Question about Brother IntelliFAX 3800 Plain Paper Laser Fax
Wide black lines down the paper. I have changed
Wide black lines down the paper. I have changed the cartridge but still get them
    Sergeant:
  • 329 Answers
Have you changed the Drum unit. Also there is a cleaning pad that you slide across the corona for cleaning. If you leave it in the middle it will give a black line, should be moved all the way to one side.
Posted on Nov 19, 2009
Just replaced black cartridge in my 2600n color laser. I have smudged about a half inch wide 2/3rds over the right of each page. It only smudges in black. I have recalibrated several times. Printed at...
If this just started after you replaced the toner cartridge, one would have to say that it is a bad toner cartridge.
Print something that smudges. Pull down the front cover and look at the cartridges. Pay attention to the top one(black).
Look at the drum on that cartridge. You should see the toner sitting there. Compare it to the other cartridges which should be clean.
Feb 08, 2011 | HP Color LaserJet 2600n Printer
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
May 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
Black vertical stripes on copy
Replace the drum unit, you've done all the cleaning you can do.
Jan 23, 2009 | Brother IntelliFAX 3800 Plain Paper Laser...
Printing 1 1/2" down right side of paper
You have a defective toner cartridge, drum should be clean when you looked at it, the blade is failing. Is the cartridge remanufactured (or compatible)? Although they usually work well (depending on the supplier) there are sometimes defects
Nov 25, 2008 | Canon PC-980 Color Copier
Brother hl-1440 laser printer
Did you mean 'vertical' (from top to bottom) line rather than horizontal? If it goes 'straight down,' it has to be. I think so, otherwise the added info that it is closer to the right wouldn't make sense.
This problem is normally due to contaminents on the surface of the drum itself although can also occur if a wire that discharges the excess toner from blank areas could be dirty.
Changing the drum cartridge will correct either of those problems since they are contained in the drum cartridge. If you are using 'recharged' cartridges and it only has a few copies on it, most companies will exchange it for you.
Oct 23, 2008 | Brother HL 1440 Laser Printer
Is there any debris under the printhead nozzle plate?
Jun 22, 2008 | Epson Stylus Pro 4800 InkJet Printer
Black line
take out cartridge, look at he inside of machineis there toner on the left side of a thin glass, look at the fuser ( where it gets hot) are the rollers O.K. ?
Nov 27, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
Brother IntelliFAX 3800 Plain Paper Laser Fax Logo
752 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
