Question about RCA L32WD12 32 in. LCD HDTV
Has back light and partial video seperated by horizontal lines. Between the lines you can see snow and the other lines are a pinkish color. At first we had some bad caps in the power supply because lcd panel wouldn't power up. We did get half a pix at one point.
  • 11,361 Answers
If you do get the backlights OK, then the next place to look will be the LCD panel driver board (T-CON), you will have to look at the board itself for the correct one for you TV. The worst case will be the panel itsef, very expensive. http://www.shopjimmy.com/catalogsearch/result/index/?q=RCA+L32WD12+&p=1
Posted on Nov 19, 2009
How do you fix white vertical lines on Vizio tv.
Any horizontal or vertical lines on a LCD pane, 90% the chance that is a defective LCD panel.
Aug 01, 2017 | Vizio Televison & Video
I have a slightly arched pink & green line accross the top of the screen.
I am wondering if we have the correct model number listed here? If so with the model listed either something is inside like a spider web or that model uses a optical light engine which "might" be able to do this if bad.
Nov 01, 2012 | Mitsubishi WD-60735 Projection Television
I have a RCA Guide plus gold Gemstar the picture color is lighter with faint pinkish,blue and green lines horizontally
Ur tv have convergence problems,it dead.U know how to solders?U must replaced 2 STK convergence ICS,and some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 01, 2010 | Televison & Video
Non-hd channels only. color is washed out with
try component cables and see if you get the same results.
Oct 24, 2009 | Panasonic Televison & Video
Horizontal lines and colored snow
HI,
There are three likely causes for horizontal lines on your plasma TV.
1) A bad incoming signal. Do you see the lines on every channel, and from every source? If you play a DVD or videotape and the lines are still there, then that rules out your cable television or satellite box if you have one. However, if you find that the lines disappear when you play a DVD, I would contact the support desk for your cable or satellite provider.
2) A burn-in. This is caused by things like excessive use of video games or watching TV programs that have static (unchanging elements) like icons or scores or even lines. Have you tried using the built-in burn-in cleanup utility that is part of most Samsung plasma sets? Even if you suspect that the problem is not caused by burn-in i would recommend you try this just to see if it has an effect.
3) A problem with the electronics. Here you have to asnwer the following: is your set still under warranty? Most plasmas come with a one- or two-year warranty. If you paid for the set with certain types of credit cards, your warranty may be extended by a year or so: call your credit card.
If the set is still under warranty, immediately arrange for a repair and keep a record of all dates, names, phone numbers, and promises made. Don't accept any statement that five horizontal lines is "acceptable" to the maker; a pixel here or there may be excused but not a serious problem like yours.
Finally, if your set is NOT under warranty, consider carefully whether to make a repair or buy a new set. New set prices have dropped sharply, and the difference between a repair and a new set may not be significant. Of course, you can wait until the set fails.
thank you,
vijay
Sep 29, 2009 | Samsung HP-R5012 Television
After TV turned on for 2-3 hours the colors begin to change
The light engine is going bad. To be specific the color wheel is wearing out and cannot be replaced seperately as it's part of the light engine. Mitsubishi extended the warranty on the light engine for an additional two years. You need to contact a local Mit's authorized service center to see if yours is still covered. Better hope so as the light engine is expensive.
Jul 09, 2009 | Mitsubishi WD73727 73" HDTV
Picture Problems: Snow, color, lines
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 23, 2008 | Sony KP-53XBR200 53" Rear Projection...
Horizontal snow lines on record and playback
the symptom is caused by a dirty video head. sometimes cleaning tape cannot do all the jobs, especially when the dirt is so much that any cleaning tape cannot remove it. open the cover, use a clean white paper dampened with a little alcohol. use your finger on the paper and gradually move the head drum back and forth. donot move the paper up or down. just move the drum slowly. good luck!
Jan 31, 2007 | JVC GR-FXM38 VHS-C Analog Camcorder
RCA L32WD12 32 in. LCD HDTV Logo
112 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
