Question about HP LaserJet 4250dtn Printer
Error 60 02 on a HP LJ 4250DTN
I got an Error 60.02 on HP LJ 4250DTN and it will not print how can I get a service manual that shows the controller board.
My enail is ken.shaw1 @us.army.mil
  • 3 more comments
  • Anonymous Feb 08, 2008
    I have the same error and it intermittently has said a paper drawer is open.
  • dizzie_684 Mar 11, 2008
    I am getting this same error however its on the HP LaserJet 4250n printer. It is still brand new, only 2 months old. I powered off the printer, removed all paper from the paper tray but the 60.02 error is still being displayed on the control panel and will not print. Please help!
  • durgi Apr 19, 2008
    there is 60.02 error in hp 4250n
  • edgar_pulgar Sep 29, 2008
    13.20.00
  • Anonymous Mar 12, 2014
    printer is not printing showing error printing while printing
  • 26 Answers
60.2
printer error
The tray 2 lifter-motor is not functioning. 1 Turn the printer off and then on.
2 If the error persists, turn the printer off.
3 Verify that the tray 2 lifter wire-harness
is full seated in its connector on the
dc controller PCA (location J93).
4 Replace the tray 2 lifter-driver
assembly. See Tray 2 lifter-drive
assembly.
5 Replace the dc controller PCA. See
Posted on Jan 11, 2008
  • 34 Answers
If you get into the printer and you see the liftter motor, it has a spring on the top of it. If that little spring is not visible, or not there you will get this error too. even if the motor is good.
Posted on Mar 14, 2009
  • 14 Answers
The paper tray by itself can also be the cause of a 60.02 error in the Laserjet 4200, 4250, 4300 and 4350 series of HP printers.
Posted on Jun 29, 2008
Uuyyyyy... buenissiimooo... gracias.. me sacaron de un lio... muy buena la solución....
Posted on Jan 16, 2008
Need to perfrom nvram init on HP 4250
To initialize NVRAM, turn the printer power off. Remove any installed accessories (for example, a stapler/stacker). Turn the printer power on, and then hold down (SELECT button) when the memory count begins. Continue holding down until all three printer control-panel lights flash once and then remain on. This might take up to 10 seconds. Press (UP ARROW button). Press the PAUSE/RESUME button (LJ 4200/4300) or the MENU button (LJ 4250/4350). The display should show SKIP DISK LOAD. Press (UP ARROW button) until NVRAM INIT is highlighted. Press (SELECT button) the printer initializes NVRAM and then continues its power-on sequence.
Nov 07, 2012 | HP Laserjet 4250dn Network Laser Printer...
MY PRINTER hp laserget 4250 dtn is displaying 57.4 error when I turned it on, what can I do? I am ofetn requested to suitch off and then to switch on but it fails to mark " Ready"
57.4 Main fan error
Hi I hope this will help
The text come from the hp manual
good luck Ian
Q2431-90912 Chapter 7 Troubleshooting 287
57.X
PRINTER ERROR
To continue turn off then on
or
57.3
EP FAN FAILURE
or
57.4
MAIN FAN FAILURE
A printer fan is not functioning.
X Description
3 EP cartridge fan, right side
(LJ 4300 only)
4 Main cooling fan, left side
57.3 Cartridge fan error (F2)
1. Reconnect the connector
between the fan and the
DC controller PCA
(location J78).
2. Replace the fan. See "Cooling
fan (right side;
HP LaserJet 4300 series
printer only)" on page 170.
3. Replace the
DC controller PCA. See
"DC controller PCA" on
page 181.
57.4 Main fan error (F1)
power supply.
2. Verify that the ribbon cables
are fully seated in the
connectors on the
DC controller PCA.
3. Replace the fan. See "Main
cooling fan (left side)" on
page 168.
4. Replace the power supply.
See "Power supply" on
page 188.
5. Replace the
page 181.
57.7
DUPLEX FAN FAILURE
The cooling fan in the optional
duplexer is not functioning.
1. Turn the printer off and then
on.
2. Replace the duplexer.
Mar 25, 2011 | HP LaserJet 4250dtn Printer
Marca error 60,02
60.2
assembly.
Dc controller PCA.
Aug 09, 2010 | HP LaserJet 4250dtn Printer
59.40 error code
That's a main motor error, something could be jammed in transport, or a generic toner cart. that is too hard to turn, try powering on with toner removed...
Aug 20, 2009 | HP 4250 Monochrome LaserJet Printer
Looking for a manual
You can download your manual from
www.generalmanual.com/Printers/HP-LaserJet-4250dtn-Printer.htm
Hope my info solves your problem,
Thanx for using fixya.
Sep 30, 2008 | HP LaserJet 4250dtn Printer
HP LJ4250dtn 49.5F11 Service Error
49.xxxx error occurs when the printer does not understand the Print Job Language. Following could be the reason:
  • Faulty Network Cable/Port
  • Corrupt Driver
  • Firmware of the printer and the Jetdirect Interface.
  • Corrupt file.
  • Corrupt Print job.
  • Less memory or corrupt memory DIMM
Hence to start with, please let me know when do you get the error. Is it when you powercycle the printer.
Please perform the following:
  • Upgrade the firmware of the printer and the jetdirect card.
  • Change the driver and install the UPD drivers.
Let me know the next update...
- Nikhil
Aug 07, 2008 | HP LaserJet 4250dtn Printer
HP Laserjet 1320n Error Lights not in Manual
hi friends......
shivachadra is here.....just i faced this problem "Attention, Ready, and GO LEDs are on solid"
and i got solution in troubleshooting....just vi refixe the connetion of laser scanner........its the error of comunication between laser scanner and formatter....
May 27, 2008 | HP LaserJet 1320 Printer
HP 2430tn lj printer with 13.20 jam inside top cover error
What is the exact error message shown on the display ?
Does it makes any strange noise when you start it up ?
Dec 31, 2007 | HP LaserJet 2420 Printer
Printer error
What make of printer, what model. Under what conditions does the error occur? Please give at least some detail.
Oct 10, 2007 | Office Equipment & Supplies
HP LaserJet 4250dtn Printer Logo
12,739 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
