Question about Samsung SGH-i900 Omnia Unlocked Cellular Phone
My messages screen will not load even after I click the messages button from the mai menu!
Enlarge text size
Create Menu tab right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar
This will add to your screen toolbar File Edit View Favorites Tools and Help select the View from the drop down list will be a Zoom with percentages % and text sizes largest to smallest and Full screen option
Increase the Font Size in Email
Email font size is easily controlled while composing messages, but the messages you receive have been sized by the sender.
Some contacts may be perfectly comfortable writing in size 8, but such text can be a strain on the eyes, even with good reading glasses.
The printed hard copies of email messages with small text are even more difficult to read.
There are a few ways to quickly change font size for ease of reading and better quality print-outs.
Open an email message with particularly small text. Increase the email font size of the text using step 2, 3 or 4.
Click on the "View" selection from the menu bar.
Roll the mouse pointer over the "Zoom" choice.
Click on one of the choices that is greater than 100 percent.
Click "View" and cover "Zoom" to make a larger choice if the first choice does not increase the text size sufficiently.
Click the "View" option on the menu bar. Roll the cursor over the "Text Size" selection.
Choose one of the options that will increase the text size.
For instance, if the current size marked with the dot is "Medium," then click "Larger" or "Largest" to make the print appear bigger.
Use a mouse with a wheel to increase the email font size.
Press and hold the "Ctrl" key while rolling the wheel on the mouse.
The text will shrink as you roll in one direction, and grow bigger as you roll in the other.
Change font size before printing.
Click the "File" option on the menu bar.
Click "Print Preview."
Click the "Size" drop down which may display "100%," or "Shrink to fit."
Select a choice greater than 100 percent to increase text size.
Click the "Print" button to view the results on a hard copy.
Nov 13, 2013 | Computers & Internet
I just replaced the ink cartridge in my canon printer and tried to print something. A box came up saying the alignment may be off and I need to print an alignment page. How do I do that?
Hello. To do a head alignment follow the steps below.
  1. Click Start - Control Panel - printers and faxes
  2. RIGHT CLICK on the canon printer and select printing preferences
  3. Select Maintenance from the top right tab (see image below)
  4. Select print head alignment and follow the steps on screen.
I hope this helps, If so please rate this answer below. Thank You for supporting the FixYa Community
Regards GM
Apr 24, 2011 | Canon Pixma iP2600 Photo InkJet Printer
How do you delete facebook messages? My facebook has 300 comments.
1.
Log in to the Facebook website (see the "Resources" section) with your registered email address and password.
2.
Select "Inbox" from the navigation menu. Email messages received from Facebook messaging system load on the screen.
3.
Press the "Sent" link. All messages you've sent via Facebook's email system are listed.
4.
Select the messages you'd like to delete by clicking on the "X" next to each message. To select multiple messages, click on the box next to each sent message you wish to delete. To select all sent messages, press the "All" button. To deselect all messages, click the "None" button.
5.
Click on the "Delete" button from the menu bar.
Please rate me if this solution works for you
Thanks......Have a great time.
Aug 22, 2010 | Computers & Internet
How can you change the message alert tone or even change it on a samsung s5230 tocco lite?
If you want to change the Tones of the Incoming Messages:
Go to Menu--Settings--Phone Profiles--Click the Arrow next to the profile you have already been using--on the top You will see an arrow facing download (a drop down menu button)--click--select New Messages--on clicking the Message Alert Tone box you will see loads of tones that you would want to select--in case if you want any song or tone that you have on you mobile to be your default message alert--select "sounds" at the bottom--select the "arrow" on the top go to the directory where you have the tones..select it and "Add" and then click "Save"
Hope it helped...Let me know if there's any problem...
Apr 03, 2010 | Samsung SGH-S5230 Cell Phone
Keeps printing documents over and over - things from yesterday and last week even!
Try doing a soft reset to see if your can clear the printer's memory cache:
  1. Press MENU/ENTER.
  2. Simultaneously press then release the * button and the # button to enter the Developer’s menu.
  3. Press the < or > button until the message REINIT FFS appears on the second line of the control-panel display.
  4. Press MENU/ENTER.
  5. The process takes approximately 2.5 minutes. During that time, the control-panel display will change several times before returning to Ready.
  6. When the Ready message appears on the control-panel display, press CANCEL to exit the Developer’s menu.
Mar 16, 2010 | HP LaserJet 3015 All-In-One Printer
Have power (backlite) but no screen (menu or any control from side buttons) will not turn off.
Try disconnecting the tv button pcb interface connection to the mai board once switched on and try using your remote control functions. If there is still no menu or functions, this cancels out the buttons pcb, and the fault is the main pcb.The voltages are ok which you mentioned..12v..5v and the 24v invertor feed voltage so it will be the main pcb..If you had sound and remote functions i would have said it may be the Tcon as well as the main pcb.
If the remote works ok with tv buttons pcb disconnected, then the problem is the buttons pcb.However, you have no picture..i presume nothing at all including 'no signal message or menu screen'. Therefore, with no bulging caps and correct votages to the main pcb, you will be right to change the main pcb.
PLEASE DO NOT CARRY OUT ANY ELECTRICAL REPAIRS IF YOU ARE NOT COMPETENT TO DO SO..ALL MAINS PARTS ARE DANGEROUS..GET A QUALIFIED TV ENGINEER TO CARRY OUT ANY REPAIRS IF THIS IS THE CASE.
Feb 14, 2010 | Vizio L32 32 in. LCD HDTV
Down loading, Service unavailable
u need to make sure that your network connection is set to t-moble otherwise you will keep getting the same error. Click on Messaging.Scroll to the bottom of the menu. Click on Message Settings.Click on Text Message.Click on Message Center Number.
Enter in the Mobile Operator phone number that corresponds to text messaging. When finished, click the Set button at the bottom of the screen.( note you may need to get the oporator number from ur cell phone service provider.
Nov 10, 2009 | LG Vu CU920 Cellular Phone
Text messages wont send, delete, or change status
I think your mobile is affected by virus. I suggest you to format your memory card and flash your phone. Dont use the backup you have taken other than the contacts. Load other things manually and frehly. hope this helps.!!
Aug 22, 2009 | Samsung Blackjack SGH-I607 Smartphone
My yahoo messager will not load when u click on it from the starst menu. i uninstalled the messager and downloaded the latest version and installed it. now when i click on the start menu for messager or...
Try this:
Using explorer go to the c:\Program Files\Yahoo Messenger (or whatever you named it) directory + right click on the program icon (EXE file) + send to + Desktop.
Than delete the old icon as it doesn't work anymore.
Mar 02, 2009 | Dell Latitude D600 Notebook
Samsung SGH-i900 Omnia Unlocked Cellular Phone Logo
24 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
