Question about Toshiba 50H13 50" Rear Projection Television
Video has squigly lines in it at the top of screen ..
Squigly lines run from left to right at the top of a picture. They are not actual lines but the video itself is squigly.
  • dvsax Jan 11, 2008
    Where do I get the module and/or info on rebuilding it (I am skilled)? THNX for the quick response..................D.
  • 1,694 Answers
Small board called a hyper module bad .....can be rebuilt be
skilled tech or sent for rebuild..........................T.
Posted on Jan 10, 2008
  • Vista Electronics Jan 11, 2008
    R & R all 10mf 16v bad caps.....can be checked using an ESR
    meter or just change them all.....Hyper board is a stand-up little
    sister on the signal board.....more info to follow..............T.
    Part # ( NLA ) = 23786198 Toshiba ..............................T.
Good picture but a squigly line
Will you please provide more details> Is the line across the screen at its middle?
Jan 02, 2013 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Picture goes blank with squigly lines
your lcd was broken, change lcd screen with a new one
Jan 08, 2011 | Maxent MX-27X1 27 in. HD-Ready LCD...
My toshiba 32 inch lcd tv has green ,red,and purple squigly lines on the screen Model # is 32AV500U
Change Your Regulator on your Color Mixer check the choke beside it the little yellow trasfomator beside.... It maybe damage too....
Sep 21, 2010 | Toshiba 32AV500U 32 in. LCD HDTV
My tv gets really hot lately...almost burns to the that normal? also when I switch inputs...from dvd (av1) to antenna I get sound but no picture....only white and black squigly can...
Is there anything on top of your TV? Are the sides or rear right up against anything?
If so, the problem could be that there is not enough ventilation. Make sure there are no vent holes blocked. Also, cleaning it couldn't hurt if it's dusty.
Also, is your TV near any source of heat?
Aug 18, 2009 | Televison & Video
Samsung HCL5515W...when using coax input pic convergence is off, red and blue seem off....when I use the component inputs it constantly flickers between the squigly lines and picture with convergence off?...
on component your device may have to be on progressive. old dvd players you could switch back and forth on progressive and normal. the squigly lines sound like you need to make sure its on progressive. hook it up using the yellow video slot on player and tv (any cable will work). go into menu and look for progressive and change it on.
Jul 14, 2009 | Samsung HCL5515W 55" Rear Projection...
Squigly lines run across screen cannot take pictures.
If its Canon A75 camera then its problem of defective ccd imager and Canon will repair your camera free of cost.
Click Canon CCD Imager Advisory for details.
Apr 30, 2009 | Canon PowerShot A75 Digital Camera
Jvc 56wp74
sounds like a solder related issue on the convergence ICs. They are acessed through the front of the TV behind the speaker grille and then remove the small acess panel and you will see the convergence amp board with the two ICs on it.
Oct 26, 2008 | JVC AV-56WP74 56" Rear Projection...
Toshiba 57H81Problems Please Help
On this model I've found the hyper module to cause lines (Left to right) in the picture. Usually at start up and half the screen, then after warm up, the set will clear up some or completely. Of course a picture of the problem would help in diagnostics. The hyper module must be soldered in, so, knowledge of soldering is advised. This PCB can be bought at: Andrews Electroncis or Tritronics. I do this job in the home, pick up for service should not be required.
Jan 06, 2007 | Toshiba 57H81 57" Rear Projection...
Video input from dvd player shows as black screen w/ squigly color lines
have you tried other devices for input...vcr, or other dvd players to see if it is a problem with the player or with the tv? Check the output setting for the dvd player (1080i etc) and ensure you are connecting to the proper inputs for either analog or digital signals (RCA inputs or RGB).
Aug 15, 2006 | Hitachi 57S715 57" Rear Projection HDTV
Toshiba 50H13 50" Rear Projection Television Logo
109 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
