Question about Car Audio & Video
WILL A EONON E1091 OR A E1022 FIT IN MY 1992 FORD MUSTANG
  • Anonymous Mar 27, 2014
    It does not read discs
How do you fix the disc read error problem?...
Posted on Feb 11, 2011
Were is thefuel pump reset switch at on a 1992
usually in the trunk area either on the right or left under the lining material.
Oct 04, 2014 | 1992 Ford Mustang
1992 ford probe gt 2.2l turbo no spark have changed plugs wires cap rotor coil distributer
1989 ford probe turbo 2.2L turbo the oil filter sandwich block thats adapted to the block of the motor... the Hole that comes out block and from where the sandwich adapter mounts to the block... is there suppose be some sorta plug or fitting there? is there possible get detailed picture so i know what im missing?
i have hole and ******** oil out... and trying get fixed so i can sell the car... to fix my current problem no motor for a mustang 5.0 gt so if anyone can help me out id greatly apppericate it...
Mar 07, 2011 | 1992 Ford Probe
I recently wired a eonon e1091 into a 2007 silverado classic. i used a scosche wiring harness that allows me to keep my chimes. everything works fine but when i turn the truck off, theres still power...
It's called delayed acc. power. It should shut off as soon as you open the door. Unless the red stereo wire is hooked up to constant power. You may need to check with a test light.
Oct 31, 2010 | Car Audio & Video
Where is fuel filter located on my 1992 ford mustang gt 5.0
The fuel filter is located on the rail under your car. Sometimes hard to find because the put a metal guard around it. Yours should be on the drivers side. Good luck
Feb 08, 2010 | 1992 Ford Mustang
Can I install the eonon 1091 in an 1999 acura RL?
Hello anthony_owen,
No, it won't fit.
The Eonon E1091 is a "double din" unit that requires at least a 4" tall opening to slide into. Your Acura has a "Euro-din" opening that is only 2" tall.
Hope this helps.
Oct 14, 2009 | Car Audio & Video
How to change a 1992 ford mustang gt 5.0 front wheel bearing
remove caliper and bracket, remove rotor. bearing is bolted on or pressed on spindle,hope this helps.
Oct 10, 2009 | 1992 Ford Mustang
1992 ford mustang lx 2.3L will not start
The crankshaft sensor went bad. I Was'nt getting any fire from the coil pack. Tried switching coils and still nothing, tried switching ignition modual, nothing. I checked to make sure it was in time and it was. Nothing left to check so I changed the crank sensor and it firerd right up! Thanks.
Jun 13, 2009 | 1992 Ford Mustang
Car Audio & Video Logo
289 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
