Clothes washer will not agitate or spin
Between loads, the machines agitator stopped, and it also will not spin.
Motor is running.
I didn't see a belt.
Any suggestions?
  • 2 more comments
  • Waynem813 Jan 11, 2008
    Whirlpool Heavy Duty Super Capacity PLUS
    Model # LSR7233DQ0
    No, I haven't looked at it that closely. I just noticed that there was a black rubber substance under the motor, and what I thought was a type of belt on the side of the motor facing the transmission. Do you have a suggestion for the case?
  • Waynem813 Jan 12, 2008
    Tech17: your diagnosis was right on target.
    Your step by step instructions were great!
    I purchased the parts, followed your instructions to the letter, and now have a washer that works fine again!.
    Thanks for your help!!!
  • amayfi04 May 23, 2009
    The machines agitator stopped, and it also will not spin.
    Motor is running.
    Whirlpool Heavy Duty Super Capacity PLUS: Model # LSR7233DQ0
    President:
  • 1,314 Answers
Reply to me with brand and model number may can help but dont rate me till we are done
Posted on Jan 10, 2008
  • 1 more comment
  • robert samples Jan 11, 2008
    ok you have a broken motor coupling do you know how to get the case off its not hard to fix reply
    Well I'm going to do my best to fix your washer. First unplug the washer and turn off the water. If you have a shop vac take the drain hose out of the drain,and through the drain hose vacuum the water out of your washer. If you don't have a shop vac go to the auto parts store and buy a pair of radiator hose clamps . Then facing the washer locate the two screws. They will either be in the front or rear of the control panel and back them out far as you can. Once you have done that pull the control panel slightly forward, and tilt it back on the hinges. Now unplug the lid switch wire but don't forget to plug it back when your done. Next locate at the rear of the washer body the two gold clips then push forward, and take careful note of how they fit. Then pop them out with a screw driver tilt the washer body forward at 45 degree angel and walk forward with the body, and set it down. Now you will see the white pump and motor assembly. You should see two clips holding the pump to the motor pop them off, and pull the pump off the motor shaft. Now if you fell the need to remove the pump use the radiator hose clamp. take them and clamp the hose coming from the tub but its not necessary for the repair. Next disconnect the wiring harness from the motor (note the position of the harness for reassembly). Remove the two 5/16 inch screws from the motor clamps and pop the clamps off. Once that is complete, remove the motor put the new coupling on the motor and transmission shaft. I use a socket and a hammer to tap it on the transmission shaft. (put the rubber piece on then the motor now you got to be patient here some are easy some you must play with). Once it slides in pop motor clamps back on replace motor clamp screws. From here the rest should be gravy, and that should fix it. Please don't forget my four boxes that's how we get paid.
  • robert samples Jan 12, 2008
    your welcome thanks for the rating
My Kenmore washer has stopped agitating. The motor is running, what should I do?
Thanks.
Posted on Feb 24, 2010
Machine not spinning dry
Top-loading washing machine has an outer tub that fills with water and sits stationary as well as an inner tub with holes in it. The inner tub has an agitator that attaches to the drive shaft. A drive belt turns the drive shaft, causing the agitator to move back and forth. Broken seals at the bottom of the agitator, or a broken belt, may cause the agitator to perform inefficiently and leave your clothes dirty
In order to properly wash clothes and prepare them for drying, a washer must agitate or spin the load. This helps wring excess water out of the clothing. If your washer has suddenly stopped spinning properly, you will notice that your clothes will be sopping wet when the washer is done. Typically, there is a simple reason for this problem that you can fix without calling in a professiona
1 Check the lid switch. You will notice on the lip of the lid there is a small stem that hangs down. This fits into a hole on the top of the washer housing and tells the washer the lid is closed and it is safe to spin the load. If the switch is faulty or has been blocked, the washer will not agitate or spin.
2 Clean out the switch receptacle. Use a multipurpose cleaner and a sponge (not a paper towel, it can shred and get caught in the switch receptacle.) Thoroughly clean the area around the switch and the receptacle.
3 Test the washer. Close the lid, allow the washer to fill with an inch of water, and move the selector to the spin cycle. Pull out on the selector. If it does not spin, stop the cycle (push the selector in) and turn the washing machine off. This means there could be three problems with the washer: the switch might be broken, something might be caught in the agitator, or the motor for the agitator may be burned out.
4 Check underneath the agitator. Small items such as underwear, panty hose or bra straps can become caught underneath the agitator and keep it from moving. Run your hand underneath this area and see if you feel anything. If you do, unwrap the item and test the washer again. If it still does not work, move to Step 5.
5 Contact a repair person. If the washer still will not agitate or spin, it will need to either have the switch replaced or the motor replaced. Contact a certified appliance repair person to have the machine inspected. If it is still under warranty, the repair person's visit should be covered.
However if its only the agitator arm, then
Instructions to Remove/replace the Agitator
1 Unplug the washer.
2 Slide a putty knife under each side of the washing machine top to release the springs holding the top in place. Lift up the top on its hinges.
3 Pull the tub clips from the inner tub using a pair of pliers.
4 Pull up on the agitator top to expose the nut holding it in place. Remove the nut using a socket wrench. Lift up on the agitator to remove it from the machine.
5 Turn the agitator upside down and remove the seals from the bottom. Replace them with a new set of seals. If the agitator is cracked, replace it.
6 Reassemble the washer.
Removing the Belt
7 Unplug the washer from the wall outlet.
8 Pull out on the bottom panel on the front of the machine. Look underneath to locate the drive belt.
9 Pull on the drive belt at the washer tub to remove it. Push down on the idler pulley near the motor to remove the belt from the machine. Route the new belt around the pulleys in the same way as before.
10 Reassemble the machine, plug it in and test.
Apr 20, 2012 | Whirlpool Washing Machines
The washer is not spinning and clothes are extermely wet top load 3.5
Hi, Well try to set the washer on the regular cycle, large load and let it fill. After the washer fills to the selected level, the motor should start and the agitator should start agitating.
If you hear the motor running, but the agitator doesn't move at all, do the following:-
Stop the washer and set the timer on the spin cycle and let it run.
If the washer motor runs and the washer empties the water from the tank, but it won't spin, that is an indication that the motor coupler is not turning the transmission at all.
The motor coupler is made of two pieces of plastic called fingers and a hard rubber piece that goes in between the two fingers. One of the fingers is attached to the motor and the other finger is attached to the transmission. The had rubber round piece goes between the two fingers. When one of the plastic fingers breaks, the motor is no longer coupled to the transmission and the washer will not agitate or spin dry the clothes. The reason that the motor coupler breaks before it should, it is that the user overloads the washer. People stuff the washer with too much clothes, big comforters, small placer rugs, snickers, etc.
Another reason is that the washer is used every day; normally the washer is used 3 times a week. So if you have a washer that is 5 years old and you use it every day, it has the wear and tear of a washer that is 10 years old.
Replacing the motor coupler is not hard to do, once you see how the repair is done. You will save at least $100 by replacing the motor coupler yourself.
Thanks!
mannu_rakesh
Aug 21, 2009 | Washing Machines
Maytag Atlantis 6451 noise when on and agitator doesn't work.
it does sound like a bad motor.
they are rather expensive on that machine,
you would be looking at 300 or so
May 28, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Washer won't spin or agitate
It doesn't agitate If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Apr 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Water pumps in timer cycles but machine will not agitate or spin
Hii!! yo check your washer belt.if on the you have a tranny problem.good luck
Jan 16, 2009 | Frigidaire FWS833A Top Load Washer
Washing Machine Shaft Wont Move
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Dec 08, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Machine does not spin, clothes are soaked
fill washer and make sure it agitates. If it does not agitate but can here motor running you have a bad motor coupling. If it agitates but wont spin make sure lid switch is good, if good you have a bad gearcase.
Jan 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer problems
if it wont drain , check your lid switch, check out your motor coupler, if it will not agitate and spin, replace your motor coupler, if it agitates and dont spin, replace your lid switch.
alot of times the washer will drain but we hurriedly cut it off when we hear noise or the water is out but it never spinned and so the clothes are soapy wet...
Nov 12, 2007 | Roper RAX7244KQ Top Load Washer
Washing Machines Logo
1,244 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
