Question about Sony Playstation 3 (PS3) Console
My psn connection strength is 100% always but it doesnt stay on for more than 10 mins and is logged off. I have surfed the internet and found out there are 2 ways to fix it. So as one said i turned media server off and i tried to get an update via internet but by the time the update finished it signed out so the update cant take place. After i disabled media server nothing changed, please help!
    Novelist:
  • 132 Answers
If you are connecting via Wifi instead of a cable this can happen. Wifi connections tend to drop connection or lose intensity.
I would recommend to you to connect it via ethernet cable directly to the router. This is the best way to ensure best communication between your PS3 and the router.
If you cant do that go into the Wifi Router configuration and try to check the configuration.
If you need assistance tell me the make and model of the router and I might be able to help you a bit further.
Hope it helped.
Posted on Nov 18, 2009
Will not stay connected to internet
This would depend on how you are connecting. If by a wireless router, check the signal strength, walls (especially thick or damp), objects with moisture like human bodies all drop signal strength because microwaves are absorbed by water. If the signal strength is good, check the routers logs by accessing the router's administration web page which usually has a statistics or log of past faults. If it is not the router or others using the router are not having the same issue. Then I'd require more information about how you are accessing the internet.
There may be software packages trying to access the Internet that are being blocked, which would block your connection.
The variables here are quite numerous.
Sep 18, 2012 | HP G60-235DX Notebook
Cant sign in to psn
Disconnect from your internet source, then reconnect. If it doesn't resolve itself, Sony is doing something to the PlayStation Network in your area and it will be down until they finish their changes.
Jun 06, 2012 | Sony Playstation 3 (PS3) Console
I recently had to reformat my hdd on my ps3 and now i can't play bfbc2. I manage to download the software update version 1.05 but it doesn't install it stops at about 13% with error code 80010038....
Yes, that's exactly the problem. It sounds like you attempted to download this when the PSN Network first went down or that 13% is actually BS and it's not downloading a thing. The PSN network is completely down and may be until the end of the month due to being hacked. That code is the error code you get (and I get) every time I tunr the ting on and it tried to auto log on.
May 10, 2011 | Sony Playstation 3 (PS3) Console
Can not log onto the PSN. error message 8002AD3D. I have relocated my PS3 to a different state and I'm using a NET40 wireless signal. The strength of the signal is stating 100% in the network settings....
Hi kdfrance
Please everyone that comes across my info take a few seconds of your time to rate my solution which you can select at the bottom of my answer Was this solution helpful? YES or NO :)... As i have taken time to answer your question the best i can Thank You......
Try turning off media server on ps3 Go into the PS3?s Settings menu and navigate to Network Settings - Media Server Connection disable it thats my first idea which could be causing the issue..Secondly unplug your modem/router for 15 sec then plug back in...THEN FOLLOW STEPS
  1. Select "Network Settings" under "Settings" in the home menu, and then press the "X" button.
  2. Select "Internet Connection Settings", and then press the "X" button. When a message stating that the Internet connection will be terminated is displayed, select "Yes", and then press the "X" button.
  3. Select "Wired Connection" or "Wireless Connection", and then press the "X" button.
  4. Select "Easy" or "Custom" and adjust settings as necessary. Follow the on-screen instructions to adjust the required settings.
Note: You should always choose Easy before going onto to adjusting the Custom settings. In most cases, the Easy settings will work and are set automatically so you won't have to search for information that could have been gathered automatically.
Hope this info was helpful cheers nikki
Jan 20, 2011 | Sony Playstation 3 (PS3) Console
Hi kdfrance
How to configure Remote access/VPN server role (using windows as my operating system)?
You can configure a server that allows remote users to access resources on your private network over dial-up or virtual private network (VPN) connections. This type of server is called a remote access/VPN server. Remote access/VPN servers can also provide network address translation (NAT). With NAT, the computers on your private network can share a single connection to the Internet. You can find a step by step guide here:http://technet.microsoft.com/en-us/library/cc736357(WS.10).aspx
Aug 15, 2010 | Belkin Computers & Internet
I been trying to connect to my ps3's playstation network. it was working fine but now it always says i havw been disconnected from psn right when i even try to get on. everytrhing else works fine, even my...
][#; There is a worldwide issue with PSN at the moment:
We're aware that many of you are having problems connecting to PSN, and yes, we're looking into it. Stay tuned for updates. about 1 hours ago via web SonyPlayStation
Mar 01, 2010 | Sony Playstation 3 (PS3) Console
Ps3 problem
#;'#;'#;'#'; There is a worldwide issue with PSN at the moment:
We're aware that many of you are having problems connecting to PSN, and yes, we're looking into it. Stay tuned for updates. about 1 hours ago via web SonyPlayStation#'#;'#;''
Un block blocked web sites my space facebook and any blocked web sites on a government computer
Total Internet Privacy and the TIP Tunnel offer complete Private Internet Browsing,Private Internet Service, Anonymous Surfing, Anonymous Internet, web surfing through the webs best most secure and private web tunnel, with free private internet browsing tools. TIP is a complete encrypted VPN solution for private internet communications.
Tiptunnel is designed for individuals accessing the Internet from insecure Internet connections, such as wireless, or from countries with restrictive Internet filtering systems.
Anonymous Internet surfing by default simply doesn't happen but it is possible. The most basic way of protecting your identity is to use an anonymous VPN to hide your IP address when you are surfing. Your communications can still be intercepted as the majority of that web traffic is in the clear but it's less likely unless someone is deliberately targeting you, the main benefit is that your IP address is not left in the logs of the web servers and your web browsing will remain more private.
provides a secure, obscured VPN tunnel between your computer and our secure servers located in Asia or the US and the Europe.
TIP Tunnel Enterprise package includes:
* Anonymous surfing
* IP Address Obscurity, your real IP address is hidden
* Bypass Internet filtering by your ISP
* All traffic is 100% encrypted with AES 256 bit encryption
* Immune to packet sniffing, attacks and popups
* Real-time virus protection
* Real-time spam filtering
* Guaranteed 100% privacy with no logs
* Supported platforms include Windows, Linux and Mac
* Multiple server access worldwide
* Professional 24/7 Technical Support
http://tiptunnel.com
Jan 06, 2010 | Computer Associates Full Version ...
100% internet connection but PSN won't let me login
That is very common, I too get that DNS error while attempting to log in. Im pretty sure it is just the playstation servers. For me it usually takes like 20-30 minutes until they get it running again or if your anxious to play just keep trying, sometimes it might only take 5 or 10 min. Hope this was helpfull.
Aug 15, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
64 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
