Microsoft Xbox 360 Console Logo
Posted on Nov 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Okay well my xbox started to freeze then i turned it off then when I turned it back on i got the three red rings
Anonymous
Level 3:
Genius:
  • Master 1,093 Answers
  • Posted on Nov 18, 2009
Anonymous
Master
Level 3:
Genius:
Answers
1093
Questions
0
Helped
146269
Points
2211
Yes the reason it starts to freeze is when the GPU and the CPU are overheating and then eventually you get the 3 red lights because they overheat too much and shut down.
All you need to do is stop the heat build up and you will be able to play your games again.
To do this you need to send it back into Microsoft or use a good guide to fix this problem.
3 red rings displayed. system started freezing, now there is no activity.
I would first unplug your xbox and then plug it back in. If that does not fix the three red lights, then you have the Red Ring of Death as it is called. This problem occurs when there is some sort of overheating or hardware failure. Your best bet is to send your Xbox into Microsoft to get it fixed. If your warranty is still active this will fix it. If your warranty no longer exists your best bet would be to find a local shop that can fix it or buy a new xbox (they have pretty much eliminated the RRD). Hope this helps.
http://support.xbox.com/
2answers
Screen freeze.
two work-around methods for those consumers who are experiencing the "freeze" issue: 1) Remove or disable the HDD
or,
2) Load three different Xbox 360 games to the main title screen of each game then load Major League Baseball 2K6 on Xbox 360. All three Xbox 360 games must be completely different before loading Major League Baseball 2K6.
Part of the outer ring is coloured red and the game wont work
Yikes! red ring is not good, if the whole ring is red you need to check your AV cables, three sections is the Red Ring of Death and you need to send your Xbox in for repairs(http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/flashinglights.aspx). Off the top of my head I can't remember what the two or one red sections mean, I do know their not as serious as the three. my girlfriends freezes from time to time and red rings, but when we restart her system it all goes away (sometimes it still jams at the Xbox load screen)
When i play xboxlive it will freez then the screen will be green or red then i have to turn my xbox help
If this is what happens each time you use your your console, it might be broken. Does it have any red rings around the console's display? If that's the case, check out these links by Microsoft corresponding to the amount of red rings on your console:
1 red ring
2 red rings
3 red rings
4 red rings
They extended the warranty to three years from the purchase date for the three rings. Give them a call at 1-800-4MYXBOX and see if they can't help solve your problem. Hopefully you're still under warranty. Good Luck!
2helpful
2answers
Game freezes and dots appear on screen
I hate to break it to you, but you may have gotten the Red Ring Of Death. It happens when playing a game and it is transmitted through online play through Xbox Live. 3 red lights will appear around the power button when your console has become infected. The Red Ring of Death may have infected your console causing it to shut down. Most Xbox 360 consoles won't turn back on but some do turn back on but they just won't play games, they will freeze up and have the dotted lines and make the buzzing noise. I'm sorry, but I think you may need a new console. You're in luck if it's still under warranty. Hope this helps!!!!
1helpful
Three red rings flashing
if it is red(or darker orange) you have the three rings of death most of the time that means to send your x-box back to the manufacturer. but call Microsoft first.
RED RING WHEN TURNED ON OFF FOR A WEEK
SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
XBox 360 freezing- Not what you think
Your system is headed for the dreaded red ring w/ three red rings. My system started doing the same thing just before this happend. If you have a service plan with it i would suggest returning it and getting a new one.
I tried all the there little tricks as well deleted everything off my harddrive all that good stuff i think it made mine worse. Cuz after all that i turned it back on and bam three red lights and no picture or sound.
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
