Question about Nakamichi Audio Players & Recorders
NAKAMICHI MUSICBANK CD PLAYER MB-8 - Faint ''Crackling'' in Sound
I have purchased a previously owned unit. The sound ''crackles'' or ''pops'' when all CDs are played - a faint sound in the background.. The laser head has been cleaned, but the problem still continues. What can cause this?
stoodleysnow
SOURCE: Every CD is skipping
If the cleaning cd does not work, try unplugging the player, taking the back cover off and manually cleaning the lens with cotton wool or cotton buds. If there is a stubborn smear on the lens, try methylated spirits on the cotton wool. Please note the following: Don't lose any screws You may need to take additional pieces of metal or plastic off to get at the lens; do not lose these or the screws that hold them and make sure they go back in the right order DO NOT TOUCH THE LENS WITH YOUR HANDS OR ANYTHING NOT CONSISTING OF COTTON WOOL OR METHYLATED SPIRITS! The lens will be quite fragile-do not apply excessive pressure Ensure everything goes back together the way it was, minus dust and dirt. hope this helps. stoodleysnow P.S. You can get methylated spirits at a local hardware or diy shop, or occasionally art shop.
Posted on Aug 30, 2006
  • 28 Answers
SOURCE: Sony DAV SA30 dvd player
Hi From the symptoms, you mentioned, ie playing CD's ok., Mpeg decoder chip is faulty. The new one supplied is a modified type. IC207, part no.6-707-406-01. Good luck. Capital98
Posted on Feb 14, 2007
SOURCE: crackling from surrond sound
I have a SONY home theater4.gif system, HT-C800DP, there is a crackling sound when playing DVDs - it is almost as if the unit overheats. Is there any solution to this? Sometimes I cannot even finish a DVD as the noise gets very loud.
Thanks,
Cindy
Posted on Jan 05, 2008
StuartB
  • 807 Answers
SOURCE: New laserunit won't work
You seem confident enought to take it apart, have you tried cleaning the runners that the laser runs backward and forward on.
Some times they collect dirt/dust and the laser can't move smoothly so it jerks and skips.
Posted on Mar 14, 2008
JSEhandyman
  • 368 Answers
SOURCE: crackling sound
You need to look inside (through the front grill) with the lights turned off, and try to spot the sparking/arcing high-voltage - - what you're likely hearing is a spark where high-voltage is grounding-out due to a fault in the wire insulation or some other insulating structure.
Once you isolate where in the machine it's arcing, you may be able to determine where it is and whether or not it's within your skills to fix it. If it's an XL-15 as indicated by this category, it's no longer in warranty (no longer even supported by the manufacturer, for that matter, so it will be up to you to determine how much you want to work with high-voltage electricity.
If you can find the spark, you might be able to report back here for more detailed advice. Hope this helps.
Posted on Dec 23, 2008
How to open Nakamichi CD Player MB-4s 7 disc musicbank. It has 7 our discs inside and we cannot reject them and we are unable to open the Nakamichi box.
Not really familiar with this one but most will have a very small hole somewhere on the front of the machine near the opening. A straightened paper clip pushed into the hold should open the tray.
Dec 06, 2016 | Nakamichi Car Audio & Video
Nakamichi Soundspace 8 No Sound
is this recently bought because it sounds like a manufacturing problem. get a new one, take this one back.
Jul 01, 2009 | Nakamichi SoundSpace 8 CD Player
Moving countries between 220 and 110 electricity.
http://www.nakamichi.com/pdf/SS8_brochure.pdf
According to this , your unit will do 120 V too.
Check your manual for more info.
Apr 01, 2009 | Nakamichi SoundSpace 8 CD Player
Nakamichi MB-70 CD player - cannot get cd to eject
Having just removed three discs from an identical unit which also jammed, I will say how easy that was. I do not know if the unit will now function when reinstalled in the vehicle.
Remove the unit from its mounts, remove the outer "frame" (if fitted), remove the two #2 phillips pan head screws from the sides holding the face to the chassis, remove the four #0 phillips screws (black, flat head) from the top and bottom of the face plate.
Slide the face plate off and carefully handle it while tethered by its ribbon wire.
Turing the unit upside down, peer into the opening and observe the disc, gently press the carriage away from the top of the unit (now the bottom, as it is inverted) and allow the disc to be freed, simply pull the disc out.
If there are multiple discs stuck inside, oberve the large metal gear just inside, carefully rotate the gear to actuate the loading mechanism as needed to release addtional discs.
Feb 23, 2009 | Nakamichi MB-70 6-disc In-dash Musicbank...
No sound to left channel on my nakamichi soundspace 8
Hi Sean....
Have you check the digital balance control? and , have your tried another speaker in the place where you're NOT getting sound?
Let me know...Thanks
Feb 18, 2009 | Nakamichi SoundSpace 8 CD Player
NAKAMICHI MB100 CD disfunction with the message "D-ERROR"
Try these guys based in Hong Kong. SunLight Car Stereo Co Ltd (sunlightltd@yahoo.com)
Jan 15, 2009 | Nakamichi MB100 Mobile Tuner / 6 Disc...
No volume control
HI Phil...
The AUX input will not work with a turntable.
The turntable needs a pre-amp before you connect into the Soundspace.
Try www.needledoctor.com for a pre-amp
Apr 09, 2008 | Nakamichi SoundSpace 8 CD Player
No Play No Eject
COMMON PROBLEM
OPEN IT UP AND REMOVE YOUR DISC AND THEN THROW THE PLAYER AS FAR AS YOU CAN.
Jan 26, 2008 | Nakamichi MB-70 6-Disc CD Changer
93 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
Rommel Balcita
Colin Stickland
Colin Stickland
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
