Question about Hotpoint Dryers
The dryer hasower but barrel wont spin heat is
The dryer has power but barrel wont spin heat is coming as well
  • Anonymous Mar 15, 2014
    BARREL WONT SPIN
  • Hotpoint Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley. If you have to replace your drum belt and if you have a front loading machine. Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum. Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn. While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good luck, I hope this helps
Posted on Nov 19, 2009
The barrel won't spin. the heat is still working, but the barrel won't spin. i may have overloaded the dryer (five pairs of jeans and three hooded sweatshirts) there was a loud bang noise and the barrel...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Dec 29, 2010 | Dryers
I have an indest 7kg tumble dryer the barrel has stopped spinning. it still heats up but wont spin.the barell can be turned by had but very stiff still. any ideas on what may have caused this or how to fix...
It sounds to me like the actual motor has stopped functioning. This could be due to a number of causes, but is more than likely due to wear of the conductive 'brushes' inside the motor itself.
I recommend having a qualified person come have a look.
Apr 15, 2010 | AEG T58840 Dryer Electric
Dryer will spin but not dry , heat element is fine
Try replacing the high limit switches if the element is fine. The limit switches will not allow power to the heat strips if they are blown. They are the little silver buttons on the heat strip. There are usually two wires connected to them one coming from the controls and one from the heat strip itself
Dave
Mar 05, 2010 | Magic Chef CYE4000AWW Electric Dryer
My dryer is not heating,we have checked all of the settings, and the barrel is spinning so can you please help, the unit is about 4 yrs.old I have a maytag neptune
check ur breaker first, dryers will run on 120volts but wont heat unless have 240.
if electric check ur heating element, thermostats, and thermal fuse for continuity with a meter.
if gas check the ignitor,thermal fuse, and secondary gas coils,
Feb 05, 2010 | Maytag Dryers
GE Dryer has not heat
dryer spins fine but wont heat
Aug 05, 2009 | GE Dryers
Dryer spins and blows out air, but no heat comes out. I had an old dryer before, and I replaced it with a fairly newer model and still, no heat is coming out of the dryer. I heard that it may be an...
Check connections at dryer terminal. sometimes they will melt and have now power and wont cause a breaker trip. plug needs 120v at L1 and 120 at L2 and equals 240 with L1 and L2 combined. can check at outlet with a meter.
Jun 08, 2009 | Maytag HYE3658AY Electric Dryer
Dryer no heat coming out
No heat coming out of my dryer it spins and there is good source of power...
Jul 21, 2008 | Whirlpool LER5636P Electric Dryer
Dryer not heating
is this a gas or electric
Mar 27, 2008 | Dryers
Kenmore 110.66712690 66712 ser.#mf3411314 not heating
ck the thermo fuse on the lint duck inside dryer its the white one also ck the thermo fuse on the element housing the one near the back dryer
Mar 06, 2008 | Dryers
Dryer wont spin
Doe the motor running ? if run w/out spinning the beltis the problem / bring sample to appliances center.
Aug 25, 2007 | Kenmore 45081 Front Load Washer / Dryer
Dryers Logo
65 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
