Question about LG Shine CU720 Cellular Phone
My LG shine slider bought in June 2008 from Rogers works but the screen goes black except for the backlight. All keys work including the keyboard light and calls can be received and made. I've tried to remove the battery and sim card and then turn it back on but the frozen screen and backlight persist. What can I do?
My pc doesnt' work
Can you hear the mac startup sound? If you hear then its booting up.
Let it finish booting. Press the Brightness keys on the keyboard "F1 and F2" does the screen backlight turns on? if not use a flashlight and shine it on the screen.if you can see your desktop then your backlight has problems.
Apr 03, 2014 | Apple MacBook Mac Notebook
HI I have used LG Flatron L1915S computer monitor. When I plug it into my laptop, it blinks showing the laptop desktop for less than a second then goes black. Other monitors works fine when I plug them...
There is often a function monitor key on the laptop, located near the F7 key area, the icon looks like a monitor on|off and is typically in blue. this key is to be used in combination with the Fn key to enable, disable the external monitor or enable both monitors or just the laptop. Press the key combination until your laptop panel lights up while the monitor is plugged in. Now check your extenal monitor refresh rate and resolution slider settings by right clicking on your desktop go to properties / video settings. (please note monitor settings are under advanced). You should see two monitors in there now. use "identify" button so you know which one to work with. on the external monitor settings, decrease (slide left the slider all the way). If you can set the monitor refresh to 60Htz. Lastly take a flashlight and check if you can see a shadow of your screen on the external monitor, if you can that means the backlight is not working and likely needs the inverter replaced. Hope that helps ! Cheers
Aug 30, 2010 | LG L1915S 19" LCD Monitor
Replacement screen for lg shine cu720 not working
go to your nearest store and explain what happen
Dec 03, 2009 | LG Shine CU720 Cellular Phone
I recently bought a LG Shine CU720 from ebay, it allows me to recieve and make calls as well as texts, but I am still unable to access the internet or recieve picture messasges. My phone has all of the...
i just got lg shine from ebay to with rogers settings and needed to change them to att.i tried everything.i finnally got att to give me all the settings for the lg shine cu720.if you email me at hey_u@been-there.com ill send them to you.its a lot to type out.it worked great for my phone and i found that no one on here has the right settings
Jul 10, 2009 | LG Shine CU720 Cellular Phone
Bought lg vu unlocked, internet doesn't work!
I did the same thing and after a little online sleuthing i found this solution (it works for me)
go to "menu" then "media net" then "browser settings"
Next go to "accounts" then hit "new" (at the top right next to the title "accounts")
fill in dialog boxes as follows
Account name: Rogers (doesn't really matter what you name it, this will just be the name of the network as it shows up in the menu)
Homepage: mymobilehomepage.rogers.com
Connection mode: TCP with Proxy
Proxy Address: 208.200.067.150
Proxy Port Number: 80
Security: Non-secure
Time out: 150
then click where it says MEdia Net and hit "options" then "new"
fill in the following
Connection Title: Rogers (again doesn't matter what you name it)
Authentication: PAP (don't worry about "bearer")
User Name: wapuser1
Password: wap
APN: goam.com
After everything is complete make sure to select your new option at the bottom (where it used to say "MEdia Net" it should now say "Rogers" or whatever you decided to name it)
Finally hit "save" and activate this profile. You should now be able to access the internet from your LG VU
Credit goes to http://www.howardforums.com/archive/topic/1047591-1.html
Jan 08, 2009 | LG Vu CU920 Cellular Phone
Power saving mode knocks the computer out, have to restart
I have an LG Flatron 19" black w1952TQ that I bought on 2 Apr 2008; when it goes into sleep mode, will not recover. Did the online troubleshooting, reseting things, unplugging/replugging all cables, nothing works except restarting the computer, and that only works until it sleeps... Read more
Aug 05, 2008 | LG Computers & Internet
My screen is black on my LG shine the phone still works, but the screen is competely black can I get a new LCD screen for this slider phone? what can I do
Is it a flip flop type of phone or a slide type.?
You need to eplace the flex wire of that phone 'coz that's the
usual problem of all flip and slide type of phones
Mar 18, 2008 | Lands Phones
I got a LG shine from Rogers and i got it unlocked to Fido, But now the Internet doesn't work
Simple don't waste money using a mobile to access the internet!!!
By not working you are saving a fortune
Feb 23, 2008 | LG Shine KE970 Cellular Phone
Lg shine tu720
How come whenever i import songs for my TU720 using the LG software it came with, it gets saved to the Rogers music player instead of the music player that is already built in the phone ? ( this is usiing the internal memory )
Dec 20, 2007 | LG Shine KE970 Cellular Phone
LG Shine CU720 Cellular Phone Logo
290 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
