Question about Dometic Heating & Cooling
I would like to install a Robertshaw 9600 prog. t-stat in place of my existing Duotherm Eletratech 50-001406-A. I need a wiring diagram for the existing t-stat
3 Suggested Answers
  • 958 Answers
SOURCE: RobertShaw Thermostat 9600 problem
verify if you have separate units for each floor.
the ones working could be a complete separate unit from the one having problem.
look at the condensing units you got outside , how many are there?
if you have 3 units outside and you have 3 thermostats, then each thermostat is controlling individual split units.
we have to concentrate on the one that is not cooling. give me the details on what is going on with problematic one.
is the outside unit running?
is the outside fan running?
can you distinguished if the compressor is running the same time as the fan?
tnx 4 using fixya,
drcool
Posted on Sep 14, 2008
  • 25 Answers
SOURCE: Wiring Amana Heat pump to inside unit and 9520 robertshaw
colors can vary. you should be able to locate a wiring diagram inside the airhandler and out door unit. you will have to remove the panels. generally though Green is fan RED is power WHITE is reversing valve Blue is common YELLOW is the contactor (usually have to jump w and y terminals at robertshaw tstats. PLEASE DOUBLE CHECK AT SYSTEM DIAGRAMS!!
Posted on Nov 22, 2008
It is required to connect the RC and at least one of Y, G or W leads to set the date?
If there is no place for batteries, then yes, connect the Red wire for 24Volt power on the R ...& Common to the C.
Jan 16, 2015 | Robertshaw 9600 Heat / Cool Digital...
How to install maple chase 9600 thermostat
The manual is very specific.  http://www.icca.invensys.com/manuals/robertshaw/110-653B.pdf    The Robertshaw 9600 is the same unit. The terminals marked RH, RC, W, Y, G are where you put the wires, just loosen the set screws with a small flat head screwdriver, insert the bare wire into the hole and tighten the screw. Leave the jumper between RH and RC for most installations. The red wire goes to the RH. Please come back and comment if you need more specific help. Good luck
Jan 08, 2010 | Heating & Cooling
I have a RobertShaw 9600 and would like to set
go to there website and print the set up instructions, this should give you stsep by step set up.
Oct 27, 2009 | Heating & Cooling
No display on Robertshaw 9600; unit seems dead/furnace works
have you checked to make sure you have a fresh battery in it
Jul 25, 2009 | Shaw Robert RS-9420 Thermostat
Hello
you have to have a thermostat! The thermostat tell the unite what to do. Get a new one.
Jul 25, 2009 | Honeywell Programmable Thermostat Heater
Repace the tstat. Bad display. Make sure the batteries you put in were good First. Russ
Jul 25, 2009 | Heating & Cooling
Thermostat wont turn on heater Robert Shaw 9600 prog.
I have a thermostat 9600 Robertshaw and I have to use the trip switch to start my furnace. Then it reaches the temperature and sometimes it will kick in by itself but majority of the time I have to trip it. I have changed the batteries cleaned the thermostat,and reset it. Is it time for a new thermostat and can I replace it myself. Thanks
Nov 06, 2008 | Heating & Cooling
Wiring a Drayton Room Stat into central heating system
9 TIMES OUT OF 10 THE COLORS ARE THE SAME. MATCH THEM UP. FIRST LABEL THE WIRES ON THE ORIGINAL STAT, AND PUT THEM IN THE CORRESPONDING PLACE ON NEW ONE.
Oct 26, 2008 | Water Heaters
Apr 20, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
94 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
