Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
I have a Honeywell VisionPro IAQ touchscreen thermostat (model # TH-9421). The right 25% of the screen has no touch response, but visual display is fine. Seemed to happen out of the blue, worked one week, the next week it didn't work. The left 3/4 of the screen has touch response. With the right 25% not responding to touch, can't change temp, humidity, can't even change set up options. Even in setup mode, can't change any values since inputs are on right side of screen. I even got a new thermostat from Honeywell under warranty and popped it in and had the same exact problem...25% of screen on right side is dead to touch. What could be causing this? There are only three pins on the back of the thermostat to connect to 3 wires...everything is there and connected. Could the interface module (down in the furnace room) be causing this? Thanks for any advice or guidance since the HVAC installer is stumped...I want to try to help him solve this.
Same thing happened to me. I spent 10 minutes on the phone with Honeywell, and they told me to wipe the screen clean. And, believe it or not -- IT WORKED! I was shocked. I thought the guy was just trying to blow me off. But, sure enough.... some times it's just the simple things that work.
Posted on Nov 10, 2010
  • Barbara
    Barbara Nov 18, 2013
    I am happy. Wiping the screen worked for me too!!! Had tried all battery suggestions & none worked. Freezing cold and just about to call a service tech when I read your suggestion. Thank you for your post!!!
  • 614 Answers
I have not had that problem. But go yo yourhomehoneywellthermastats and the web site has question and answers. Rus
Posted on Nov 18, 2009
  • Barbara
    Wiping the screen worked for me too!!! I was just about to call a service technician. Hurrah!!!
    Problem Solver:
  • 14 Answers
I do not have the same thermostat but did need to turn my display off when sleeping downstairs near the thermostat. So, I called my utility company that installed the Honeywell Utility Pro Series Thermostat and here is how to do it. It was not in the Honeywell User Manual located at:
http://www.bgesmartenergy.com/media/pr/thermostat-operation-manual.pdf
  1. Press System – it will blink
  2. Press & Hold Square 3 + 5 at the same time
  3. 120 change with up arrow to 280
  4. 0 = OFF and 1 = ON
  5. Hit Done button
That is it for mine! Hope this helps.
Posted on Nov 20, 2009
I have a Honeywell VisionPRO IAQ thermostat. Heat won't kick on automatically, thermostat keeps saying 'wait. Can turn system off, back on and works. Is there something I can do to fix it?
Have you tried reseting the system by throwing the breaker waiting a minute then restarting? Turning it off and on at the keypad isn't the same thing. That has happened to me and the program glitched. I'm not sure what is being displayed on the screen, so am not sure what you have done, partially completed a scheduling program, etc. However, I found the manual online.
www.manualslib.com/manual/782319/Honeywell-Visionpro-Iaq.html?page=2#manual
You can look through it and see if there is something in there you aren't/are doing to keep it from working properly. There is also a 1800 number for assistance from Honeywell if your still stuck. Hope this helps.
Oct 18, 2017 | Honeywell Heating & Cooling
Honeywell TH9421C1004 blank after power outage. How dove ss I turn it back on?
Remove your thermostat from the wall and you probably will find a battery compartment in the rear.
Sep 01, 2014 | Honeywell TH9421C1004 VisionPRO IAQ Total...
Honeywell TH9421C1004 blank screen after power outage
We'd love to help resolve this. Please give us a call at 1.855.733.5465 and our customer support team will be happy to troubleshoot with you.
Auto does not show in system
On Honeywell thermostats you have to program the thermostat on the setup mode to have the auto to be on the display. The setup instructions will walk up through it. If you do not have them, you can down load them to you computer.
Jul 20, 2014 | Honeywell TH9421C1004 VisionPRO IAQ Total...
TH9421C1004 touch screen stopped working
Make sure there is 24 Volts between the R & Common wires connected to the thermostat subbase.
Dec 13, 2013 | Honeywell TH9421C1004 VisionPRO IAQ Total...
Touch screen stopped responding
Pull the thermostat face off the wall. Wait a few minutes, & gently line up the pins and place back on. Let display pull up. If that doesn't work, your thermostat is probably under warranty...Replace.
Honeywell VisionPRO IAQ thermostat. No back light. Screen shows characters, but dim. When touched, back light fails to work. All other systems function okay.
this control has an option for back light display in the set up menu. if it has never worked this may be the problem. if it did work then quit you should replace the t-stat. there are many different models as they have advanced over the years. this is a great control. see if you can find the set up manual
Oct 12, 2013 | Honeywell YTH9421C1002 VisionPRO IAQ...
Blank Screen on thermostat
check your float switch. On your air hander you have 3/4 white pvc coming out of bottom of unit, where the water drains out. If you have a float and your drain line is plugged it will make your tstat go blank. vacuum the drain line where it comes out of the ground outside.
Jun 19, 2013 | Honeywell TH9421C1004 VisionPRO IAQ Total...
Honeywell 8000 Thermostat relay switch clicking noise.
It's an expensive solution but doable. Look for Honeywell's VisionPro IAQ thermostat. It works much differently than a conventional thermostat and shouldn't click at all make sure it's the 3-wire version.
Aug 21, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
1,397 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
