Question about Amana AOES3030 Electric Single Oven
I have an F2 error what does that mean - Amana AOES3030 Electric Single Oven
  • 6,784 Answers
HI. this code is indicating that the oven temp sensor is malfunctioning. follow the steps below to address this issue further.
1. Look for welded relay contacts on bake or broil relays. If the relay contacts are welded, replace oven control (also called clock or ERC).
2. For SELF CLEAN models: check door lock operation.
3. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature.
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
Posted on Nov 18, 2009
  • Michael Masters
    Michael Masters Nov 18, 2009
    The sensor will need to be extracted, for testing. this is achieved by unscrewing the housing screws first. These screws are located inside the oven, on the back wall, on the top right or left corner of the inside oven wall. once the screws are removed, the sensor can be pulled from the rear of the oven for testing. use the sensor contacts for testing. A multimeter will be required to test this device, correctly.The sensor housing will look like a 5 inch slender probe.
One controller keeps flashing F2, what does this mean. It will not go to any setting on/off , raise or lower heat setting, etc.
All the information is here. It is a heating sensor error. There is also a video.
If you have a GE oven with an electric ERC, F2 means it is over heating. It is an oven. It is supposed to heat up. For the GE electric ovens and some others, F2 means it thinks the temperature is 590 degrees or higher with the door unlocked or 990 degrees with the door locked.Oct 11, 2015
F2 Google Search
Dec 10, 2016 | Ovens
E1 F2 error code
Check the ribbon cable for connection
Mar 27, 2013 | Whirlpool RBS245PDS Electric Single Oven
I keep getting the following error message: E6 F2 - what does this mean?
If you have a Whirlpool oven, the F2 E6 error means that the Cancel key line is open. You will need to replace the keypad or the keypad and controller board (if a single assembly) if the keypad doesn't respond to a press of the Cancel Key.
I hope this helps.
Dec 12, 2011 | Whirlpool Ovens
I self cleaned the oven and over 12 hours later am getting a f2 error. How do I fix it?
The F2 error code means that the oven over heated by at least 100 degrees and the oven temp.sensor needs to be replaced.
On the self clean cycle the oven temp can easily reach over 600 dergees and therefore the sensor thinks it got too hot. If you have not already done so the F2 can be cleared by pushing the CLEAR/OFF button on the control...if the F2 error code reappears the sensor has became defective and it would need to be replaced.
GENE
Sep 05, 2011 | Jenn-Air WW30430P Stainless Steel Electric...
Amana Self-cleaning Oven flashes F2 and F3 and beeps. It doesn't get real hot. Although it does heat up not the appropriate temperature.
Hi, F2 error code on the Amana Oven means "Oven too hot" You have to replace Oven temperature sensor to fix it.
F3 error code means "Open or shorted oven temperature sensor". Yo also have to replace Oven temperature sensor to fix it.
Summarily, both code has to do with the temperature sensor which you need to replace...
Oct 23, 2010 | Amana Ovens
When I turn the GE oven on sometimes it works fine other times it will shut off. When it shuts off it will give the F2 or F3 error sign.Can you please tell me what this means? Thanks
Hi, the F2 Error code means the oven has detected an excess temperature condition. Most often this is due to a bad temperature sensor - the sensor costs about $75 from an online repair site.
The "F3" error code means the oven sensor is open, I suggest you flip breaker off then back, on Re check for error, if OK fine if not turn back off and fix or call for service man...
Oct 06, 2010 | Ovens
Error code f2
This usually means the oven detected an over-temperature condition (although F2 meaning varies by model). This can be caused by a faulty temperature sensor or a failed control board. Many of the control boards for the older models have been discontinued. We repair these at www.fixyourboard.com.
Oct 05, 2009 | GE Ovens
Oven will not come on. Display screen flashes F2.
The error code means that bad relay on control board.
It could also mean that sensor is not making proper
connection with the board.
Sep 01, 2009 | GE Ovens
Amana AOES3030 Electric Single Oven Logo
156 people viewed this question
Top Amana Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Ismael Rodriguez...
Are you an Amana Oven Expert? Answer questions, earn points and help others
