Question about Reddy Heater RLP100 Portable Forced Air Propane Heater with Variable Heat Ouput
I have to hold the knob in to keep it going. Even after a couple of minutes
  • 1,420 Answers
Bad thermocouple or it is not in the pilot flame enough.
Posted on Nov 18, 2009
Is there a trick to starting the Pyrox 400? Turned the fan on and press on low then repeatedly press the ignition pilot light, start to smell of gas after a minute. Won't start Help please
Is the ignition sparking? When you press and hold down the buttons, the ignition should be sparking at the centre electrode. At the same time when you hold the buttons down, the gas valve is manually held open to release the gas. The spark is then supposed to ignite the gas. Hold the knobs down for about 3 to 5 seconds after ignition and the gas valve will stay on. If it lights but the flame wont stay on, it could be anything from a partially blocked aeration port to a worn knob. When you push down on the knob, it is supposed to press down on an electromagnetic lock which keeps the gas valve open when the flame is burning. When the knob or shaft isn't pushing down enough, it doesn't keep the gas valve locked and the flame will go out as soon as you let the knob go.
Apr 19, 2015 | Heating & Cooling
How do i light my furnuce in my fifth wheel
Turn the gas valve to pilot, depress knob-hold & light the pilot...keep depressed for a minute & let go...make sure the pilot stays lit, then turn the knob to ON.
Dec 05, 2013 | Heating & Cooling
Pilot light keeps going out
pilot light keeps going out! more then likely its the thermal coupling doing this. if bad it shut all gas to heater for a safety measure. just shut power off, then turn gas off and replace it. then you should be ready to go. to relight heater hold down on gas vavle knob in the pilot position, hold down and light it at the coupling where gas comes out. when it is lit, continue to hold down for 60 seconds. release knob very slow. then if its lit, turn to the run position. if flme goes out, wait at least 5 minutes to expel the gas fumes and turn to pilot and try again. good-day !
Mar 31, 2012 | Water Heaters
How to light pilot on Dayton furnace and then start furnace
If this is a standing pilot system, turn the gas valve to pilot position. push in the knob & hold while lighting pilot...keeping holding knob down for a minute... this will pick & hold the gas valve. Let go of the knob & see if the pilot stays lit, if it does, then turn the knob to on position & the furnace should start if there is a call for heat from the thermostat
Sep 15, 2011 | Dayton Gas Furnace Heater
How do i relight my water heater
turn gas knob to off, wait a minute, then turn knob to pilot. then press down on knob while lighting pilot, hold down at least 1 minute, then let the knob up slow. if it lights, then turn knob to run. if you can not light it after a few trys then the thermal coupling is bad and needs replaced. have a good day !
May 01, 2011 | Rinnai Orbis Vented Heater 15,000 BTU Wall...
Recently the Maintenance Required light comes on and blinks for a couple of minutes, then goes off. We put new brakes on the front and we changed the oil and I thought the light would stop, but it's still...
the car is telling you that the oil needs to be changed/ the milage has reached the limit for needing to be changed. even if you have changed the oil it will still warn you after 7500 miles to change the oil. To make the light go off, press and hold the knob the resets your milage for 15 secs then turn the key to the on position(dont start the car) then continue to hold the knob in for about 30 secs, release, turn the car off, wait 5 secs, turn car to on position, then back off the start the car it should clear the maintence light.
Oct 18, 2010 | 2005 Honda Pilot
I HAVE A 20+ BRYANT BOILER THE PILOT LIGHT IS OFF HOW DO I TURN IT BACK ON PLEASE HELP THANKING YOU IN ADVANCE MS I
Turn the gas valve to pilot. Push knob down & hold. While holding, light pilot & keep knob held down for one minute. Let go of knob & see if pilot stays lit. then turn knob to on position. Boiler should then turn on.
Oct 18, 2010 | Bryant Heating & Cooling
Pioneer
Hold down the volume knob until clock displays flashing. Use up and down arrows to change, right and left to switch from hours to minutes. Click volume knob again to go back to tuner or cd. Your welcome people...
Shane
Jun 24, 2008 | Car Audio & Video
Heating & Cooling Logo
128 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
