Question about GE 24-7/8" Convertible Portable Dishwasher - White-on-White
My dishwasher wont drain and before it was making a loud noise before or while draining
Drain Pump Failure
Posted on Nov 18, 2009
A GE GSD3300D45WW dishwasher makes a loud noise and won't drain
Check drain line hose that is connected to the disposer.. Also check the disposer dishwasher drain hole inside the disposer.. Could be clogged up..
Nov 06, 2016 | GE Dishwashers
Hi wont start. just making a loud whiring noise.
According to your description of the fault, something was blocking drain turbine of main motor. Dishwashers always first start drain water because calibration of water level inside dishwasher (empty). In your case, the main motor is same motor for washing and draining. Runing in one direction means washing, runing to oposite side means draining.
The solution is to open a turbine pump and remove all obstacles and visual check turbine impeller,ceramic seal and plastic sleeve on the motor shaft.
Dado
Mar 26, 2015 | Electrolux Dishwashers
Frigidare dishwasher wont drain, can hear pump motor start
Hi Mark, this is AP and I'm happy to assist you!
I understand you are having trouble with your dishwasher not draining and making odd noises. I would suggest checking the drain hose to ensure it has not become twisted or kinked. Even if the hose is not kinked make sure it has not fallen behind the dishwasher either as this can prevent draining. Additionally, you could check the filter at the bottom of the tub to make sure no debris has clogged the filter or disposal. Other than that the drain pump could be the culprit. If so, I would recommend a local authorized technician to come out and properly diagnose the dishwasher. I hope this information helps.
Mar 15, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
When dishwasher is draining it makes a very loud noise but it does drain
May be solenoid valve makes a thud noise. It is normal.
But if it was silent during earlier days usage and the noise is notice now, then check it's mounting. For this you have to open the back door of your machine.
May 17, 2010 | Dishwashers
Loud noise during the draining that started after an year of using.
something stuck in the drain pump, you have a slight clog. the propellor is hitting this restriction.
Mar 10, 2010 | Bosch SHE66C0xUC Dishwasher
Ge triton xl makes loud noise when filling with water - water pump proboem ? or other possible cause? easy fix?
GE Triton dishwasher loud noise after draining water. We started to hear a sustained and loud noise after water is drained. This noise is not heard during washing and draining times. What is wrong? Thanks a lot!
Oct 19, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
I bought a used dishwasher when I start it it makes a loud noise
it is most likely leaking from the drain or supply tubes you must remove the dishwasher again and check the tubes for a loose band or clamp. Or a cracked hoes!
Dec 05, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
1 week after installation- is very loud
dishwasher less then 2 months old was really quiet when we purchased now has a loud vibration noise when water is pumping out.
Jul 23, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Dishwasher loud in beginning cycle and drains early
sounds like you have 2 problems however generally speaking (most makes) of dishwashers go into drain mode when there is a fault elsewhere, however is this set up properly, is the waste pipe end high enough to allow the water to actually fill up (only about 30cms of water aprox)so it doesn't flow straight though to the waste. the noise could just be an empty pump, it runs dry after a while, and makes a screeching noise eventually? check installation pictures to see if its set up right, you may have also a leak somewhere check all other connections and pipes
Sep 21, 2007 | Maytag MDB7100AWB Dishwasher
GE 24-7/8" Convertible Portable Dishwasher - White-on-White Logo
302 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
