I have an acomdata 1tb XHD. The status light is blue, but XP wont recognize. I have already tested the cable and the USB port on the CPU.
  • 358 Answers
First of all make sure that the USB port that you are using to connect it to your PC is a USB 2.0 port, and not USB 1.0.
Also if it came with an external power, connect it to the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is lower than that of USB 2.0 and therefore might not be enough to power up your USB Drive.
After making sure about this, power up your system, and plug the harddrive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your harddrive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your harddrive to be detected automatically.
In case it still doesnt work after trying this, then do this:
Unscrew the hard drive case and remove the Hard disk from the case, connect it directly to a system, not externally or through USB this time around, then get a software called NTFS DOS Professional. It is a software that works like magic when it comes to hard drive repairs.
If you know any other hard drive utility, apart from this, you can also use it. I just recommend this personally because that is what I use.
Insert it into your PC, start up your CD-ROM and let your system boot from CD-ROM.
It works through DOS, and it should be able to help you with it.
If this does not solve the problem, then I'm afraid you might need to replace the hard drive.
And if it repairs it, I would suggest that you just retrieve all your valuable files from it and don't fully rely on the hard drive again because of the hardware error it has developed. Just keep using it as a second.
If you cannot do this by yourself, just get a very good technician to do it for you instead.
Kindly keep me posted about the problem.
Hope it helps.
Goodluck.
Posted on Nov 23, 2009
Acomdata external hard USB hard drive model HD160UE5-72 worked fine then suddenly the device was not recognized. Reboot with unit powerered up and the device is not detected. Blue LED is on, tried...
Either the hard drive is bogus or the electronics of the external adapter is the culprit. Take out drive and hookl directly to mo bo as a secondary drive. If recognized drive is ok and the box is at fault.
Aug 25, 2017 | Acomdata (HD160UE5-72) (HD160UE572) 160 GB...
I plug it in and the blue light comes on but it's not detected
If this is windows, especially windows xp, the first thing i wuold do is try one of the back ports, and if you already plugged it in the back, a different port.
Windows XP is notorious for putting certain usb ports aside for devices that once occupied that slot.
If that doesn't work, and you have some computer skills, I would try another operating system or another machine.
A good test would be to either take it to you local library and see if a pc there recognizes it or if you can get your hands on a cd booting linux os like Ubuntu and then plug it in, that could help.
I'm afraid thats really all i can do from here. It might be that the device has gone bad, but you wont know unless you can test it on another pc and/or operating system to see if you get the same lack of response.
Oct 27, 2010 | Memorex Ultra Traveldrive - 160GB USB Hard...
My hard drive doesn't show up
If the external hard drive is not detected by yur computer, try first connecting the drive on a different USB port so we can test the USB port and then after that if still not yet detected try a different USB cable to test the cable and after that still not detected connect the drive on different computer so we can see if this is already a hardware problem.....
Jan 05, 2010 | Sabrent eSATA External Drive Case
External hardrive not recognized
Try a different cable between the computer and the drive.
Disassemble the casing, and remove the "internal" disk-drive.
If the USB-to-disk-drive adapter has "died", it's possible that the
disk-drive itself is intact, and your data will be intact.
Connect the "internal" disk-drive as a "slave" drive in a desktop computer, and see if it can be detected.
If it's dead, and it's still under warranty, then exercise the warranty.
Jan 04, 2010 | Acomdata 1TB Puredrive USB Esata 1 TB Hard...
Acomdata 1TB external drive
I have the same exact drive (I'm assuming as it's the same make/size since I don't have a model number) and what you need to do is turn the drive off and let it cool down. The drive is not well vented and it tends to over heat. I would get in the habit of turning the drive off whenever you're not using it because of this problem.
Sep 25, 2009 | Acomdata 1TB Puredrive USB Esata 1 TB Hard...
The red light is staying on on my Acomdata 1TB Puredrive USB Esata 1 TB Hard Drive and the computer will not recognize it.
I would say take the drive out and if you have SATA connectors on your motherboard, connect it directly to you computer and see if the computer will recognize it.  If it does, your enclosure is bad.
Mar 04, 2009 | Acomdata 1TB Puredrive USB Esata 1 TB Hard...
Drive not recognized by desktop.
Try checking your power cord adapter.
I found the same problem was with the cord.
Luckily, I had another Acomdata HD cord to check the problem.
Aug 25, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Acomdata no longer recognized
Check your USB Cable connected possible lost contact problem or the power supply of your optical drive.
Hope this will be helpful to you.
Oct 25, 2007 | Acomdata E5 (HD080FE5-72) 80 GB FireWire...
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
