Question about Sony Playstation 3 (PS3) Console
When i hook up my ps3 to another tv without hdmi i use the componant cables i have sound no video
SOURCE: PS3 not working thru HDMI cable
Same happened to my ps3 one week from new , took it back the the shop and got a refund.
Posted on Oct 20, 2007
SOURCE: PS3 not working through HDMI cable
Hi Badgeman,
I repair PS3 Consoles and other Video games, It is apparent to me that you have what is ailing many of the PS3 systems, I am finding the HDMI socket is poorly soldered, and not well supported mechanically. I believe your HDMI socket need to be resoldered. Probably on both your PS3 Consoles. This is common. My service in the USA, and I do not believe it is reasonable for me to repair your PS3 since Shipping and all prohibits the service.
www.playstationclinic.com
Posted on Jun 26, 2008
SOURCE: PS3 will not display on TV
reset ps3 settings to default and restart browser
Posted on Jan 01, 2009
leme
  • 25 Answers
WHEN YOU START YOUR PS 3, KEEP YOUR FINGER ON THE START BUTTON UNTIL YOU EAR A SECOND BEEP ( BETWEEN 5 & 10 SECONDS); THIS WILL RESET AND SELECT THE RIGHT CONNECTION . I HAD TO FIND THIS PROBLEM WHEN WE WERE SWITCHING FROM THE LIVING ROOM TO MY KID'S ROOM.
LET ME KNOW, HAPPY NEW YEAR.
PIERRE ( MONTREAL)
Posted on Jan 02, 2009
  • 7 Answers
SOURCE: My PS3 hdmi cable does not work
First off, if you want to use the hdmi remove the supplied composite cable from the back of the ps3.
You don't need both plugged in at the same time, and I'm not sure with the ps3 but some video devices will not enable both at once.
Have your tv selected for whatever hdmi input you have it plugged into. They should be labeled where you plug them in.
With the unit in standby, switch off and red light in front, hold the power button by the disc tray for 3-5 second. You will hear it beep, after the initial turn on beep, then you should see a display set up screen.
If you switch back to the composite, you will have to do this over again.
Posted on Jul 06, 2009
I have the phillips system. i didnt get a manual with mine. so im hooking it up with out one. ok i have a cable running off of my hdmi cable and ps3 on hdmi. i took my ps3 off and pluged the blueray up to...
I don't recommend doing things without a manual when one is available...
http://www.p4c.philips.com/files/h/hts5580w_f7/hts5580w_f7_dfu_aen.pdf
Think about where you TV audio originates. Unless you have an antenna on your TV, everything IT hears comes from an external audio device like a cable/sat box which almost certainly has a digital audio output and/or HDMI.
I would recommend you carefully utilize your limited connections this way:
Using Page 10 as a guide.
IF your TV has 2 HDMI's or one HDMI AND one Component input:
Cable box (Component Out and Analog Stereo RCA) or HDMI Out to corresponding TV In's if available.
Cable Box coaxial audio to the HTS (3). This way the best broadcast TV multichannel audio goes to the best electronics and speakers.
HTS HDMI Out (9) to TV Component In (if available), otherwise use Component Out (7). I recommend saving the highest quality video delivery path for your native BD because broadcast Hi-Def video is always bandwidth compromised while BD is the best video available today.
Composite Video Out (6) to Composite Video In on TV for HTS management functions.
You still have both Aux In (4) pairs).
Jan 25, 2011 | Philips HTS5580W/F7 Theater System
How do I hook my PS3 gaming system into my Yamaha Rxv2600 receiver. I can get sound but do not get video. I had to use component video from the receiver to the TV because that was the fire code for...
Use HDMI - I don't understand what you mean by "fire code". HDMI uses less cable involvement, where as component uses five cable to produce video - no audio. HDMI accommodates the audio signal as well. However, if you want 1080i, this will only work for component - you need 1080p for HDMI.
Jan 20, 2011 | Yamaha RX-V2600 Receiver
Tried to hook up ps3 to a different, older tv. was hooked up with hdmi cable and optical audio cable. bought a component cable that works with the ps3. I can't get a picture or sound. or anything else. ...
HDMI is a digital signal, so your TV and your PS3 are basically talking to each other over the connection at all times. That's why when you plug an HDMI connection into your PS3, it can detect the connection and try to switch right to it. Component cables don't work the same way, they only output information, so it's a one way street. Your PS3 is still outputting information, but it still thinks it needs to output to the HDMI port. The fix is pretty simple, and there are two options.
The Long Way
  1. Plug your PS3 into an HDMI TV.
  2. Change the Audio settings first, so your console outputs audio to a Component source.
  3. Now change the Video settings last, so the PS3 is outputting to a Component source as well.
  4. Your screen should go blank once you do this. Hit the X button once, wait a moment, then use the power button on the front of the PS3 and turn it off.
Now just plug the PS3 into the other old TV with the Component cables, and turn it on. You should have picture and sound now.
The Short Way
  1. Leave the PS3 plugged into the old TV, and turn it off with the front power button. Once the light has turned Red, hold the power button down for at least 5 seconds. Don't let go until you should hear the system beep twice.
Now you should be able to use your PS3 on the older TV without a problem.
The Short Way is a simple reset of your video card, it causes the PS3 to revert to outputting to it's out-of-box settings. If neither of these ways worked, check here at the Sony website, and one of those solutions may better fit you, but it sounds like one of the two solutions above should solve it.
Please leave a comment or rating letting me know if this solved your problem, constructive feedback is always welcome. Good luck with your console and good luck with your games.
Dec 29, 2010 | Sony Playstation 3 (PS3) Console
I just bought a PS3 slim and hooked it up to my 65'' Toshiba DLP TV using a HDMI cable. The problem is i have picture but no sound. I have tried the settings and all seems to be fine, also tried different...
not 100% sure but check the manual for your tv it may be that you need a faster hdmi cable, as with having a larger tv it will work at a faster rate so the basic hdmi cables wont work.
Nov 19, 2009 | Sony Playstation 3 (PS3) Console
I have a Onkyo HT-S6100 sound system which has the HT-R667 receiver. I have a DirecTV dvr hooked up with hdmi, a PS4 hooked up with hdmi, and a Wii hooked up through component cables. The receiver is...
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
Sep 26, 2009 | Audio Players & Recorders
Ive had my PS3 hooked up using HDMI for years now but i bought a component cable because i have just bought a PVR and it can only record using component and not HDMI. The problem im getting is that when i...
Hook it up with the component cable and then hold the power button on the console until something comes up on screen. Make sure you have selected the component input on your tv or else you wont get anything anyway.
What holding the power button does is it resets the video settings to the lowest common denominator and then you can reconfigure it for the optimal picture quality of the component cables.
If that doesn't work double check the component connections on the back of the TV and just make sure they are where they should be and that no accidents were made while hooking it up.
Please post the results from these steps here so that I know what happened.
Jun 09, 2009 | Sony Playstation 3 (PS3) Console
Line going up and down TV when i play ps3?
did you reset the setting in your xmb on your ps3 from hdmi to a/v cables?
Dec 27, 2008 | Sony Playstation 3 (PS3) Console
Ps3?
Check the couplings at either end of the cable. Sometimes these will loosen and can cause a lack of signal strength.
but its probably not the cable, its probably the ps3. HDMI cables don't really break because they are just wires, they don't have moving parts. Try connecting your PS3 to your TV with the regular cable red, white, and yellow connectors that you got when you bough the PS3. If the PS3 doesn't work with the original red, white, and yellow connectors then you know its the PS3. If the PS3 does work fine, you know its either the HDMI cable (still unlikely) or the HDMI connection on your TV or PS3 (more likely
Oct 12, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
143 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
