Question about ViewSonic VPW450HD 42 in. HD-Ready Plasma Television
Broken coaxial input on a samsung 42 plasma - ViewSonic VPW450HD 42 in. HD-Ready Plasma Television
    President:
  • 1,284 Answers
Most likely can replace just the tuner. I will need a model number of the TV first.
Posted on Nov 18, 2009
My cable box is hooked up but no signal can u tell me whats wrong
If you hookup your TV directly to the coaxial cable, bypassing the cable-box, do you get a few channels? If so, then the coaxial cable is carrying a signal, which is good.
How are you hooking the output from the cable-box to the input(s) on the TV? Coaxial output port on box to coaxial input port on TV?
Red/blue/green "component" outputs on box to matching inputs on TV? Red/White audio outputs on box to red/white inputs on TV? HMDI output from box to HDMI input on TV?
You have to "tell" the TV which of the inputs:
* coaxial (with TV set to Channel 3 or 4)
* component
* HDMI
to "listen" to.
Oct 24, 2014 | Samsung PN60E6500 60-inch 3D Plasma TV
How do you connect a coaxile cable wire to nec plasma tv that has no coaxile connection plug.
You need to have a decoder box from a over-the-air (DTV), cable or satellite provider that has an HDMI, "S" video, composite video, VGA or component video outputs to connect to the TV's input. The coaxial cable only plugs into the decoder box. Apparently your TV doesn't have a tuner for coaxial RF.
Jan 17, 2011 | NEC PlasmaSync 42MP3 42 in. Television
Samsung HP-R4272 42" plasma. 3" blue/ green ribbon
This is caused by the LCD panel shifting in it's mounts. You will need to disassemble the frame holding the LCD screen in place and re-center it.
The lines will take some time to go away as the set warms up, but be patient, they usually disappear over time.
Oct 26, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
I Have a Samsung HP-R4252 42 in. HDTV Plasma Television and the picture is not showing. It does have sound but no picture. Is there any ease way to fix this problem??
sounds like the video cable is not in the right input.
or maybe you have to redo the setup and be sure the tv is set to the right video input . HDMI or component etc. I hope this helps.
Oct 19, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
For some reason, the component video input on my Sony Wega KE-42TS2U plasma HDTV will not work. Component video is on video 3. All other inputs work fine (coaxial, standard RCA inputs, and the digital...
Yes you need a new Q board most likely, if you audio fails after a while and your other inputs do as well then for sure you need a new Q board. It may be B board but I highly doubt. Atleast with my experiences with the KE-42TS2U.
Feb 21, 2010 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
Where is the cable tv input to screw a normal cable cord into the back of my akai 42 inch plasma screen? Does it have one?
Every T.V. will have a Coaxial input on it. Just keep searching. More than likely if you have all your rca/componet inputs on the back of your t.v, it should be towards the bottom of those, and if not, Not to often, but it could be behind a hidden flap. Read your manual, it will let you know exactly where it is.
Sep 01, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Cannot find hdmi connections
Here is the link where I viewed the specs on your tv. I do not see where you have the HDMI inputs.
http://www.bizrate.com/tv/samsung-sp-p4251-42-in-flat-panel-plasma-tv--pid70802962/
May 11, 2009 | Samsung SP-P4251 42 in. Plasma EDTV
Connecting a samsung dvd-vr to TV with cable & rf modulator
my coaxial cable hook up is broken from the plasma. Can i fix it?
Jun 15, 2008 | Samsung LN-R328W 32 in. HD-Ready LCD...
Daewoo screen in a samsung
probably not,,,you need to look at the back of the plasma panel itself and see who really made it..the samsung is probably a samsung panel while the daewoo might be from lg..
Sep 21, 2007 | Televison & Video
Theoretically yes functionally no. Not unless the parts are the same, chack the model numbers of the plasma screens. If they match you can change them out, if not don't try it.
Sep 21, 2007 | Daewoo DP42SM 42 in. HD-Ready Plasma...
ViewSonic VPW450HD 42 in. HD-Ready Plasma Television Logo
402 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
