Question about Technics SL-1210 Turntable
1210 mk2 troubles
I was spinning records the other day and with no warning my 1210mk2 just turned off and would not come back on. any ideas on what caused this and what steps to fix it I might try?
  • 135 Answers
Try fuse F1 / 250mA
Posted on Jul 05, 2010
Tone arm cueing problem on technics sl 1210
The turntable may not be level and consequently beyond the ability of the balance and antiskate adjustments to correct
Jun 26, 2013 | Panasonic Technics SL-1210MK2 Turntable
Distorted sound on Technics SL-1210 mk2
Hi, check to make sure the headshell is fitted properly to the tone arm and that the stylus is not damaged. Cheers john. Styluscity
Sep 26, 2012 | Technics SL-1200 Turntable
I have two 1210s, a mk 2 and a mk 5. When I let go of a record on my mk 2 it seems to take longer to catch speed compared to my mk 5, and feels 'slack'. Any ideas what this is?
Being the older model, the chances are that the drive belt on the Mk2 turntable has got worn and shiny with use. It may also have stretched a bit. If you are using the tables for 'scratching', the fact that you are holding onto the turntable when the motor is running is placing a strain on the belt that it is not really designed for. I would recommend changing the belt - you can easily find spare belts for sale on the internet
Feb 02, 2011 | Technics SL-1210 Turntable
Technics 1210 mk2 motor problem
Depends on if it's a belt drive turntable or direct drive.
If a belt one, there will either be a speed adjuster on the top of the motor, or one on a PC Board. And yes apart from setting the speed, it as straightforward as taking the old one out and wiring the new one in.
The direct drive, will also have to be adjusted for speed too.
Feb 22, 2010 | Panasonic Technics SL-1210MK2 Turntable
He doesn't start anymore
I'm havin the same problem,
did u manage to work out what the fix is?
Dec 20, 2009 | Panasonic Technics SL-1210MK2 Turntable
Technics 1210 MK2 - unstable/uneven speed problem
Since this is a direct-drive turntable, it isn't a slipping or stretched belt. You will need a technician with a couple pieces of equipment and some experience/training to find the source of the problem. I suspect the part(s) will be the minor cost of the repair.
Sep 07, 2009 | Technics SL-1210 Turntable
Turntables lags on pick up
I have the same exact problem with one of my 1210 MK2 turntables. It seems like the motor is too slow now. When I hit the start button or release the record, it takes much longer to speed up to the normal speed than my other same exact turntable. I don't think it has anything to do with the pitch slider. Please let me know if you find out what the problem is thanks!
Mar 18, 2009 | Panasonic Technics SL-1210MK2 Turntable
Technics sl 1210 will not start up
did you ever open the turntable. It sounds like the on/off switch is bad. Remove the platter and screws with a phillips screw driver and just make sure the connections are in place. make sure you disconnect the power first. let me know what happens afterwards.
May 24, 2008 | Technics SL-1210 Turntable
Technics sl 1210 MK2 does not start
Your switch probably went bad. Does it not respond at all? Does the button at least 'bounce' back when you press it? If not, then you might have messed something up when putting it back together.
- DJPROLAB
Feb 14, 2008 | Technics SL-1210 Turntable
Technics SL-1210 Turntable Logo
134 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
