Question about Ricoh Office Equipment & Supplies
ORIGINAL MISFEED (J001) - Ricoh Office Equipment & Supplies
  • 32 Answers
Open the adf cover and clean all the sensors
Posted on Dec 08, 2009
2 Suggested Answers
  • 1294 Answers
SOURCE: My Gestetner Dsc445 shows a continuous misfeed
Verify the exit sensor actuator and the entrance sensor actuator.
Posted on Nov 24, 2009
Testimonial: "Ive just received the service manual, will check the actuators. Thanks."
Any time i try to print with my sharp ar-m205, it automatically reselect bypass tray and give error Check bypass tray: out of paper or misfeed. But the original tray i selected is tray 1 and there is paper...
Make absolutely certain the correct size is specified for the paper in your tray, otherwise your print driver may be locked on selecting from the bypass tray and not set to 'auto select'
Nov 01, 2013 | Sharp AR-M205 Copier
MISFEED INDICATOR BLINKING
DEAR SIR WHERE YOU REMOVE THE PAPER IN THE MACHINE THAT SECTION THERE IS PAPER PATH SENSOR ,THAT SENSOR POSITION IS ABNORMAL PLEASE CHECK THE SENSOR OF THAT SECTION WHERE YOU REMOVED THE PAPER
Hope this may help;
Regards,
VOTIT
Aug 29, 2008 | Sharp AL 800 Copier
Error code J001 shows up after a jam
ricoh mpc3500 paper jam j001 which sensor ,no have inside paper
Jul 06, 2011 | Ricoh Aficio 250 Copier
It is showing the following signs U1, A,C
look my dear that is misfeed positions ok a; that mean first tray misfeed and tray2 c; that mean misfeed in fuser unit u1; mean misfeed in sorter
Jan 08, 2011 | Ricoh FT5832 Copier
Will copiers misfeed when toner is low and would you get a joo1 code
I don't know about the j001 code but generally the reason a copier will misfeed is the pick up rollers being worn. There can be a number of other reasons besides this but this is the most likely.
Oct 10, 2010 | Gestetner Copier
Hello, I have a Brother Fax 560 (Plain Paper Fax). I am having difficulty receiving faxes. It is not transmitting on the receiving end. What is the problem?
Hi Despite the increase in texting, email, Facebook and Twitter, we still hang on to our fax machines. They are perfect for sending copies of original documents despite document jams, buying ink or special paper, maintaining a phone line--we love 'em. Basic problems like paper misfeeds can be troubleshooted through the use of some basic steps.
Check the Message
  • Check the messages on the display of your Brother fax machinemag-glass_10x10.gif. The messages will be pretty self-explanatory such as "Insert Doc, Again" or "Please Supply Paper." "Insert Doc. Again" means that that the documents weren't placed on the feeder correctly; just follow the instructions and try again. A message like "Please Supply Paper" will simply mean you need to replenish the paper. "Memory Overflow" is probably the most cryptic. It just means that the memory capacity was exceeded and it has stopped recording. Press "Enter" to register the documents in memory and to complete the operation.
  • Misfeeds
  • Clearing an original's misfeed by pushing down on the release lever to open the front panel. Remove the failed original and close the panel. To clear recording paper that's gotten jammed in the paperfeed, open the turn guide and remove the paper. To clear paper from the transport unit, which is in the top, open the cover, remove the drum and toner. Lift the guide and remove the paper by pulling upwards. Paper can get stuck in what is called the Fixing Unit. Open the top cover. Again, remove the drum and toner. Open the Fixing Unit cover and remove the paper by pulling it back.
  • Aug 02, 2010 | Brother IntelliFAX 560 Plain Paper Fax
    Misfeed detected but no paper jam
    Di 251 is legacy Minolta machine, Minolta is now Konica Minolta
    for the image unit try this site
    Precision Roller Printer Toner Cartridges Parts and Supplies Office...
    as for the adf replace!!! the rollers all three try the same site above
    Nov 03, 2009 | Minolta Di251 All-In-One Printer
    I JUST CHANGED THE TONER AND THE COPIES ARE PRINTING OUT WITH A HEAVY THICK LINE ON THE SIDES
    Indication Cause and remedy Page
    Drum replacement
    required indicator
    Steadily
    lit
    Replacement of drum cartridge will be needed
    soon. Prepare a new cartridge. 70
    Blinking Drum cartridge must be replaced. Replace it with
    a new one. 58
    TD cartridge
    replacement
    required indicator
    Steadily
    lit
    Replacement of TD cartridge will be needed
    Blinking TD cartridge must be replaced. Replace it with a
    new one. 57
    Misfeed indicator Blinking
    A misfeed has occurred. Remove the misfed
    paper referring to the description of "MISFEED
    REMOVAL".
    63
    SPF misfeed
    indicator Blinking
    An original misfeed has occurred in the SPF.
    Remove the misfed originals referring to the
    description of "D: Misfeed in the SPF".
    67
    Power save indicator is
    steadily lit.
    The unit is in the preheat mode. Press any key to
    cancel the preheat mode. 54
    The unit is in the auto power shut-off mode.
    Press the start ( ) key to cancel the auto power
    shut-off mode.
    54
    The paper tray indicator is
    blinking.
    The paper tray is not installed properly. Push the
    tray into the unit securely. –
    "CH" is blinking in the
    display.
    The TD cartridge is not installed. Check if the
    cartridge is installed. 57
    "CH" is steadily lit in the
    display.
    Side cover is open. Close the side cover
    securely by pressing the round projections near
    the side cover open button.
    "P" is blinking in the display.
    The paper tray or multi-bypass tray is empty.
    Load paper. 15, 17
    A misfeed has occurred in the paper tray or
    multi-bypass tray. Remove the misfed paper. 63
    A letter and a number appear
    alternately.
    The scan head locking switch is locked. Unlock
    the scan head locking switch. 9
    alternately.
    The unit will not function. Turn the power switch
    off, remove the power cord from the outlet, and
    contact our Technical Assistance Department at
    1-(630)378-3590 in the USA or 905-568-7140 in
    Canada.
    May 13, 2009 | Sharp Office Equipment & Supplies
    1,820 people viewed this question
    Top Ricoh Office Equipment & Supplies Experts
    OfficeServiceAjnc
    OfficeServiceAjnc
    fares
    Level 1 Expert
    SOURAV KAPOOR
    Level 1 Expert
    Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
