Washer will kick in spin cycle, but with any type of heavy load will not spin , most times will spin if helped to get going by hand,will spin good empty or with light load.
  • 2 more comments
  • res00ot1 Nov 18, 2009
    make is top load Hotpoint 2 speed 8 cycle. don't know where to look for model number
    also how to open it to check , when it in-gauges in spin cycle, sounds like it's trying to in-gauge a gear. and dose not fully in gauge.
    need more help , please
    thank you , i did find that and opened it, could not see anything leaking and belt was tight, , i noticed below motor shaft and above motor pulley there is a sort of of a metal bowl can;t see inside but appears like it might be some sort of clutch, maybe wings or something that fly's out against the bowl driving the belt which drives the transmission, could this be worn , if that is how i think it might work, to bad i can't draw a picture of what i am trying to describe.thanks for your quick answers , much appreciated.
    President:
  • 1,218 Answers
Good day,
Without the model number or make, makes it pretty hard to come up with a solution, but if it's not a Whirlpool, Kitchenaid, Roper, or Kenmore direct drive top loader,
Remove the front panel and check the belt and tensioner.
Also, on occasion, water, and or possibly oil from an oil leak out of the bottom seal of the transmission can get on the belt and cause slippage.
P.S. On older Whirlpool and Kenmore washers, they did use a belt and you accessed it from a panel on the rear.
Belt might need adjusted, or in some cases the clutch simply wore out. Not a practical repair.
Posted on Nov 18, 2009
  • John Hall Nov 18, 2009
    Hidden clips on top left and top right where top panel meets front panel.
    Need a putty knife to locate where the clips are and press in to release. Top of front panel should tip to you when released.
Kenmore series 80 washer won't drain after wash cycle
Try the 'drain' portion of a few of the other cycles (heavy, perm. press, delicates) and see if it will drain/spin there. You can also try advancing the timer slowly through the 'spin' portion to see if it kicks in anywhere.
If it will rinse and spin in the other cycles, you most likely have a bad timer.
Hope this helps.
Sep 25, 2011 | Kenmore 22422 Top Load Washer
Put in load with which must have been to heavy, washer didn't spin out clothes, tried to put through another spin cycle, won't do it. unplugged washer, tried restarting cycle after removing clothes, will...
You can try to reset control board///unplug washer for one min/plug unit back in within 5 seconds open and close lid 5 times after you do that wait a min then unplug wait a min plug back in and lets hope she works..hope this helps good luck need more help contact me.. thanks for voting
Mar 21, 2011 | GE Profile WPRE6100G Top Load Washer
Screen reads UE? what is UE?
UE stands for Unbalance Error. If the washer has tried to spin numerous times, tried to redistribute the load itself between each attempt, and still not been able to get the load up to full speed without experiencing an off balance condition, it will finally stop and display the UE code. This is most often the case when a heavy / bulky item(s) are being washed and the spin speed is set very high. When washing these items, set the spin speed to low. The machine will most likely be able to handle that. If you want them spun out faster, then AFTER the washer has made it through the cycle on low speed spin do this: Turn the power back on. Without selecting any cycle, just press the spin speed button, selecting the next higher spin speed. Now press start, and your washer will just do a 14 minute or so pump and spin.
For super wet heavy loads, if you cannot even get the washer to go through a cycle on the lowest spin speed, you may have to wring a bunch of the water out of the clothes by hand before doing the 14 minute cycle thing.
Apr 11, 2010 | LG WM-2277HW Front Load Washer
Maytag washer will not spin, clutch slipping
Sound like it's time to go shopping, sorry
Jun 20, 2009 | Washing Machines
My Kenmore 80 series washer just started making a loud Aihaiha electrical or motor type noise. This happened during a heavy load cycle. Noise was very loud. When I click to regular, delicate or hand wash....
The following are the reasons for the drum not spinning :-
* Test the lid switch
* Test the timer control
* Test the centrifugal switch
* Test the water level switch
* Inspect the motor coupler
* Inspect the drive belt (belt drive only)
* Inspect under the washer for soot (clutch)
* Test the motor
* Inspect the pulley
* Test the transmission
In the case of loud noises in the machine, the drum bearings might have been damaged and might need a replacement. Also do check the leveling of the machine. Good luck.
Feb 28, 2009 | Washing Machines
Wont always spin with a medium to heavy load
seams like you need to check your belt
copy n paste this ;
http://www.youtube.com/watch?v=6XIsK3W_Qcg&NR=1
"Was this helpful?"
Jan 16, 2009 | Kenmore 22622 Top Load Washer
Stopped operating in the spin cycle
With a heavy blanket you probably have an out-of-balance condition which doesn't let the machine spin out and drain. This would keep the door lock from opening. Try hitting the Stop button twice. This should cancel the cycle and let the door lock open after a little while. Then either redistribute the load or add some items and run a Spin and Drain cycle.
Mar 05, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
85 people viewed this question
Top Washing Machines Experts
