Question about Cyberhome CH-DVD 300 DVD Player
It does not want to load anything.
My cyberhome 300 does not want to load any dvd ,I had it in region 0 to watch a dvd from canada and all of the sudden only load appears in the screen everytime I insert a dvd for hours and nothing happens?
  • 3 more comments
  • Anonymous Feb 12, 2008
    my dvd is getting as no disk
  • ShyGal16 Feb 14, 2008
    I've turned on my DVD player, put in the disk and at first it says it is reading the disk, but after several minutes reading is replaced with a ? beside a disk and the led power light flashes green and red.
    I've checked the connections and they apear fine. The disk is a rental butlooks relitivly free of problems. Not a tech person so no idea what else to try.
  • Lyndah Feb 17, 2008
    When I put in a dvd, it says loading for a minute or two then it says no dvd. How can I fix this?
  • Anonymous Feb 18, 2008
    cleaning
  • worldchanger Mar 15, 2008
    the solution says to reset to default, but how do i do that? And will Divx format DVDs play in my player?
    Problem Solver:
  • 9 Answers
I cannot reset my defaults on my unit,go to setup,,,system menu ,,,scroll down (green buttons),,If load setup defaults is in black letters, I havent found a way to use this function,,dont know about divx format,try holding the stop button on front of player for 5 sec.
Posted on Mar 15, 2008
  • rdmkr1 Mar 15, 2008
    No disk errors are usually power supply probs
  • 58 Answers
Have you tried resetting it to factory defaults?
Posted on Feb 09, 2008
I have a Cyberhome CH DVD 300 (region 1), I want to change the region on this player. I learned I need for first: 1.- Turn On the DVD player 2.- The tray needs to be closed and empty 3.- Press the Menu...
  1. Turn on the player (without a disc inserted)
  2. Close the disc tray
  3. Press MENU, 1, 9
  4. Selection menu will be displayed
  5. Press ENTER
  6. Select region
  7. Press ENTER
  8. Press OPEN/CLOSE
Dec 07, 2010 | Cyberhome CH-DVD 300 DVD Player
Is it possible to change the region code to region 3 so we can watch movies from Thailand? No need to switch back as I have another DVD on region 1. Charlie (cleggett1937@aol.com)
You can make this player REGION FREE so all discs operate on it.
Power up, no disk in. Status says READ then INSERT DISC.
Press MENU (status reads invalid key icon)
Press 1 (status reads invalid key icon)
Press 9 Menu is displayed.
Press ENTER on the region, digit turns to "-"
Press 0
Press ENTER again
Press EJECT to clear the special menu.
If you reset (unplug) the player for any reason - this will need to be re-entered.
Thanks for using FixYa!!
Mar 18, 2010 | Cyberhome CH-DVD 300 DVD Player
Need remote code
try this method THIS METHOD WORKS FOR THE CH-DVD 300, CH-DVD 300S, AND CH-DVD 320
1. Switch player on, making sure that there's no disc in the tray.
2. Close tray.
3. Using the remote control, key in the following: MENU, 1, 9.
4. A menu will appear with the region option near the bottom of the screen.
5. Press ENTER, enter the desired region (0=REGION FREE )AND PRESS ENTER again to save the desired region.
6. Press OPEN/CLOSE. Hope this helps you with your problem
May 02, 2009 | Cyberhome CH-DVD 300 DVD Player
Need a universal remote code for a cyberhome dvd 300
Cyberhome 300 DVD player codes... 20816 20874 21023 21129 21023 worked on my comcast remote for all the DVD PLAYER FUNCTIONS!!! =)
Jan 14, 2009 | Cyberhome CH-DVD 300 DVD Player
Change region
Switch player on and make sure there is no disc in the tray.
CLose tray and press menu,1,9.
A menu should appear with the region option at about the third line from the bottom. Press enter and enter the region you want("0" for free zone) . Next press open/close.
Sep 09, 2008 | Cyberhome CH-DVD 300 DVD Player
Cyberhome Ch- DVD 300
Your advice was very helpful. After two+ months of tooling around and navigating around the menu blind I was on the brink of trashing it.
At first I tried the stop button with a dvd in the player with no success. After taking the dvd out, turning in off/on then pressing the stop button for 20 seconds the screen turned blue as said.
This help saved me a great amount of fustation.
Thank You!
May 27, 2008 | Cyberhome CH-DVD 300 DVD Player
Region Error
this is for: Cyberhome CH-DVD-300 1. Ensure the players disk tray is Closed with no disc . 2. Press Menu. 3. Press 1. 4. Press 9. 5. A menu will appear with the region number near the bottom of the screen. 6. Press Enter. 7. Select the desired region. 8. Press Enter to save the settings.
Jan 31, 2007 | Cyberhome CH-DVD 300 DVD Player
DVD Player stops in "Loading..." mode
1. Check that disc is encoded for your geographical region. A disc from Europe (Region 2) will not play in a North American (Region 1) player. 2. Turn off player with disc inserted, unplug temporarily from wall outlet, plug back in and turn back on. 3. If your player has a transportation lock (usually a plastic screw on the bottom of the unit), make sure that it is not engaged. 4. If you have an older player, check with the manufacturer to see whether an update to the firmware is available. Many newer DVD titles with lots of special features are famous for causing problems on older players. if nothing helps, call for service.
Sep 12, 2005 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
89 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
