Question about Frigidaire FWS833A Top Load Washer
Washer wont spin
i can here the motor running but it is making a clicking noise and won't spin. lid does not lock now in spin mode
    Guru:
  • 1,738 Answers
It is your cluch on your motor. Your cluch what holds your transmission in place while spinning.
Posted on Nov 19, 2009
THE DOOR WON'T LOCK THEREFORE THE MACHINE WONT START
Washer Door or Lid Won't Lock - Repair Parts - RepairClinic ...
www.repairclinic.com/...Washing-Machine/...---/Washer-door-or-lid-wo...
Most Frequent Causes for Washer door or lid won't lock. For the most ... Once thewasher door is closed, the washer can begin operating. If the door lock is ...
Door makes clicking noise and won't lock or start - Kenmore ...
https://www.ifixit.com/.../Door+makes+clicking+noise+and+won't+l...
iFixitOct 30, 2013 - Door or Lid Latch Assembly If the washer lid or door won't lock thelock and ... The Kenmore Elite HE3 is a washing machine by Kenmore.
Front Load GE washer won't lock / start. ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Front Load GE washer won't lock / start. ... Based on your symptom and details it could have a faulty door lock assembly ... GE Washing Machines 3.8 cu. ft.
Washer Won't Spin or Agitate? Washer Door Latch ...
Dec 13, 2015 | Washing Machines
Lid is not locking properly, washer sensor is overfilling, and the washer wont spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Pl click if helped.
Apr 28, 2013 | Whirlpool WTW4950XW Washer
My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 11, 2012 | Washing Machines
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
Sep 30, 2012 | Roper Washing Machines
The machine doesn't spin properly and doesn't drain the water
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Sep 28, 2012 | Hotpoint Washing Machines
Roper RAX4232KQ0 maker loud noise at spin cycle and then stops
There are a few things that can go wrong, If the washer doesn't adgitate or spin then probably the coupler is broken, lean the washer back and look under the machine between the motor and transmission you will find the coupler. (very common)
Coupler Part# 285753A $22.95
If its agitating but not spinning, check the lid switch, (easy check just listen for the click when you shut the lid, Or you can bypass it with a jumper wire under the console there are only 2 screw that hold the console down they are philips and either located in the front lower corners or the back lower corners)
Lid switch Part# 3949247 $42.95
If lid switch is good and the motor still doesnt run you might have a bad timer (RARE)
Timer Part# 3954563 $95.95
If you can hear the motor running but its not spinning and you have rulled out the coupler then your probably looking at a clutch (common problem) either the clutch isnt grabbing or the brake isnt releasing both problems solved with the clutch kit
Clutch kit Part# 285785 $44.95
Worst case your looking at a transmission, (uncommon) to rule out, make sure its agitating, then put washer in spin cycle. look under the washer to see if the clutch bell is spinning. if its not then you will need a transmission.
Trans Part# 3360629 $172.95
if its making loud noises when it stops spinnig then the block is bad.
Block Part# 389140 $14.95
Feb 07, 2009 | Roper RAX4232KQ Top Load Washer
Wont go to wash
Do you hear any noise, like motor running or anything like that or does it just sit silently?  If it makes noise, it could be a motor coupler issue.  If it sit silently, it may only be a lid switch.  The lid switches do have a habit of breaking, which would allow it to fill, but not run.  No to expensive, and a fairly easy job to do.  Let me know further info or if you need any help or info.
Jim
Sep 21, 2007 | Roper RAS8445KQ Top Load Washer
Frigidaire FWS833A Top Load Washer Logo
156 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
