Question about Cameras
Panasonic Lumix DMC-FX100 focus problem
I have a problem with an aged and well used fx100. when turned on the lens goes out and in and out again and then it (sometimes) works in normal or macro mode. Often though it won't focus on certain modes but when you scroll it around to another mode it does work. I initially thought that the problem was hardware as I have read of other focus issues where the lens goes in and out a few times - but the point with mine is that it does work on some modes all the time but the modes it works with vary. Question is, is there there somewhere where I can download some new firmware?
jyackle5
  • 8197 Answers
SOURCE: lost manual panasonic dmc-fx100
You can download the manual here.
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Digital-Cameras/Lumix-Digital-Cameras/model.DMC-FX100K
Good luck and please rate FixYa!
Posted on Apr 12, 2009
  • 411 Answers
SOURCE: lens sticks out when lumix dmc-fx100 turned off
disassemble the len unit,replace the broken parts and assemble,if u can do OKif not get it done by camera tec.
Posted on Mar 09, 2010
Testimonial: "Thanks so much! I think I had better go to a tech!"
  • 11967 Answers
SOURCE: panasonic lumix dmc-fx100 problem
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 10, 2010
dj_relly999
  • 4070 Answers
SOURCE: I want to download Simple
Hi! Please click on the manual I provided to serve as a guide. Pay good attention on page 24. Hope this helps and thank you for using FixYa! Please click here http://service.us.panasonic.com/OPERMANPDF/DMCFX100%20PC%20CONN.PDF
Posted on Oct 11, 2010
  • 102366 Answers
SOURCE: Describe your how to change
Press [MENU/SET] to display the menu. Press cursor-left, use cursor-up/down to select the wrench icon, then press cursor-right. Use cursor-up/down to select the speech bubble icon.
Full instructions are in the "Setting the Menu" section of the manual, especially the "Language" subsection (pages 17 and 21 in my copy). If you need a manual, you can download one at
http://service.us.panasonic.com/OPERMANPDF/DMCFX100.PDF
Posted on Jun 27, 2011
Software download panasonic lumix dmc-fx100
If you are missing the disc you might also be missing the user manual for your device, so besides downloading the software I suggest you also download the user manual:
Panasonic DMC FX100 manual
Nov 11, 2012 | Panasonic Lumix DMC-FX100 Digital Camera
Someone was looking through my photos on playback mode on my panasonic DMC-FX100. Then gave it back and now it says "no valid picture to play". not sure if they multi deleted everything. No photos are...
It's no problem at all to get them back. Please see this post for several free software that you can download. You'll need to use a card reader with these programs though:
All the download links listed in the article are through CNET, primarily to verify that these are malware free software, and to give you a chance to read user reviews on the software before downloading.
Sep 12, 2010 | Panasonic Lumix DMC-FX100 Digital Camera
Message saying please turn camera off and then on again on DMC Fx100. When turned off and on again message just re-appears
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Aug 15, 2010 | Panasonic Lumix DMC-FX100 Digital Camera
Lens sticks out when lumix dmc-fx100 turned off
Mar 09, 2010 | Panasonic Lumix DMC-FX100 Digital Camera
Lens wont move, turn it on and it just sits there making mechanical noises
I have Panasonic DMC-FX100 , Lumix 12 Mega Pixels.
When I on my camera its shows that "Please turn camera off and turn on again." when I turn off the lence cannot shut down , it makes noise. When I turn on, the lence move again but cannot turn off.
Oct 02, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Turn the camera off and on - can't do anything!
I have the same problem. I contacted Panasonic and they will attempt a repair. I really have no other alternative than junking the camera.
Aug 03, 2009 | Panasonic Lumix DMC-FX100 Digital Camera
SHOWS TURN OFF-ON THE CAMERA VERY OFTEN WHY? when I take pictures or when I´m reviewing the pictures.
your batteries may be low.. recharge them or replace them with the new ones.. if your problem persists i am here.. let me know/.
Jul 10, 2009 | Panasonic Lumix DMC-FX100 Digital Camera
Panasonic dmc-fx100
The manual can be found in the link below.
DMC-LZ2 Instruction Manual
Mar 26, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
Cameras Logo
155 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
