Question about HP Officejet 5610 All-In-One InkJet Printer
CARTRIDGE ERROR....ALIGNMENT HELLO...I JUST REPLACED THE INK AND THE PRINTER IS READING "CARTRIDGE ERROR" SOMETHING REGARDING THE ALIGNMENT. THANKS
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
One of your cartridge is not working and need to be replaced
if you have the old ones check tha cartridges to find the broken one
and replace it with a new one or if you want you can refill an old one like this
and
Posted on Oct 30, 2010
How do I reset the printer to read ink levels as full on manually re filled cartridges??
Remove the Cartridges and the Printhead. When you remove the Cartridges, you can find a latch on right side on the Cartridges slot that you need to lift and lift the Printhead.
Turn off the printer and Turn on
Take a link free cloth and clean the electrical ( golden ) contacts on the printhead and Cartridges. and install the Printhead and Cartridges.
The printer will go through alignment process and it should say alignment successfull. This displays the ink level
Regards,
Sean
Oct 18, 2012 | HP Officejet 6500 Wireless All-in-One...
E5 what does this mean and how can I get out of it?
Hello and welcome to FixYa!
Error E5 means that the ink cartridge is not installed or the ink cartridges is not installed properly or may be
non-supported ink cartridge is installed.
It may also mean that if you have both cartridges in printer one or both are failed. To solve this problem check print cartridges and replace first color, if not help replace black ink. Install the appropriate fine cartridge and also If the lines are misaligned or resulting output is not satisfactory, carry out the fine cartridge alignment and make it aligned.
I hope this solution helps you
Don't hesitate to let me know if you want any further assistance.
Thank you for using FixYa!
Jul 12, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Printer is not registering new cartridge, which is full and an HP "02" . Printer was out of cyan blue for a while, printing in black and white, then replaced it. Ink is flowing, checked with...
Hello.
New cartridges that are not HP brand can sometimes give these errors. If they are HP brand then the issue is with the sensor that reads the cartridges "chip" The ink levels are not read like the fuel in your car, there is a page counter on the cartridge and when it hits 0 then it assumes there is no ink. So the issue seems to be it is not reading the chip correctly. Try removing all the cartridges. turn the printer off for 10 mins and replace the cartridges 1 by 1. This can sometimes correct the issue. If not the pins that read the cartridges chip can be checked for dirt of dry ink that may be interfering with the pins touching the cartridge. these pins are in the Cartridge holder for each colour, inside the printer. use a torch to see them properly.
Good Luck. Regards GM
May 26, 2011 | HP Office Equipment & Supplies
I have HP Officejet 6310 All-in-One I replaced black ink cartridge No 98 just recently, and since then I have problems to print anything. When I try to print I get this message on printer?s...
hello, some of the time the color ink cartridge can cause the problem, especially if its a refilled ink, but at same time, i do know some of the new inks right out of the box will fail. so try with a new color cartridge first.
Sep 30, 2010 | HP Officejet 6310 All-In-One InkJet...
Hi, replaced ink cartridge on Lexmark X2470. Now it goes as far as the "print alignment page" and freezes. Will not print the alignment page or any other page for that matter. Thanks.
Hello. The ink cartridge may not be seated properly in the carrier. Remove the cartridges from the printer. Close the cover. Clean the nozzles using a damp paper towel. Unplug the printer from the power source. Plug it back in after 10-15 seconds. When the printer asks for the cartridges, reinsert the cartridges. Also, make sure you're using the compatible ink cartridges for the printer. Let it print the alignment page all the way without cancelling it to align the cartridges properly. Hope this helps.
Mar 22, 2010 | Lexmark X2470 All-In-One InkJet Printer
Hi I just replaced the ink cartridge on my 210c printer and it still reads near empty on all. Is there something I need to do to reset? Wendy
If you have already run the deep cleaning utility and alignment utility, it sounds like you may be using aftermarket/refilled cartridges. The nozzles and ink sensors may be clogged.
To clear the sensors and nozzle, install new OEM cartridges, run deep cleaning a number of times (at least 3 times), and then the alignment utility.
Aftermarket/refilled cartridges do not always meet the manufacturer's specifications for quality. Try cartridges from LDproducts.com for your printer. I've never had a problem with their aftermarket cartridges.
Please rate this solution. Thanks.
Dec 15, 2009 | Brother MFC 210C All-In-One InkJet Printer
Will not print. color ink cartridge light keeps
..."Open the ink supply andgently move the ink cartridges to the left. Then reach in to the rightside and you'll find a small (1/2 x 1 inch) sponge. Push it down andoff/on the machine. try it now. or ...go to where I found out more than I should know about Canon's and where I got my quote...http://www.fixyourownprinter.com/forums/inkjet/39177 good luck.
Oct 21, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Rx680 epson ink cartridge error
I was changing my cyan cartridge and got this error. I thought for sure it was that cartridge. Tried a few things including pulling them all out and putting them all back in. Didn't work.
Finally, I found a place in the software that showed the info on all the cartridges. Turned out the light cyan was not reading. Took it out and rubbed the contacts with a pencil eraser. Voila! Problem solved.
Sep 21, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
Error message on HP 2800 business inkjet, message reads 1% ink left on brand new cartridge
View the user manual here. http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00449611/c00449611.pdf
go to page 60 and follow the instructions for replacing the ink cartridge, remember to have the printer on when you do.
Then go to page 62 and allign the print head automaticly following the instructions it gives.
This will re-callibrate the ink level on the printer and should read correctly for you.
Thanks
CompuFirm
May 27, 2009 | HP Business InkJet 2800 Printer
Dell 922 printer alignment problem-
try this...
Aligning Ink Cartridges Your printer automatically aligns the ink cartridges when they are installed or replaced. To verify your ink cartridges are aligned, you can print an alignment page. After you close the printer unit, press the Menu button. The alignment page begins printing. During printing, the operator panel display reads Alignment Page Printing. When complete, the message reads Auto Alignment Complete. Your ink cartridges are now aligned for optimal print quality.
You may also need to align ink cartridges when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridges:
  1. Load plain paper. For more information, see Loading Paper.
  2. Click Start® Programs or All Programs® Dell Printers® Dell Photo AIO Printer 922® Dell Printer Solution Center.
  3. Click the Maintenance tab
  4. Click Align to fix blurry edges.
  5. Click Print.
The ink cartridges align when the page prints.
If this helps you plz rate this fixya. Thank you kindly. If you need more help post it & I'll be glad to do what I can.
Feb 01, 2009 | Epson Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
96 people viewed this question
Seeker5211
Seeker5211
