Question about Bosch Axxis WFL 2060 Front Load Washer
Doesnt spin on spincylce and just makes a rattling noisewff1475 bosch
  • Bosch Master
  • 3,463 Answers
The rattling noise is probably something in the pump.
If it is not draining properly, this will stop it spinning.
Check pump filter, if clean, then I would suggest you check the brushes in the motor for wear, as badly worn brushes will also stop it spinning.
Please rate my solution.
Thanks.
Posted on Nov 19, 2009
Bosch Maxx washing machine. 1000rpm It rattles in the spin cycle
The load in the drum is seriously out of balance at the start of the spin cycle and that is why the drum and tub are mounted on a fairly substantial suspension system.
The mountings of the suspension system and the springs or dampers take a real pounding so it isn't unusual that sometimes a spring will break or a mounting wear through.
Clearly it could be something else entirely but whatever the cause it needs checking with a degree of priority. There is a lot of semi-exposed wiring and circuitry inside that soon could be damaged, perhaps making repair uneconomic - "a stitch in time saves nine"...
Mar 28, 2016 | Bosch Washing Machines
My Bosch washing machine won't turn the bowl
Hi Justene,
i Think its control circuit has a problem.
or the fuse for motor drive circuit is damaged.
please check with electrician.
regards.
nuwan
Jan 13, 2014 | Bosch Washing Machines
Bosch wfl 2060 washing machine makes a funny rattling sound when it should be spinning or draining. why
Check the filter behind the flap (Bottom right of kickplate) souns like you have a coin or other foreign object in the pump.
Feb 18, 2013 | Bosch Axxis WFL 2060 Front Load Washer
Washer makes a rattling sound when it starts the spin cycle. Sounds like gears stripping or something loose rattling around. Now it won't spin after the wash cycle. It will spin if I put it on the...
Sounds like you cannot activate youre imagination maybe Ill do this for you one time here goes ~: You or someone left coins in your pockets jeans cardigan whatever they got out of garment while in the wash spin and worked themselves into the machine and now its bug-gerred innit?
Jul 30, 2017 | Bosch Axxis WFL 2060 Front Load Washer
My bosch classix 1200 fl wont spin or drain
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Plug off the wall first. Remove the front lower panel, screws underneath. Be prepared for water, drain out from drain hose. Check filter for clogging, clean out. Sometimes when the load is unbalanced & the machine cannot adjust the load it stops. To avoid this make sure your wash is mixed with big and small clothes.
If this does not work remove the rear panel & check belt, should have half inch ‘give’. Still not good, remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes (at terminal end of motor), if they are any shorter than 1 cm replace brushes.
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Oct 15, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Washing machine doesnt rinse and spin
IT SOUNDS AS THOUGH ITS NOT HEATING IF IT DOESNT IT STAYS IN WASH MODE AND WONT COMPLETE CYCLE NEW HEATER REQUIRED
Aug 12, 2009 | Bosch Exxcel WVT 2850 Front Load Washer /...
Overheats, engine rattles when idle and when accelerating, radiator fan doesnt seem to spin
If your engine is rattling,it's TOO hot. Get it checked out immediately, and don't drive it ant farther than the repair shop. You may have already done damage to the engine.
Jul 02, 2009 | 1999 Pontiac Grand Prix
Bosch built in dishwasher won't drain
1.
  1. Adjust the level of the washer to mitigate sound.
  2. The water backup is due to the low drain hose mounting position. Check the sink disposal position; the drain hose connection from the dishwasher to the disposal must be placed higher than the present drain hose passing the sink cabinet from your dishwasher.
Jun 24, 2008 | Bosch SHU3305 Dishwasher
Ticking noise in spin
Possible. First run your hand around the inside drum...be careful...sometimes there can be an object stuck in the holes and the extra vibration can set it off. common objects are bra wires and hair clips (sorry ladys its the truth) followed very closely by......(you guessed it ladys) Nails
Jan 03, 2008 | Bosch WFMC 3200 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
262 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
