PackardBell easynote MX37 charger get so hot it melts the cable! I have bought 3 chargers now and the all melt. It is the correct chrger for the computer as stated on the sticker under the computer and has a 5.5 * 2.5mm connector. My stepdad had it in skye who does computers and he put his jack in which was a multi connector type one and had it on for 2 days straight and barely got warm! Soon as i got home i put my new one in and its started melting the plastic around the connector in less than 15 mins! Whats wrong!?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 109 Answers
Where did you purchase the adapters from? You say they are correct because they match the specification on the bottom, but that does not mean they are of high enough quality to handle the contact power pull that a laptop gives.
If you bought these directly for PackardBell then contact them to get a refund and report your issues. If they are aftermarket adapters then the quality of the adaptor is not high enough for your laptop. Since your stepdad has an adaptor that works well with it, then find out what brand it is and try to purchase the same model as he has.
Posted on Dec 31, 2009
My samsung laptop charger gets hot and starts to melt when pluged in and powered up and does the same if i take the battery out please helptried a new battery and new charger could it be the jack on the...
I'm unclear however
Does the new charger get too hot? If so the problem is not the charger or the socket.
Does the laptop work with the new charger plugged in but no battery? If so the socket on the laptop is probably ok
Is the actual charger melting or is it just the plug that goes in the laptop that's getting hot, if it is the plug on both chargers then the socket will need repairing or resoldering, they are a weak point, the soldered pins go high resistance and can generate a lot of heat around the plug and socket. Its usually obvious if the socket is faulty because as you move the plug it makes contact intermittently.
DONT USE THE CHARGER THAT'S MELTING and if both are getting hot have the socket repaired.
If only the one charger getting hot the short is probably in the plug on that charger but read on
On a different note the genuine chargers should be over current protected and overheat protected, they should never melt.
May 13, 2014 | Samsung Rv511 Series Laptop Intel I-core...
Why did my RYOBI charger melt on a job sight counter top and how can they not have a suport number when thing like this happens lost alot on this product why the melt down of the charger ?
I have no idea unless it was possibly plugged into a 220 outlet by mistake, I suggest you call RYOBI direct and ask their service department what might be the cause.
Jan 12, 2012 | Ryobi Drills
My samsung RV511 laptop seems to be overheating a lot. Whenever the computer is under a heavy load it just shuts off. I bought 2 different cooling mats and they do not help. It is to the point now that...
Check the cooling fan at the bottem of the laptop see if is working ,also use a can of compressed air and blow out the fan give it a thorough cleaning if need you might have to replace the fan .If you will supply me with a model number I will get instructions on how to disassemble to put in a new fan
Sep 07, 2011 | Computers & Internet
My blackberry 2 storm wont turn on
These type of problems are hard to diagnose. But first start with power. If using the home charger, try the car charger. If both do not work, check the battery to see if it's seated correctly. Are you using an OEM "original equipment manufacturer" charger. If you use a charger bought from a 7-11 then you may have burnt out part of your phone. Use a friends battery that has a phone like yours. If that works and it's out of warranty, buy a charger and charge batteries on a chrger, then insert them into phone each time. Got insurance on phone?
Sep 15, 2010 | Cell Phones
Completely dead and won't come on
Sep 15, 2010 | Nokia E63 Cell Phone
Melted Power Adaptore on a Asus eeepc 900ha
you need to contact the manufactuer if it melting plasic its gettting way to hot. if it catchs fire they are responsible contact them so they can either repair it or replace it
Vote me 10 for this solution
Jan 06, 2010 | ASUS COMPUTER INTL EPC900HABLK006X: Eee...
Compaq presario v2000 charging plug melted and will not charge
The problem maybe with the electrical circuit. Find an electrician to check it.
Mar 18, 2009 | HP Compaq Presario v3000z Notebook
Laptop charger melting
The cause was high resistance in the charger, probably from a poor solder joint. It is likely your laptop was not damaged. You can use another charger.
Mar 01, 2009 | Computers & Internet
Intergrated web cam!
ok try on the following link and navigate to 'Drivers & Download'
www.packardbell.com
Make a search for your 'Service Tag No', it will list you all the drivers required for your machine. And you can easily make download.
Thanks
Iqbal
Mar 09, 2008 | Computers & Internet
Computers & Internet Logo
201 people viewed this question
David Payne
David Payne
