Question about Sharp Office Equipment & Supplies
Why does (-64)^(2/3) report an error 2? - Sharp Office Equipment & Supplies
  • Sharp Master
  • 8,049 Answers
Certain calculators such as the HP 48G are designed to return the complex principal root for any fractional exponent. Yours appanrently cannot handle complex roots, or is not in complex mode.
To get the real number root, compute the radicand first (-64)^2 using the x^2 key then compute the cube root using the cube root key, if there is one, or the general root key or even the general power key with exponent 1/3.
Hope it helps.
Thank you for using FixYa.
Hope
Posted on Nov 20, 2009
Tip
Disabling error reporting in windows xp
You might have seen this disturbing error report while you browse internet or running some application. Here are the step by step instructions on it.
Step 1: Right Click on My Computer and go to properties
Step 2: Go to Advance Tab (1) and Click on Error Reporting (2) Under start up and recovery
Step 3: Select the Radio button near Disable error reporting (1) and Check the option But Notify me when Critical error occurs and Click on OK and OK again.
http://soluzia.net/How-to-disable-error-reporting-in-windows-xp.php
on Jan 05, 2010 | Computers & Internet
Tip
Disable Error Reporting Windows XP
everyone hates those error reports whats the use of sending them they never inprove so here is how you Disable Error Reporting
1. Open Control Panel
2. Click on Performance and Maintenance.
3. Click on System.
4. Then click on the Advanced tab
5. Click on the error-reporting button on the bottom of the windows.
6. Select Disable error reporting.
7. Click OK
8. Click OK
Regards: Dark-Viper
on Jan 27, 2009 | QuickStart PC Cleaner XP (798936829016)...
Need 64 bit windows version
Then you have to get a 64 bit Windows version
Dec 30, 2013 | StompSoft CD Stomper Pro Labeling
In RAID10 4HDDs samsung HD103UJ 3 HDDs failed at the same time
Sounds about like a TDL4 malware infection, or perhaps the BAD BIOS infection!
Apr 26, 2017 | Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334...
Sharp FO-4400 Manual
Setting 05: TRANSACTION REPORT PRINT SELECTION
This sets the condition for printing out a Transaction Report. Enter a number
from 1 to 5 as follows:
1 (ERROR/TIMER MEMORY): A report will be printed after an error, timer
operation, or memory operation.
2 (SEND ONLY) A report will be printed only after a transmission
3 (ALWAYS PRINTS) A report will be printed after each
transmission, reception, or error
4 (NEVER PRINTS) A report will never be printed.
5 (ERROR ONLY) A report will be printed only after an error occurs
Oct 20, 2011 | Sharp Office Equipment & Supplies
My computer with Windows XP Pro SP2 is crashing often, after i had connected a hdd with my computer ============ CPU-Z TXT Report Processors...
probably itz either minor case of software corruption/improper ground/cpu fan..
or major case of faulty or defective main board/ram/hdd..
..plz do check the following as in order:..
the Hardware part:..
1)see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
2) 4) a) see if ur hdd is noisy or emitting any 'ticking' noise (like 'tuk tuk' or 'kirr kirr')..
b) or if the system is not supporting either the newly installed device or itz software/driver /firmware
if so, u need either a fresh os installation or ur hdd is likely to b replaced..
3)remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
4) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market) between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
5) on main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(esp above1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)....
the Software part:..
1) hv a licensed and UPDATED antivirus installed (i prefer avg/kaspersky,remember, without updation a full version antivirus is useless)..
2) download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
3) download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'remove all the unnecessary startup items from here..(if u can't find what to remove, post me/us in ur comment with all the items listed in each n every tabs herein)..
4) remove all unnecessary software from add/remove programs..
5) download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
6)disable the following:..
a) 'Automatically Restart' right click on my computer->properties->advanced->startup n recovery->(uncheck on the) Automatically Restart;
b)'Error Reporting' right click on my computer->properties->advanced->error reporting->disable error reporting->(uncheck on the) 'but notify me when critical error occur'..
7) Increase the size of Virtual Memory, Initial: 1440; Maximum: 2880
if u r bot a professional, always better to seek advise from ur system admin/vendor....
Nov 13, 2009 | Asrock K8NF4G-SATA2 Motherboard
Printig problem
This is an driver (in some parts memory) problem.
http://forums11.itrc.hp.com/service/forums/bizsupport/questionanswer.do?threadId=1258893
Author Subject: PCL XL error Subsystem: KERNEL Error: IllegalOperatorSequence favorites_add.gif Clinton Griffin
Aug 13, 2008 02:59:02 GMT I purchased a HP Color LaserJet CM1312nfi MFP and connected to my HPLaptop with Vista 64-bit operating system and received the followingerrors when trying to print from most applications:
PCL XL error
Subsystem: KERNEL
After many hours of reinstalling the drivers, the firmware, on thephone with Microsoft and on the phone with HP to no avail, I discoveredthe work around myself.
I downloaded the HP Universal Print Driver Series for Windows Vista 64-Bit and this driver works! Here is the link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=
us&prodNameId=3271558&prodTypeId=18972&prodSeriesId=503548&swLang=8&ta
skId=135&swEnvOID=2100
This solved my problem and hopefully it helps you.
- Clint
Aug 15, 2008 23:27:43 GMT Unassigned
Clint,
Just so you know what you were dealing with, as it may resurface, seeboth of Chris H's replies in this thread. Since the error was the same,it was a driver fault, and replacing the driver, not necessarily thatspecific UPD driver, that fixed it.
http://forums12.itrc.hp.com/service/forums/bizsupport/questionanswer.do;HP-FORUMS-S-WPA-IDX=H37N4f36mF4yp5t5NKsNBSL4PnhvrlHJnkHP21LmvMQkc43snv3j!-204454619
6!-1667575472?threadId=1203940&admit=109447627+1203190733494+28353475
I'm glad it's working for you.
Pat
Sep 19, 2008 03:31:26 GMT Unassigned
Update:
I continued to look at the issue and now think the problem is not thedriver, but the application software. Using the 64-bit driver for theCM1312:
1. I can print color using Paint and text using Notepad.
2. I cannot print from Adobe 9, IE 7 and Office 2007 (downloaded 9/17/08) in color. If I do I get the
PCL XL error
Subsytem: KERNEL
Error: Illegal Operator Sequence
Operator: EndSession
Position: 15
3. I CAN print all the products in 2 if I switch to grayscale.
4. I can print screen captures from the products in 2 using Paint -which may be my workaround until HP and Microsoft get together on asolution.
So does anyone from HP monitor this and report the issue and resolve it?
So theThe problem for me is color printing in Microsoft products.
Dec 20, 2008 | HP LaserJet 4250n Printer
Send error report
there is not necessary to send the error reports
Oct 08, 2007 | Microsoft Windows XP Professional With...
101 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
