Question about LG 42LC2D 42 in. LCD HDTV
Tv vibrates & buzzes. more with female voices
    President:
  • 1,284 Answers
It sounds like the cabinet is causing the issue. You might want to go around to all of the back screws on the TV and give them just a quarter of a tun and see if that helps. If that does nothing for it then possibly one of the speakers is bad. This can be confirmed by placing the balance control towards the left speaker first and listen to see if it still happens. If it does shift the balance to the right. If it stops then you know the left speaker is defective. The part number for the speakers are as follows. I doubt the tweeters are the issue, but I thought I'd get you the part numbers anyway. Please take a few moments to rate my answer, Thank you...
Woofers are part number EAB30829201
Tweeters are part number EAB30825601
Posted on Nov 18, 2009
Testimonial: "great advise dude"
Is it true that the voice actor for Bart is actually female?
Yes, it's true. Nancy Cartwright has voiced Bart all the way throughout the show.
Sep 04, 2016 | The Simpsons (1989)
Is there a way I can fix the low static sound on my Magnavox DVD player
Magnavox tv has loud static - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-2293282/magnavox-loud-static.html
Sep 9, 2014 - After a loud clap of thunder my magnavox tv with built in dvd and vcr developed static sound ... JVC DVD player and Samsung VCR to my new MagnavoxHDMI TV ... Can you connect the cable box with a HDMI cable or component ... and making a loud humming sound how do I fix help · Burning in of static ...
What is that TV Buzzing Noise? - noice fix brokentv ' Ask MetaFilter
ask.metafilter.com/17525/What-is-that-TV-Buzzing-Noise
Apr 14, 2005 - My TV does this annoying buzzing sort of humming noise (vibrating?) ... It especially seems to do it when I have the volume turned down low (or else I just don't notice .... The capacitors in there can store a charge large enough to kill you for 12 hours or more. ... Although, I feel like I hear it more often on DVD.
HOW TO FIX VCR & DVD PLAYERS REVIEW - YouTube
? 9:23
https://www.youtube.com/watch?v=1ggOD7RnMJU
Mar 17, 2013 - Uploaded by Tampatec
HOW TO REPAIR FIX VCR VHS DVD COMBO Easy Quick & Simple COMMON FIXES FOR ... this works ...
Magnavox TV help - ecoustics.com
Dec 30, 2015 | Magnavox Televison & Video
Emerson tv problems
If you are using a cable or satelite box, the problem could be from mismatch of the volume level between the TV & the source. This is solved by properly adjusting the 2 volume levels to eliminate the buzz.
The issue could also be either your speakers or Input/Output PCB.
Also be sure it is coming from the speakers.There have been some issues of buzzing caused by vibrating transformers on circuit boards,
Jul 24, 2014 | Emerson LC320EMXF 32 in. LCD TV
My GPX tv/dvd combo is making an intermitent 'buzzing' sound,anyone know how to fix it?
Is the sound coming from the speakers? (do you hear it with the sound turned off)
Either an audio problem if heard only with sound up or if a buzz with sound off it is a coil or transformer on the circuit board vibrating hard enough to produce the noise.
Both are fixable but require different tactics to resolve.
Mar 14, 2012 | GPX Televison & Video
My phone wont stop talking, the key tone is off and when its just on vibrate it keeps talking and it like screams it when it talks.
I had the same probelm:My phone started using a female to tell me if somebody called to sent a text message.
Phone: LG Lotus LX600
Solution: Tools -> 6)Voice Control -> 5)Voice Guide Set Alert to Off Set Reader to Off
I don't know how it got into this state, but turning off the Voice Guide Alert and Reader made it go away.
Jun 03, 2011 | LG Lotus Cell Phone
LG AX390 phone does not ring, only vibrates
Mine will not ring... It just has a stupid female voice that says call from xxxxxxx call from xxxx and I can't hear the voice when I am operating loud equipment?????
Aug 02, 2010 | LG AX390 Cellular Phone
Dacor DMT2420s when started makes a loud buzzing sound
The fan could have an obstuction. I have heard of tech sheets getting into the fan and causing a vibration and vibrating sound.
May 12, 2009 | Dacor DMT2420SS Microwave Oven
LG flat screen TV speakers make a vibrating noise
I have this problem with my 37LG30.
They all seem to have the same factory flaw.
The plastic bezel and rear is vibrating against itself I have found.
Tonight, just now, I just took all the front bezel screws out,(from the back) loosened the other 4 big screws in the rear center(I don't recommend removing them)and loosened the stand screws also and tried separating the bezel from the back as I went around the set. This did not really help much except around the bottom where the noise/vibrating comes from-the speaker area.
The two plastic pieces are vibrating against one another.
The vibrating was coming from the speaker area without doubt.
The next thing was to try separating at the bottom where the speakers are with my fingers and a stiff metal nail file carefully..fingers seemed to work best for me.
As I separated the front bezel from the rear housing (at the speaker location)most if not all the buzzing/vibrating /distortion went away.
I then inserted small pieces of cotton (you can use felt, or similar I suppose) and buttoned it all back up;put the screws in
Almost all the distortion and speaker buzz/vibratingis gone except on very low frequencies.
good luck!
Jan 29, 2009 | LG 42LC2D 42 in. LCD HDTV
Nextar x3 08 GPS -Can I change the female voice to a male voice?
You cannot modify the voice like you can for TomTom. You are pretty much stuck with the female voice if you want voice prompts.
Nov 03, 2008 | Nextar X3-02 GPS Receiver
Very loud fan or vibration noise
Listen from the back of the TV and locate the source of the noise. There may be fan with a bad bearing. The noise will lead you to it.
Nov 06, 2007 | Soyo Dymond DYLT037A Television
LG 42LC2D 42 in. LCD HDTV Logo
113 people viewed this question
Computer Repairing
Computer Repairing
