Question about Cell Phones
I am putting appointments in the calendar of my new Sony Ericsson W995a cell phone and thought I'd also add local public holidays. I set them up by selecting New Appointment then enter: Subject=holiday name, Mark as=Holiday, Start Date=holiday date, All day=On, Recurrence=Yearly. For most holidays this has worked - the day shows shaded in pink in the weekly or monthly calendar view, and selecting the day shows the holiday. But for New Years Day the day is not shaded in the calendar view, and if I select the day the holiday detail doesn't show up- I have to use Options>Advanced>Find to find it. Any ideas?
Code memo error message
Download a software Online and reset it please...
Jul 31, 2012 | Sony Ericsson W995a Cell Phone
How do I remove scratches from the screen of my Sony Ericsson w995a phone?
I think, it depends on the scratch of your phone. But try using a small clean cloth or a cotton to remove the scratches. If its just a light scratch, maybe it will budge off.
Hope this helps! -jayps
Mar 15, 2011 | Sony Ericsson W995a Cell Phone
Free unlocking code for sony w995
i put the phone lock on my phone but i have forgot the pin as i havent usd it for about 4 moths can u help me
Nov 29, 2010 | Sony Ericsson W995a Cell Phone
When I sync the outlook calendar to my iphone, one of two things happens. 1. If I put an all day event in outlook, it syncs to the iphone a day earlier (both otlook & iphone are on same date &...
Make sure time-zone is the same for both iPhone and the computer.
On iPhone setting > Mail,Contacts,Calendars setting > Time Zone Support, make sure you are choosing the city where you are in.
Otherwise, make sure you have updated the iTunes to 7.5 or later.
Update to iTunes 7.5 or later to resolve this issue. If you're not able to update, continue reading for other options to resolve the issue.
Each Outlook calendar event has an internal property known as "Message Class." When some Outlook plug-ins are installed (such as Live Search Maps), the setting for the Message Class property can change from its default of "IPM.Appointment" to something else. iPhone and iPod touch are only able sync calendar events with the Message Class set to "IPM.Appointment," therefore any calendar events created after installing certain Outlook plugins may no longer sync.
To verify this, examine the property of the Calendar event items for MS Outlook and see if the Message Class shows something other than "IPM.Appointment" in any of the calendar events. To view the Message Class property for your Outlook Calendar events, add the Message Class field as one of the columns in the Current View using these steps:
  1. Open Outlook Calendar on the computer.
  2. Choose View > Current View > Events.
  3. For Windows Vista, choose View > Current View > Customize Current View.
    For Windows XP, choose View > Arrange By > Current View > Customize Current View.
  4. Click the Fields button and choose All Appointment fields from the pop-up menu in the "Select available fields from" section.
  5. In the "Available Fields" column, select "Message Class" and click the Add button.
  6. Click OK.
  7. Click OK.
Now verify that all your calendar events are showing "IPM.Appointment" for the Message Class column. If you have calendar events showing a different value other than "IPM.Appointment" you will need to perform the following steps to fix the issue.
  1. Uninstall any Outlook plugins such as Live Search Maps or other plugins which change the default Message Class "IPM.Appointment" to some other value. Once the plugins have been removed, verify if those calendar events revert back to the Message Class of "IPM.Appointment" so that you can sync the calendar data to iPhone/iPod touch. If you are able to sync, try adding the plugins back one at a time and verify that you are still able to sync.
  2. If removing the Outlook plugins does not change the Message Class value for the calendar events, manually change the Message Class value of those calendar events to "IPM.Appointment." For more information on Message Class and how to change the Message Class fields/value, refer to Microsoft's KB article 201087 How to update existing items in an Outlook folder to use a new custom form
Apr 06, 2010 | Apple iPhone Smartphone
I have a sony ericsson w995a and forgot my code for start up please help
reset manufacture settings in phone then make a new one
Mar 12, 2010 | Samsung SGH-e315
Appts on iPhone do not synch to computer
you need to set your preferences in itunes to sync properly
Nov 17, 2008 | Apple iPhone Smartphone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
