Question about Ford 8N Tractor
Looking for a fuse box for a Ford Tractor 3930. The fuel and temp gages on the dash want work and are pegged to the max. I think it might be a fuse but cant find the fuse box nor the owners manual. Any help will be appreciated.
emissionwiz
  • 80637 Answers
SOURCE: 2002 Ford Mustang convertible fuse box
Here it is please rate this as a FIXYA if it helps, follow this link for a picture of your fuse box.
http://i143.photobucket.com/albums/r152/mharner6/fusepanel.jpg
Posted on Sep 05, 2008
short shadey
  • 421 Answers
go buy a cheap test light from a parts store they cost about ten bucks and you can test every single fuse quickly and easily by attaching the clip end to a bare metal surface in the car and touching the tip of the probe with the key on to either side of each fuse on the head of the fuse very quick and easy and you'll use it all the time please rate -jeff
  • 1201 Answers
SOURCE: no dash lights on a 1985 ford f150.. replaced all the bulbs, fuse box cover is missing and no manual, so which fuse do I check?
Facing fuse box, left hand side, bottom fuse
Posted on Jan 21, 2009
  • 104 Answers
SOURCE: Radiator cooling fan fuse location for Ford Taurus
The cooling fan on a ford car usually does not have a fuse. The cooling fans are controlled by a relay in the power distribution box inside the engine compartment. The box is usually located near the battery. Your owners manual should have a guide showing you what each relay in the box is for.
Posted on Jul 15, 2009
  • 52 Answers
SOURCE: windshield washer pump stopped working,
Fuse 113 which is a 30A fuse controls the front wiper motor and washer pump. You can also download another copy of the owners manual from Ford at https://www.fleet.ford.com/maintenance/owners_manuals/results.asp . Hope this helps.
Posted on Mar 30, 2010
Where is the gages located for fuel, battery,& temp on 2002 olds bravada
Check for a blown fuse under the dash. It will be marked gauges or instruments.
Jun 14, 2017 | Cars & Trucks
1982 s10 dash cluster wire harness looking for 12v source for fuel gauge or wires for fuel gauge
As long as it is ignition feed, it goes hot with the key on. The circuit is dead with the key off. It should work.
There may be a gage fuse in your fuse box? As long as the circuit is dead with the key off.
I don't have wiring info for your model year.
Apr 14, 2017 | Chevrolet S 10 Cars & Trucks
Does a 3930 ford tractor have a engine heater ?
if you do not get a response from a shop , go google and type in --- engine heater for ford 3930 tractor-- there are many tractor sites that you can call by phone that will have the answer
Nov 20, 2016 | Office Equipment & Supplies
Temp gage on dash stays at low and i have no heat coming out from any vent just air,
If you have checked the radiator coolant level and it is correct, I would think that maybe your thermostat is stuck in the open position which will not allow your engine to come to the proper operating temperature.
Dec 29, 2012 | 2002 Chevrolet Cavalier
I have a 2004 xg350 all of my gages example- fuel gage, speedometer, temp. no dash gages work at all, I did check the fuses but my eyes are not what they used to be so I could have missed one, these fuses...
Cheaper to start with fuses but It could also be the relay box if you look at the back of the cover that is covering the fuse box there should be a diagram showing were each fuse.
Not 100% shore but worth checking as there could also a fuse box with fuses and relays in the engine bay
Let me know if this helps
Regards Craig
Feb 09, 2018 | Hyundai XG350 Cars & Trucks
The fuel and temperature gauges are pegged out on my Suzuki samurai. The fuel gauge is always pegged out and the temperature gauge is low when first started then goes to max temperature in about a minute....
I just had a similar issue with my 1995 Buick century. My issue started out with the gage being almost pegged with the car off. When I turned the key to run it pegged the gage completely. I first called AutoZone and they told me it was either the temperature sensor, thermostat, or gage.
I knew that my thermostat wasn’t bad because I replaced it a while back. I then checked my sensor; I unhooked the two pin connector of this sensor at the block and suspected the needle to drop to zero. This was not the case.
I then checked my wires using a multimeter to verify that there was no short at my firewall. My wiring was fine.
I then called a family mechanic and he instructed me that there is also a "temperature switch" that also is interconnected to the coolant temperature gage. I then found this switch which was threaded into the block near the firewall of my car. I unhooked the 2 pin connector and suspected that the gage would return to the neutral position. And sure enough it did!!
This could have been a heck of a lot easier if AutoZone could have told me that my car has a "temperature switch". But non the less it was only a $15 fix!
First try unhooking your sensors and switch to see if this is the problem, I would lastly suspect your gage to fail!
Good Luck
Jun 26, 2009 | Suzuki Samurai Cars & Trucks
Fuel gage jumping around and truck stalling out
go to the battery follow the cable that dose not go to the starter the other cable will go to hard piont that is the feed for the fuse box check that connection
Jan 23, 2009 | 1997 GMC Jimmy
The dash gages are not working, fuel gage, speedo, temp gage
Is this the only problem? How did you check the fuses?
Dec 28, 2008 | 1996 Mitsubishi Eclipse
Ford 8N Tractor Logo
356 people viewed this question
Top Ford Toys Experts
Philip Doherty
Level 1 Expert
Rob Woolcock
Rob Woolcock
George Christ
Are you a Ford Toy Expert? Answer questions, earn points and help others
