Question about Hitachi 53FDX20B 53" Rear Projection Television
I BOUGHT TV NEW IN 2003, IT'S BEEN A OUTSTANDING TV UNTI RECENTLY, IT HAS DEVELOPED A BLUE COLORED SHADOW NEXT TO THE MAIN PICTURE SUCH AS A PERSON'S HEAD THERE IS NOW TWO HEADS. ONE REGULAR AND ONE BLUE TINTED. I HAD A SEARS TV MAN OUT & HE SAID I NEEDED NEW PROJECTION BULBS BUT IT WOULD BE A TEMPORARY FIX AND IT WAS VERY EXPENSIVE-CAN YOU TELL ME WHAT BULBS I NEED? AND DO YOU SELL THEM?
  • dean_w_l Nov 18, 2009
    I NEED HELP IN IDENTIFYING WHERE TO GO TO GET INTO THE PROPER CIRCUIT BOARD, ARE THERE ANY SPECIAL PRECAUTIONS I NEED TO KNOW IN REMOVING & RE-SOLDERING THE IC, WHERE DO I GET THE CHIP, CAN I PURCHASE IT THRU YOU, IS THERE ANY RE-ALIGNEMENT I NEED TO DO? I AM NOT A TV REPAIRMAN BUT I WORKED MOST OF MY LIFE IN THE TELEPHONE SYSTEMS TECHICNAL FIELD, BUT I HAVE BEEN RETIRED SINCE THE EARLY 80'S SO THAT WAS A LONG TIME AGO, THE SET IS A HITACHI PROJECTION COLOR TV # 53FDX20B.
    THANK YOU FOR YOUR HELP AND I WILL BE WAITING TO HEAR FROM YOU.
    DEAN LUDWICK
  • 10,594 Answers
If it is Hitachi 53FDX20B, then symptom shows TV has convergence out IC failure problem that need to be replaced.
Convergence out IC is not so costly chip and a person that can solder parts in circuit board can replace it with soldering tools.
If TV model number is other than that mentioned, post back with correct model written at back to provide you helpful info.
Thanks.
Posted on Nov 18, 2009
  • Shahid Electronics
    Shahid Electronics Nov 18, 2009
    53FDX20B.
    DEAN LUDWICK
    Get back to you with details.
    Thanks.
    53FDX20B.
    DEAN LUDWICK
    There are two big black ICs mounted on aluminum heat sink, these are convergence out ICs that need to be replaced. These are mounted on main board and number would start with STK392-xxx, very easy to recognize.
    Below image shows location of ICs
    STK392-150 are available in Part Store, please click that link to see IC image and price info.
    No adjustment is required after replacing above ICs because ICs become bad and causing problem.
    In above picture you see few low ohms resistors, please check and if found color faded or sounds heated, replace them as follows..
    Hope above info will help you repair this TV.
    Thanks.
I have a 8 year old 57in Sony projection HDTV,when the picture is dark you can see faint blue lines in a curved arch like pattern across the screen.Any ideas? Thanks
The tv problems is call a convergence picture problems,it is just starting to developing.This problems when it is fully developing into a convergence picture problems to the tv eventually.Tv will develope into a colors lines R,G,B mis alignments,have a colors shadow pictures or into a picture 3D look alike.Eventually the tv convergence board will dies,have to have it parts replaced like 2 STK convergence ICS and some or all of it resistors too.This problems the tvs shops will cost u like $300-350 for parts and lobors.
Aug 13, 2011 | Sony KP-57WS500 57" Rear Projection...
Akai PT5598HDI Rear Screen Projection TV With Blue Shadowing
If the ghosting is like a 3D effect its your convergence ICs , but if its like a blue Halo around objects that usually means your CRT coolant has congealed and will need replacement. The blue is the first tube to congeal for some reason, followed by green. Red seems to be not quite as prone to this. It is a normal occurrence n sets about 4 years old to need the coolant changed.
Jan 25, 2008 | Televison & Video
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
Blue shadows and a yellow and blue arc acroos the bottom of the screen
Tv have a problems known as a convergence problems it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board it is dead.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 02, 2011 | Pioneer SD-582HD5 58" Rear Projection...
There is a blue shadow (especially around on screen graphics, lettering etc.) when in HD mode. I attempted to align the colors through the color convergence but the blue alignment did not work. I also...
No.This tv have a convergence problems,it dead.The tv have R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board,must be repaired by repacling 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board,to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Feb 14, 2011 | Mitsubishi WS-65807 65" Rear Projection...
I have red and green shadows. I tried using the Converge Red/Blue and Multipoint Red/Blue functions as described in the manual but neither worked
The tv 100% have convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv have a dead convergence board,the 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 10, 2010 | Philips Televison & Video
PICTURE IS BOWING INWARD AND THE COLOR . LIKE PERSON FACE IT WILL HAVE A SHADOW OF RED, BLUE, GREEN, YELLOW
Tv have a problems known as a convergence problems,it dead.Colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts are dead,must be replaced on the tv convergence board to repair the convergence problems.The shop,will cost u $300,350 for parts and labors.
Sep 14, 2010 | RCA HD52W58 52" TV
The picture seems to be sliding down the screen of my Samsung HCN553W, I can still watch it except for the top 4-5 inches in the top left corner, it's black. Does anybody have any idea what it could be?
Ur tv it beginning to create and will develope a simtom call "Convergence alignment"These problems will delope in to the picture will have shades of colors like red or blue shadows,the picture bows in coners and colors will misaligns,the picture look like u watching a 3D movies,and the tv sometimes,just die and making chirpings sound.This problems very common in DLP tvs,it will develope just sonner or later that all.The covergence problems,the only way to fix are to take the tv aparts take out the Pc board call The Convergence board.Change the 2 STK convergence ICS,and some or all it supporting resitors and pico fuses.
May 06, 2010 | Samsung HCN553W 55" Rear Projection...
We have a 47 inch Vizio, Blue shadows
my vizio made a popping noise and then screen went black. tv has power
Aug 30, 2009 | Televison & Video
Hitachi 53FDX20B 53" Rear Projection Television Logo
57 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
