Question about Amana ALW880WH Top Load Washer
Seems like there is no pressure coming out of cold water tap
    Guru:
  • 1,738 Answers
Your mixer value.
Posted on Nov 19, 2009
2 Suggested Answers
  • 32 Answers
SOURCE: Cold water only trickling into my washing machine
unfortunately it sounds like you have a stuck plunger in the cold side of your water inlet valve.if the screens are clear and your water pressure is good,thats what you have.
Posted on Sep 28, 2008
Why no water will come out of the water heater
Is there a shutoff on the hot water line coming out of the tank? Is this problem only at one tap or all of the taps in the house? Is the cold water supply to the tank turned off? If it is no water will flow since the cold water pressure pushes the hot out of the tank.
Aug 29, 2014 | Water Heaters
Low pressure coming from Hot Water Tap
Were is the water boiler located.
Feb 20, 2014 | Water Heaters
Cold water pressure poor in shower. Just had Rheem installed.
You might have clog in water lines.
If shower is only place where low pressure exists, then clog is probably at shower valve.
Disassemble valve and see if clog will flush out.
From there, you have to keep moving back along cold water line looking for pipe filled with sediment or elbow that has obstruction.
If pressure problem is bad at every cold tap, but doesn't affect Hot water, then clog is inside Cold line somewhere after water heater connects to cold line.
Buy a pressure gauge that connects to water hose.
Buy adapter that also fits pipe thread.
For example Brady BTG 100.
Test outdoor spigot for baseline pressure.
Open cold tap inside house and see how much pressure drops.
Close cold line and open hot tap and see how much pressure drops.
Next, move pressure gauge along cold water line.
Take apart pipes and inspect for obstruction at elbow or pipes filled with sediment.
Look for any place galvanized pipe connects to copper pipe, since this will be likely place for obstruction because of bi-metal corrosion.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on pipes.
Jan 05, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
I have installed a Grundfos CH2050PT pressure booster system at my home (3 stories). The pumps is installed at ground level and is connected to the main water tank (source of water). The pressure is...
it could be the differential in pressure between the cold water from your booster pump and the hot water from your solar water heater . the cold water which feeds your solar heater is probably being reduced in pressure by a pressure reducing valve . so what you need is equal pressure on both your hot and cold water system you could install a pressure reducing valve on the pipe thart feeds your cold taps etc valve set at the same pressure as the one on the solar water heater that would give you a balanced hot and cold water system
Dec 07, 2010 | Grundfos JPS4 1 HP Pressure Booster Pump
No water pressure
Check all valves are open, cold in bottom, pushes hot out top, and if cold at tap is doing same, take aerator off tap and see what happens. Is same thing happening at all taps?
Apr 25, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
I have a combi boiler and a 'popping' hot tap
the lock nut has either come loose under the handel or the 'o' ring and stem have loosened up, might this be a delta faucet? if so replace the cartridge "stem" and the o-ring and spring you will be fine,,
Jun 09, 2009 | Rheem Tankless water heater for 1-2...
Sep 25, 2008 | Washing Machines
Changed cold valve
What brand and model do you have, most domestic units have a combination hot/cold valve? You just need a meter too verify the valve is closing, if the valve solenoid is closing you may be having a water pressure issue, too much water pressure can cause leaks.
Jul 29, 2008 | Washing Machines
Amana ALW880WH Top Load Washer Logo
Top Amana Washing Machines Experts
Charles T Nevin
Charles T Nevin
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
