Question about Garden
I have a Stihl BG55 Blower Gas comes out of muffler.
I have a Stihl BG55 Blower. When trying to start, gas comes out of the muffler. Any thoughts?
  • 169 Answers
You have a piece of trash/debris under the inlet needle of the carb and or a welch plug has come out, ive seen this many times on zama carbs, if its within warranty bring it back to your service center for a new carburetor.
Posted on Nov 18, 2009
Installed a new carburetor on stihl bg55 blower. primer bulb filling up but is not pushing gas into carb. no cracks in line filter is good. Have tried two new carbs with same result.
If the bulb wont prime you have a leak some where lines, tank, cap, if it is not air tight it will not pump.tank full of gas.
Apr 05, 2017 | Stihl Garden
I have a BG55 blower when I try to prime it no gas come in bubble. I have made sure there nothing in gas line,and it skeet when I put a pin in the little hole, but no gas when u try to prime.
Apart from the bubble there is at least one non-return valve that could be stuck or not working because it is dry.
Could be removing the bubble and wetting everything thoroughly with fuel and quickly refitting it could kick-start it and make it work.
Sep 05, 2016 | Stihl Bg 55
My stihl fs400 strimmer starts first time and runs on full throttle then dies a few moments later starts first time and does ame thing again
inside the muffler there is a screen that gets all gummed up, take muffler assy. apart and clean screen, if you have a propane torch, this works well as you burn crud off it becomes ash and wipes or blows off. first link shows how.
press the helpful button and follow me on fixya
Easy Repair on STIHL FS38 Grass Trimmer Clogged Spark Arrester
how to fix stihl trimmer
STIHL GAS TRIMMER REPAIR Stihl FS 40 Grass Trimmer RAN NO OIL IN GAS blown...
How to fix bogging out grass trimmer with clogged spark arrester
Feb 03, 2016 | Stihl Garden
Stilh bg55 spark plug setting
Hi
Stilh recommend 0.020 inch (20 thou), however I have found that 0.025 (25 thou) or 0.6 mm provides a better start and run arrangement.
Regards
Jacko from down under
Apr 26, 2014 | Stihl Bg55 Bg65 Bg85 Leaf Blower Fan
Will start with chock on but wont stay running with it off
the idle jet or the float valve is blocked
you need to strip the carb and unscrew the jets and clean them
i use small interdental brushes ...
Mar 23, 2014 | Stihl Blower Handle Moulding Bg Sh 45 55...
How do I adjust the carburator on my Stihl BG55 leaf blower
You can adjust the carb by turning the screws counterclockwise, the H high speed screw is the one closest to the Air Filter and the low L is closest to cylinder (Motor) Change your spark plug first, then run it at wide open throttle and slowly turn the "H" screw counterclockwise a little at a time if it blubbers then it is too far out (rich) so take it the other way till you reach peak R.P.M. s -then back it out opposite way till the sound of the R.P.M's just starts to drop and High speed is set. the low speed is adjusted at idle to where there is no hesitation when you pull throttle open, keep trying till you get a good acceleration with out hesitation, and you are good to go!
Nov 12, 2011 | Garden
Manuel for bg55 stihl gas blower
MOST OF THE TIME YOU CAN GO ONLINE TO STIHL AND THEY HAVE A PDF PARTS AND MANUAL SECTION FOR JUST ABOUT EVERYTHING THEY SELL
Jan 01, 2011 | Garden
Parts list and view for stihl bg55 blower
Unfortunately, STIHL won't release or allow their dealers to release illustrated parts lists of any kind. If you have a local dealer, sometimes they will let you look at their diagrams while at their shop. Sorry.
Dec 22, 2010 | Garden
Garden Logo
1,208 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
