Question about Samsung LE32R74BDX 32 in. HD-Ready LCD Television
My 32 inch samsung lcd tv has got faint black lines running down the screen ,its nearly 4 years old but i expected it to last longer than that,and ive had sky hd box recently would that have anything todo with it?
    President:
  • 1,284 Answers
Are these lines on both side of the screen or what location are they in? They can be caused by watching 4:3 television with the black bars on both sides. Watching 16:9 full screen HD wont cause issues with that. If only on the sides there is not much you can do except put a pure white screen on the TV and leave that on for at least 6 hours. This will age the panel a little but in theroy wil even the pixel burn you have to make the lines less noticable. Please take a few moments to rate my answer. Thank you
Posted on Nov 18, 2009
  • dannyq52 Sep 20, 2010
    Hi ive had the same problem, but the lines are vertical lines across the screen and theres a few of them streching about half way , they seem to better when the screen has nice bright colours
  • Trooper Rick Nov 22, 2010
    I have the same exact problem with my 32" LCD. It started a month ago and has steadly gotten worse. Please email if you found a solution. Thanks, Rick.
I have a ln-s3238d that i got a couple years ago. Last month it started getting a line of pixels running across the top of the screen. over the last month that problem has gron to four lines on top and...
Hi andrew, its not a big problem.. Decent TV. but the pixels are DEAD. that means you have to recover them by fixing the LCD. this would cost you around £40-60 for a 32 inch TV. hope this helps!
Nov 05, 2010 | Samsung LN-S3238D 32 in. LCD HDTV
SAMSUNG LE40M86BD very thin black line
The screen is failing. A conductive strip from a flex connector to the glass panel is losing contact when cold. Any warranty left? extended warranty? Usually not repairable, screen has to be replaced and cost as much as a new set....
Mar 24, 2010 | Televison & Video
Lcd tv has black cloudy line from top of screen about 1 inch wide and 4-5 inch long down the screen
This problem is not just for Philips. I've found similar complaints online for JVC, and my Vizio 32" LCD has the same problem. In my case the TV is about 3 years old and has a lot of hours on it.
Oct 23, 2009 | Philips Televison & Video
Vertical colour lines on whole screen
The problem is that the panel has failed. Apparently this is a common problem with LCD TV's between 18 mths and 3 yrs old. If it survives over 3 yrs it is likely to last for a few years longer. The cost of replacing the panel is more than a replacement TV!
May 25, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Faint Vertical lines on Samsung LCD TV
Your correct, LCD's don't burn. This sounds like a defective main control module. I would take it in as soon as possible to have it looked at.
May 03, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
Thick faint lines on screen
It sounds like it could be the cable. Does the same thing happen on all channels and all TV's?
Jan 06, 2009 | Norcent Technologies LT-3225 32 in. LCD...
Red pixel cloud in plasma black
THIS IS THE START OF THE PLASMA GAS RUNNING OUT...PLASMA TVS ONLY LAST 4 TO 5 YEARS THE GAS JUST BURNS OUT....LCD TVS LAST ALOT LONGER UP TO 10 YEARS..
Dec 29, 2008 | Samsung PS42P2S 42 in. Plasma Television
TV BLEWUP
What would cause that is failure of some part (probably a filter capacitor) in the set's power supply. The usual cause is component stress due to manufacturers keeping their costs down by using parts that just barely can stand their operating voltages. (Higher rated parts would last longer, but would cost more.) Some parts are just a little too weak and break down. It's not unusual to have this kind of problem these days. The set would be repairable unless there was physical damage to the circuit board itself. You might have it looked at and get an estimate for the repair.
Nov 22, 2008 | Samsung 32 in. LCD Monitor TV
Complete black screen on samsung 46 inches
Thats Samsung for you. They are designed to last just right outside the warranty then fail. Typically the LCD panels are bad, and they are the most expensive part on that Korean unit.
Sep 07, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Vertical Black line 3 inch width on Plasma Samsung 42C96HD after 2 months of use
On al the plasma tvs there are control boards on the lower part of the screen that control the vertical images. If one of the chips on one of the boards fail, have a bad connection, or no ground it will result in a thick black lne down the screen. Seeing as the tv is new I would get the warrantee repair on it. There is a possibility that there is a problem with the screen itself but more than likely its the boards.
Aug 09, 2008 | RCA L26WD26D 26 in. LCD TV
Samsung LE32R74BDX 32 in. HD-Ready LCD Television Logo
825 people viewed this question
Jerry Greenberg
Jerry Greenberg
