, or common wiring. Note… If the oven doesn't have a separate bake/broil/etc. selector switch, the problem is often with the thermostat. It's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem with either of these,
Jun 27, 2010 | Kenmore Ovens
Zanussi electric double oven. Top oven not working.
Hope this helps.
Feb 10, 2010 | Ovens
Heating element
the chances are the top oven thermostat has gone and may need replacing. also check on any selector switches relating to the top oven unit they can burn out on the contacts. there is no seperate fuse.
Jan 20, 2008 | GE JKP45 Electric Double Oven
Electric wall oven will not heat up
This is ovenmad from the previous post. I had a repair guy come out and he found the problem to be the Safety Thermostat. When tripped, this allows everything to work on the oven except the elements. He did not have the part with him so will return in 6 days to replace it. That should solve the problem. No idea why it tripped. The safety thermostat is located on the rear of the oven so we will have to pull out the oven to replace the thermostat. Again, this was a Frigidaire Single Electric Wall Oven made in 2004. Hope this helps somebody else.
Dec 22, 2007 | Frigidaire FEB27S5A Electric Single Oven
Southbend SLEB/20 Stainless Steel Electric Double Oven Logo
88 people viewed this question
Top Southbend Ovens Experts
Dennis Boxerman
Dan Webster
Dan Webster
Paul Bade
Are you a Southbend Oven Expert? Answer questions, earn points and help others
