Question about Dakota 3828-4 Clip-on Watch
How do I replace battery on dakota clip-on watch? Cannot seem to get the back of as with most watches to replace the battery?
  • 29 Answers
SOURCE: Opening back of watch for battery replacement
Turn the watch sideways & look around the edges of the back of the watch. You may have to use a magnifier to do this. Look for an area that has a gap. Put the knife there & pry it open. Hope this helps.
Posted on Mar 01, 2008
SOURCE: technomarine watch battery replacement
If you plan on doing this yourself, find a nice heavy pair of needle nose pliers and put the ends in the knotches on the casing back. Have them as far apart from each other as you can and turn counter-clockwise. If you still have problems opening, put the watch in a vise with the lugs in the teeth of the vise. DO NOT tighten too hard or you will snap the lugs. It dosn't have to be tight , just enough to hold the watch while you turn the back. If you still have problems please let me know and we will find another way of doing this.Good luck!!
Posted on Sep 29, 2008
SOURCE: to replace battery of pocket watch
My son has a Timex pocket watch-I just got the back off with a very tiny flat-head screwdriver- the niche or indent you're looking for is almost indiscernible; look very closely, the edge of the back barely deviates from where it meets the edge of the front piece. Looks more like a flaw than an intentional point of entry
Posted on Nov 20, 2008
  • 4 Answers
SOURCE: watch battery number for dakota watch
This watch requires a size 1620 battery, available at all Dakota Watch Company store locations, and most electronics stores. Dakota Watch Company always recommends taking your watch to one of our store locations or a reputable jeweler to reduce the risk of damaging your watch during a battery change.
We are sorry to read of your trouble with receiving technical support. We will be happy to answer any questions regarding your Dakota watch. Please feel free to contact our Customer Service by email at customerservice@dakotawatch.com, or by phone at 1-888-459-0404. Thank you!
Posted on May 21, 2009
  • 4 Answers
SOURCE: Lose or gain time?
We are sorry to read of the trouble you have experienced with your Dakota watch. The problem you have described is typically a mechanical issue that requires a movement overhaul completed by our repair department. Depending on the details of your purchase (date, place of purchase, receipt, etc) this service may be covered under warranty. To determine how to submit your watch for repair, please visit your nearest Dakota Watch Company store location, or contact our Customer Service by email at customerservice@dakotawatch.com, or by phone at 1-888-459-0404. Thank you!
How to re-close the back plate on a Dakota time/date warch?
Some of these watches have a notch where the stem goes. If you don't have the back in place it will not snap back into place. Also some are a slight screw back and will snap off, but when putting them back you must kind of screw it back in place. Good luck.
Jan 28, 2015 | Dakota Watches
How does one replace the battery used to power timex rush T44361
Hi Debra, yours might be similar to my IronMan watch...... 4 small Philips head screws to remove then back comes away to reveal a sticker that has 2 clips either side, use a safety pin point to release the clips and the battery comes off with the sticker! The battery is placed with the total flat side upwards! Hope this helps!
Nov 01, 2014 | Timex Indiglo Watches
How to change battery watche
Remove the back cover of the watch. You probably do not need a special tool to do this. The battery is likely right on top, held by a metal clip. Note the "polarity" and orientation of the battery, i.e., which end is up (take a picture, if necessary). Carefully remove the battery by gently prying up the clip that holds it in place. The battery type is engraved on it, and you will need to get a replacement of the same type or an exact equivalent. You could purchase one on-line or from Radio Shack.
With the replacement battery in hand, insert it back into its cutout within the watch mechanism, again gently prying up the clip. Make sure it's oriented the same as the original battery. Replace the watch back -- you may need to press down to make it click into place.
Sep 10, 2014 | Casio Watches
My Timex Indeglo watch does not have any means of opening the watch so I can replace the battery. It kept perfect time when it ran, but now it does not run at all. Is it supposed to be a disposable watch...
  • If you don't already know what size battery you need, you can find this information on the back plate of your watch. Once you have your replacement battery, you will need to open the back of the watch to gain access to the battery compartment. Depending on the watch, the back plate will either screw off or be attached by a few small screws. If attached with screws, you will need a set of precision screwdrivers such as a jewelry or eyeglass kit.
    Inside the battery compartment, you will see the battery is held down by a clip. Carefully remove the clip and eject the battery. Insert the new battery and replace the clip. If the battery clamp indicates you should do so, quickly press the reset button twice. Then reattach the back of the watch. If the watch display remains off after replacing the battery, press all buttons at the same time to reset the display.
  • Mar 02, 2011 | Timex Indiglo Analog Watch
    How do I change the battery/ies for the watch? The red light still functions, but the timepiece does not.
    I took a clip watch to the Mall today and had the battery replaced at the Dakota Kiosk. It cost $10. They used a tiny knife to pry off the back. I was trying to use a screwdriver and that didn't work.
    Sep 09, 2010 | Dakota Angler II 3864-9 Pendant Watch
    I got the cover off my Coleman 40-727 wrist watch. I tried to slip the battery cover off as the previous expert suggested. Easier said than done. I was not able to slide the cover off. There appear to...
    You can slide a thin metal strip(like a paper cutter or something) and lift the back cover of the case..Watches do not have clips. It just clicks into place thats all.
    Jul 06, 2010 | Watches
    I have a Pulsar PQ2001 LED wrist watch requiring battery replacement. The battery is covered by a sticker and seems to be ''clipped in.'' I afraid to try to force the 2025 battery out of its position. I...
    You need to CAREFULLY peel back that sticker and on either side of that metal clip is a way to unclip it. I really would not recommend someone changing any of their batteries unless its a "cheapo" watch! If you touch the wrong area with the tweezers you could end up having to send it in for repair! Best bet here is to take it to a reputable watch repair shop and let them do it!
    Jan 13, 2010 | Watches
    Timex Men's Digital Expedition Chrono Alarm Timer Watch battery
    hi
    please follow the steps to change the battery
    1. Step 1 Make sure the little arrow on the back is aimed to the right. Then, insert a small flat head screwdriver into the notch on the edge, and lever the back open. Place the back to one side.
    2. Step 2 Unscrew the clip holding the battery (if your model has a clip), and remove the battery.
    3. Step 3 Use plastic tweezers to put in a new battery. Do not directly touch the new battery. Screw the clip (if it has one) back on.
    4. Step 4 Replace the gasket that seals the watch. Then lightly coat the gasket with a silicone-based grease.
    5. Step 5 Align the back with the little arrow aimed to the right again, then carefully press the watch between two pieces of wood that are being held by a small vise, until the back seats itself.
    thank you....
    Apr 08, 2009 | Timex T41091 Expedition Watch
    Watch battery number for dakota watch
    Jan 31, 2009 | Dakota 2786-6 Wristwatch
    Lose or gain time?
    Jan 18, 2009 | Dakota 2786-6 Wristwatch
    Dakota 3828-4 Clip-on Watch Logo
    133 people viewed this question
    Top Dakota Watches Experts
    J.D. Browning
    J.D. Browning
    Andrew Taylor
    Andrew Taylor
    Are you a Dakota Watch Expert? Answer questions, earn points and help others
