Question about Samsung HT-Z310T Theater System
DVD PLAYER FAN MAKES REALLY LOUD NOISE IT SOMETIMES GOES AWAY WHEN I TAP THE BACK OF THE FAN SOUNDS LIKE ITS JAMMING
  • 10,594 Answers
When fan's shaft got dry, it start vibration in spinning and produce lound noise. Lubricate exhaust fan shaft with good quality machine oil.
Thanks.
Posted on Nov 18, 2009
The engine in my automatic '91 Integra intermittently makes a loud squeaking noise...it sounds to be coming from the left side of the car under the hood. It is not the fan/fan belt, as the noise...
are you sure its not your fan belts? because if fan belts are not turning, it means that the engine is off. check if the tension in your fan belts are still ok. if not, have it re tensioned. if noise is still present, have it changed.
Aug 11, 2011 | Acura Integra Cars & Trucks
Fan makes a loud noise i tap on the top then it goes away . Or if I blow in to the vents it goes away then comes back later? let me know
Sounds like filter is clogged or dirty. Take a vac cleaner to the vents. If that doesn't cure it, then disassemble and clean thoroughly.
Jan 07, 2011 | Optoma HD20 DLP Projector
Hello I have a Dell Dimension 3100 desktop. After
Bad Fan... either the CPU Fan or the Power Supply Fan or the Case Fan. If the PC is older than 4 years it is probably the Power Supply.
Dec 30, 2009 | Dell Dimension 3100 PC Desktop
Philips pet1030 portable DVD player makes this horribly loud noise when you put in a cd ,then either reads no disk, or shuts itself off, sometimes it works fine.
its possible the laser carriage is jammed or jamming, the only thing you can do is try pushing the carriage up and down in its slot a few times to see if this clears it
Nov 23, 2009 | Televison & Video
My projector makes a really annoying noise
It is also possible that the bearing is going bad on the fan. I'd look into getting a replacement fan if that's the case. It is probably cheaper than a replacement bulb that would be needed if the fan failed entirely.
Jul 09, 2009 | Toshiba TDP-P5 DLP Projector
Acer aspire4920 makes loud noise at start up
This could be caused by the harddrive. There might be a bad bearing or something. Please backup all your data. You will probably have to replace the hard drive sooner or later.
May 07, 2009 | E-Machines T6524 PC Desktop
Loud air intake engine noise on startup
I would guess it is the electronic fan clutch. It will cause the fan to run too fast (very loud) and the light will come on sometimes.
Nov 10, 2008 | 2002 GMC Envoy XL
Dryer doesnt do anything besides a loud noise
What kind of loud noise??  A loud electrical noise??  A loud squealing noise??
It's possible that there is a foreign matter inside the filter chamber jamming up the blower fan.  Pull the filter screen out and look down the filter chamber area and see if there is a sock jamming the fan from turning.  If you can pull it out, that should resolve your problem.  If not, you may need to call a qualified LG technician to resolve this issue.
Mar 16, 2008 | LG DLE2532W Electric Dryer
After Recording
Unit sounds like it has a small cooling fan at the rear. A bad fan bearing will produce a noise when dried-out. Replace the cooling fan.
Jun 23, 2007 | LG DR-4912 DVD Recorder
Samsung HT-Z310T Theater System Logo
1,261 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
